06-26-2018, 09:32 | #304 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | You was little bit late, SM activation has beed deactivated, please read this - http://forum.gsmhosting.com/vbb/f296...l#post13193490 |
06-26-2018, 09:41 | #305 (permalink) | |
Freak Poster Join Date: Feb 2014 Location: indore
Member: 2120393 Status: Offline Thanks Meter: 238 | Quote:
07-01-2018, 11:42 | #307 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Infinity `SM` software v2.00 released - http://forum.gsmhosting.com/vbb/f296...eased-2427131/ |
07-18-2018, 10:11 | #309 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
What to do: 1. Install required Card-Reader Drivers: - File with Drivers: CardReader_Fetian_FT2K.7z - File with Instruction: Infinity-Box_How_to_update_FT_SCR2000_CardReader_drivers.pd f Drivers version after installation should be 2.5.6.0823 or 2.5.9.1202 Download files - http://www.infinity-box.com/support/?r=6 OR 1. Insert Smart-Card into another Card-Reader (good result for today is with Alcor Card-Reader) The next steps are: 2. Run DongleManager 3. Update Dongle firmware - DO NOT update Smart-Card many times otherwise your account will be locked automatically after 3 tries for 24 hours - DO NOT use any kind of usb sharing/trace/spy/debug software to avoid problem with Dongle ! | |
07-18-2018, 10:12 | #310 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Infinity `SM` software v2.01 released - https://www.infinity-box.com/support/?r=100036 |
07-18-2018, 11:11 | #311 (permalink) |
Junior Member Join Date: Mar 2010
Member: 1260678 Status: Offline Thanks Meter: 2 | === DongleManager [Infinity] v1.72 [7/18/2018 13:08:07] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: Generic USB Smart Card Reader 0 HWID: 00004800176D4082 === Process started: 7/18/2018 13:08:07 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Contact to http://www.infinity-box.com/support/?r=2 |
07-30-2018, 10:12 | #313 (permalink) | |
This Smart-Card is not an Infinity Smart-Card - Disconnect all other Boxes and Dongles from PC - Connect ONLY one Infinity Box/Dongle to PC | |
07-30-2018, 10:13 | #314 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Please see instruction here - http://forum.gsmhosting.com/vbb/f296...eased-2427131/ |
08-01-2018, 09:47 | #315 (permalink) |
Junior Member Join Date: Mar 2014
Member: 2149356 Status: Offline Thanks Meter: 4 | pls... help,.. i bought new CM2,.. UPDATE is ok but SM not open,... === DongleManager [Infinity] v1.72 [01/08/2018 16:51:11] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 00001AB81CC74082 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): DF7D1AB8 Firmware version: 0137.02 === Process started: 01/08/2018 16:51:12 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0007] No updates found for your Smart-Card. DO NOT try more today ! pls,. help,.. |
