07-30-2011, 07:00 | #2 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hello, To make this phone supported we need to get some information about phone hardware: 1. What is this phone CPU chip name ? 2. What is phone bottom connector type, how many pins ? Please, post an answer here or send an information to [email protected] Thank you very much in advance for information about this phone ! |
08-02-2011, 23:34 | #4 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Thanks for advice, but anyway, my questions to people who really have this phone on hands: 1. What is this phone CPU chip name ? 2. What is phone bottom connector type, how many pins ? Please, post an answer here or send an information to [email protected] Thank you very much in advance for information about this phone ! |
11-22-2011, 16:26 | #6 (permalink) |
Freak Poster Join Date: May 2010 Age: 35
Member: 1300364 Status: Offline Thanks Meter: 23 | i have this phone in my hand any news sir ? ********* COM5 [VCP4] selected module v4.07 Device: _Autodetect MT6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: read ffs/eeprom ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A08]... CPU: MT6223 high speed boot On chip: 0011:5BD2:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: C2227E22212201:2AEA0000000000 flash: AMD/Fujitsu std [def 0080x020000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: C2227E22212201:2AEA0000000000 flash: AMD/Fujitsu std [def 0080x020000] 16Mb otp offset: 00000000 detecting chip #02 in region #00... flash: C2227E22212201:2AEA0000000000 flash: AMD/Fujitsu std [def 0080x020000] 16Mb otp offset: 00000000 detecting chip #03 in region #00... flash: C2227E22212201:2AEA0000000000 flash: AMD/Fujitsu std [def 0080x020000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: C2227E22212201:2AEA0000000000 flash: AMD/Fujitsu std [def 0080x020000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: C2227E22212201:2AEA0000000000 flash: AMD/Fujitsu std [def 0080x020000] 16Mb otp offset: 00000000 it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (07) TCL-ID is absent ==================== New firmware found (v.4.07, database date: 09.11.2011): ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.EF-LAPOSTE9S-P109A17V1_0_0B01.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info ver: 07 sw version: ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.EF-LAPOSTE9S-P109A17V1_0_0B01.BIN project-id: EF-LAPOSTE9S-P109A17V1.0.0B01, 00000000 code offset: 00000000 ffs offset/size [02]: 00880000/00780000 rom info structure: [standard] type (07) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00880000 standard ffs/eeprom offset confirmed: 00880000 detecting ffs/eeprom size... ffs/eeprom size: 00780000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00880000-00FFFFFF firmware area: 00000000-0087FFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done |
11-22-2011, 17:12 | #7 (permalink) |
Member: 1300364 Status: Offline Thanks Meter: 23 | Full flash + eeprom https://rapidshare.com/files/3065874...161041.B0M.rar |
The Following User Says Thank You to [email protected] For This Useful Post: |
11-22-2011, 20:14 | #9 (permalink) | |
Freak Poster Join Date: Jan 2010 Location: MALI
Member: 1219355 Status: Offline Thanks Meter: 104 | Quote:
The Following User Says Thank You to DCU-6O For This Useful Post: |
11-23-2011, 12:14 | #10 (permalink) | |
Major Poster Join Date: Apr 2008
Member: 740593 Status: Offline Thanks Meter: 9 | Quote:
192 byte(s) read 38 byte(s) read Phone lock: Off Phone code: 1234 180 byte(s) read reading data... 972 byte(s) read lock[1] code: + 804783341656 lock[2] code: + default lock[3] code: + 1122 lock[4] code: - default lock[5] code: - default lock[6] code: + default lock[7] code: + default if phone do not ask for a code try: *983*8284# if code is not accepted by phone: - make full flash backup for emergency case - flash phone with good eeprom file - Power-On phone without sim-card - Power-Off phone (do not remove battery) - read unlock codes - restore original imei Finished, time used: 15 sec Remove/Install battery now ! mobile 01 noir | |
The Following User Says Thank You to melizi_28 For This Useful Post: |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
