Old 03-16-2010, 14:33   #1 (permalink)
duyphuong3000's Avatar
Member: 468656
Thanks Meter: 76
Thumbs up Can infinity team help me with file flash Vcall 829!
Can INFI team fix file Vcall 829, i tried repair Calibrate touchscreen but not done! i tried mode Auto - 1 -2-3-4 still not fix Calibrate touchscreen! Plz, help fix this file! Thanks... Infi team...
-- mega.1280.com - M3829_PCB01_GPRS_MT6225_S00_TV_V1_1_3fullflash_201 00315-184649_B0M.rar -
Old 03-17-2010, 15:33   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
sorry, i can not download it from there
upload to some other place
Old 03-18-2010, 10:27   #3 (permalink)
Member: 468656
Thanks Meter: 76
Please! DOWNLOAD This link sir: 4shared.com - online file sharing and storage - download M3829_PCB01_GPRS_MT6225_S00_TV_V1_1_3fullflash_201 00315-184649_B0M.rar
Old 03-19-2010, 04:18   #4 (permalink)
Member: 468656
Thanks Meter: 76
INFI TEAM please help me!!!
Old 03-19-2010, 16:45   #5 (permalink)
Member: 468656
Thanks Meter: 76
Can INFI Team not fix that file flash Vcall?
Old 03-19-2010, 20:46   #6 (permalink)
Member: 148515
hello!
also post here all calibration logs.
especially MODE-AUTO
Old 03-20-2010, 08:22   #7 (permalink)
Member: 468656
Thanks Meter: 76
I tried All mode Auto then it had chosen file flash backup Vcall but i selected that file, my phone not connect phone with Phone TEST MODE and i tried select - 1 -2-3-4, it was'nt required file selected and not fix calibration!
COM16 [VCP0] selected
module  v3.10
Action: touchscreen calibration
mode: 3
Model: Autodetect 6205-6227 NOR
Checking data, wait...
19200 autodetect
Initializing [6225:8A03:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:0003:0002
status: FF
Connecting at 19200, wait...
error: can not finalize test mode
repeat operation and HOLD phone "Power" button long time !
error: operation failed !
Finished, time used: 1 min 26 sec
Remove/Install battery now !
  ==== [3/15/2010 6:56:25 PM] ====
module  v3.10
mode: 1
19200 autodetect
CPU: MT6225
high speed boot On
status: FF
Finished, time used: 2 min 16 sec
 ==== [3/15/2010 6:59:56 PM] ====
module  v3.10
mode: 2
19200 autodetect
CPU: MT6225
high speed boot On
status: FF
warning: wrong packet cs
Finished, time used: 1 min 37 sec
==== [3/15/2010 7:20:38 PM] ====
module  v3.10
mode: 4
19200 autodetect
CPU: MT6225
high speed boot On
status: FF
Finished, time used: 23 sec
Old 03-20-2010, 08:37   #8 (permalink)
Member: 468656
Thanks Meter: 76
MODE-AUTO
module  v3.10
How to calibrate touchscreen:
- for this operation you need to have full flash backup from phone
- if you have full flash backup already press "Yes", select full flash file and follow instructions given by software
- if you do not have full flash backup yet press "No", read full flash and repeat calibration procedure
Do you have full flash backup ?
Loading file v.02...
M3829_PCB01_GPRS_MT6225_S00.TV_V1_1_3__ffs_20100315-191858.B0E.bin loaded
error: can't detect ffs/eeprom structure id
Finished, time used: 8 sec
Old 03-20-2010, 10:39   #9 (permalink)
Member: 148515
hello!
you must load FULL flash backup, not FFS (eeprom)
make "read full flash" operation on speed 921600 and repeat calibration-auto with this backup
Old 03-21-2010, 08:39   #10 (permalink)
Member: 468656
Thanks Meter: 76
hello!
 ==== [3/21/2010 2:11:19 PM] ====
module  v3.11
Device: Autodetect 6205-6227 NOR
Action: read flash
====>  Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot On
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====>  Initialize ...
flash: 98004900000002:18E59F00000000
flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb
otp offset: 00FF0000
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====>  Set baud ...
921600
Set baud Done
====>  Initialize bootcode ...
Initialize bootcode Done
====>  Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: 2nd [enhanced] generation
TCL-ID is absent
startup code area #1 is Ok
startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\id.1799331D.[M3829_PCB01_GPRS_MT6225_S00.TV_V1_1_3.BIN_B8B56B2D].rpl
rom info detection finished
New firmware detected (v.3.11, database date: unknown):
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to RapidShare: 1-CLICK Web hosting - Easy Filehosting or 4shared.com - free file sharing and storage
- include in your e-mail full text from phone back label (phone name etc.)
device-id: 1799331D
rom info ver: 04
sw version: M3829_PCB01_GPRS_MT6225_S00.TV_V1_1_3.BIN
project-id: TV_V1.1.3, 2D6BB5B8
code offset: 00000000
ffs offset/size [01]: 00E00000/00200000
TCL-ID is absent
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
standard ffs/eeprom offset confirmed: 00E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====>  Check firmware content ...
Check firmware content Done
====>  Backup required data ...
reading: M3829_PCB01_GPRS_MT6225_S00.TV_V1_1_3__fullflash...
file saved: C:\Documents and Settings\phuong 311\Desktop\M3829_PCB01_GPRS_MT6225_S00.TV_V1_1_3__fullflash_20100321-142241.B0M.bin
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\M3829_PCB01_GPRS_MT6225_S00.TV_V1_1_3__system_log_1799331D_B8B56B2D_20100321-142334.B0X.bin
Finished, time used: 11 min 58 sec
And Fix calibration but not Done!
==== [3/21/2010 2:23:52 PM] ====
module  v3.11
M3829_PCB01_GPRS_MT6225_S00.TV_V1_1_3__fullflash_20100321-142241.B0M.bin loaded
ffs/eeprom record offset detected
ffs/eeprom record size detected
19200 autodetect
CPU: MT6225
high speed boot On
status: FF
Finished, time used: 1 min 18 sec
Old 03-21-2010, 15:39   #11 (permalink)
Member: 1043909
Thanks Meter: 60,921
@duyphuong3000
1. what cable you have used ?
2. If you use PinFinder: are you able to Power-On phone completely when you use PinFinder as a phone power source ?
Infinity can't unlock MXNEC N9 chip Infineon 7880, Infinity team help me ! coolderheart Infinity-Box 1 11-15-2009 06:12
who can help me with this flash file .::Naseer Al-islam::. Chinese Models & Cloned Phones 0 09-13-2009 10:36
plz infinity team help me in dide n99i 2 serial after flash fone KhOliO Infinity-Box 4 07-08-2008 00:03
plz infinity team help me in dide n99i 2 serial after flash fone KhOliO Infinity-Box 2 07-06-2008 20:40
who can help me with k610i flash file? jawad8305 FuriousGold 2 09-06-2007 18:16
Page generated in 0.23904 seconds with 9 queries
