09-06-2017, 12:27 | #181 (permalink) |
Crazy Poster Join Date: Aug 2010
Member: 1366785 Status: Offline Thanks Meter: 2 | Box/Dongle type selected: [BEST] Card-Reader: FT SCR2000 0 HWID: 0103747115BF1292 Box/Dongle found: [BEST] Reading... Serial No (S/N): 97DB7471 Firmware version: 0122.02 === Process started: 06/09/2017 12:23:25 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0007] No updates found for your Smart-Card. DO NOT try more today ! |
09-06-2017, 12:28 | #182 (permalink) |
Member: 1366785 Status: Offline Thanks Meter: 2 | == DongleManager [Infinity] v1.70 [06/09/2017 12:27:41] === Searching... Card-Reader: FT SCR2000 0 HWID: 0103747115BF1292 Box/Dongle found: [BEST] Serial No (S/N): 97DB7471 Firmware version: 0122.02 "UK Edition" status: Off Last launched Application: 0000 v.0000 => Activations: - 03: [BEST] v.0122 - 07: module #07 => Box/Dongle misconfiguration. Contact to support ! |
09-06-2017, 13:49 | #183 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
What to do: 1. Install required Card-Reader Drivers: - File with Drivers: CardReader_Fetian_FT2K.7z - File with Instruction: Infinity-Box_How_to_update_FT_SCR2000_CardReader_drivers.pd f Drivers version after installation should be 2.5.6.0823 or 2.5.9.1202 Download files - http://www.infinity-box.com/support/?r=6 OR 1. Insert Smart-Card into another Card-Reader (good result for today is with Alcor Card-Reader) The next steps are: 2. Run DongleManager 3. Update Dongle firmware - DO NOT update Smart-Card many times otherwise your account will be locked automatically after 3 tries for 24 hours - DO NOT use any kind of usb sharing/trace/spy/debug software to avoid problem with Dongle ! | |
09-09-2017, 02:36 | #184 (permalink) |
Junior Member Join Date: Mar 2015 Location: CONGO? D.R.C. Age: 54
Member: 2359449 Status: Offline Thanks Meter: 2 | Hello, I have activated and upgraded my Infinity box SM, but the software opens, but it does not open the menu, for example: menu READ INFO and RESET FRP / RL etc ... what to do ? if you please help me. |
09-19-2017, 14:11 | #190 (permalink) |
No Life Poster Join Date: Oct 2004 Location: Holland China Brazil Age: 43
Member: 88016 Status: Offline Thanks Meter: 320 | === DongleManager [Infinity] v1.70 [9/19/2017 6:09:23] === Box/Dongle type selected: [BEST] Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 0003938410321292 Box/Dongle found: [BEST] Reading... Serial No (S/N): 75A89384 Firmware version: 0122.02 === Process started: 9/19/2017 6:09:24 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0006] Your account is temporary suspended. See problem reason in log file Contact to http://www.infinity-box.com/support/?r=2 |
09-21-2017, 00:30 | #194 (permalink) | |
Use Alcor reader and update dongle | |
