04-07-2018, 07:15 | #286 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Jodhpur India
Member: 48238 Status: Offline Sonork: 100.54361 Thanks Meter: 397 | === DongleManager [Infinity] v1.72 [4/7/2018 11:33:47] === Box/Dongle type selected: [BEST] Card-Reader: FT SCR2000 0 HWID: 01049F5F24881292 === Process started: 4/7/2018 11:33:47 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Contact to http://www.infinity-box.com/support/?r=2 |
04-07-2018, 11:24 | #287 (permalink) | |
What to do: 1. Install required Card-Reader Drivers: - File with Drivers: CardReader_Fetian_FT2K.7z - File with Instruction: Infinity-Box_How_to_update_FT_SCR2000_CardReader_drivers.pd f Drivers version after installation should be 2.5.6.0823 or 2.5.9.1202 Download files - http://www.infinity-box.com/support/?r=6 OR 1. Insert Smart-Card into another Card-Reader (good result for today is with Alcor Card-Reader) The next steps are: 2. Run DongleManager 3. Update Dongle firmware - DO NOT update Smart-Card many times otherwise your account will be locked automatically after 3 tries for 24 hours - DO NOT use any kind of usb sharing/trace/spy/debug software to avoid problem with Dongle ! | |
04-07-2018, 12:16 | #288 (permalink) | |
Member: 48238 Status: Offline Sonork: 100.54361 Thanks Meter: 397 | Quote:
Will try later today after arranging another Card reader and let you know the result Thanks for the reply WBR Jyoti | |
04-17-2018, 05:44 | #291 (permalink) |
Freak Poster Join Date: Jan 2010
Member: 1220104 Status: Offline Sonork: 1592061 Thanks Meter: 44 | Infinity Chinese Miracle-2 Activation problem === DongleManager [Infinity] v1.70 [4/17/2018 10:37:30] === Searching... Card-Reader: Generic EMV Smartcard Reader 0 HWID: 0000224C18164082 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): 2D832xxx Firmware version: 0118.02 === Process started: 4/17/2018 10:37:32 === Connecting to server Connection to server failedSocket Error # 10060 Connection timed out. |
04-19-2018, 10:15 | #293 (permalink) | |
04-30-2018, 12:39 | #296 (permalink) |
No Life Poster Join Date: Nov 2010 Location: cox's bazar bangladesh
Member: 1453066 Status: Offline Thanks Meter: 75 | Dongle With SM Activation Is Not Found Error: Process failed: Product (sam) already Active for Token Process terminated update firmware ok but Dongle With SM Activation Is Not Found help plzzzzzzzzzzz |
05-30-2018, 10:51 | #298 (permalink) |
Freak Poster Join Date: Jun 2007 Location: OUT OF CONTROL
Member: 536012 Status: Offline Sonork: 100.1660617 Thanks Meter: 120 | after activate SM .. Dongle with Sm activation is not Found "Token - Type: Infinity-Box/Dongle - Account Status: Active - Hardware Status: Ok Services - Activation 1: Infinity-Box/Dongle; S/N: AD****** - Activation 2: Infinity SM" |
