05-27-2008, 20:54 | #46 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | |
05-28-2008, 10:55 | #47 (permalink) |
Freak Poster Join Date: Dec 1999 Location: MKD
Member: 748 Status: Offline Thanks Meter: 9 | Need Help!! heloo to infinity team last week i have recive my pinfinder but i have trouble with adapter activation and conection was ok but for example i try to use L18a cable and option auto finder something starnge is happening when rx pin is on pos 2,3 and 6 and 7 there is no power supply i have try al posible option but same any idea ??? again example if i put that i use L18 a cable for cect t689 cpu 1 rx is 7 tx is 9 i have no power supply i have try all posible known ways to me but same any idea or solution is welcome p.s. i have try also without cables same |
05-28-2008, 15:17 | #52 (permalink) | |
Please, see page 19: Automatic pinout detection: Troubleshooting I hope you can solve at least 99% of possible problems (especially with 8, 12, 14, 15 pins cables) with this instruction. | |
05-28-2008, 15:58 | #53 (permalink) |
Member: 748 Status: Offline Thanks Meter: 9 | i think you misunderstand me i,m owner of 3 infinity boxes with 3 adapters other 2 works ok this one not for sure problem is software of pin finder box because no matter what type of cable is chosen if rx conection is on 2,3,6,7,13,16,17,19,21,22,23 line command power on is not working and beacuse of that most of phones can be autodetected red power diode for phone powering is not working this is software problem because on other adapter red light is when detecting blinking on this one is start blinking but when one of mentioned pins is on rx red diode is down so no power supply i have measured all voltages and are corect i have a lot of friends with working pinfinders but i have also with non working with same problem i,m not writig this to make some bad news i,m aksing from team to release if posible sowtware repair or diagnose for pin finder and then online update |
05-28-2008, 16:17 | #55 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @roki Could you, please, use commas (",") and dots (".") in your future messages. Thank you in advance ! Please, check UserManual page 19. You will see pictures with small modifications that should be done for some cables. |
05-28-2008, 16:23 | #56 (permalink) |
Member: 748 Status: Offline Thanks Meter: 9 | Sorry for not using signs. i habe read user manual at least 100 times,and if you dont notice i have 3 of them only one is not working. With described problem i,m facing and that is fact cables are fine because i have test them. |
05-29-2008, 05:12 | #58 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | You need to select AD CPU for Pantech. Also pre-defined pinouts can be downloaded here: http:///vbb/showpo...93&postcount=2 |
How to use SpiderMan for Sagem, LG, SE, Motorola, Pantech, Fly, O2, ZTE etc. | hamada33r | SpiderMan | 13 | 11-16-2008 16:04 |
how to use pinfinder for china | rajendrakumar | Infinity-Box | 1 | 10-02-2008 21:23 |
UNLOCK MY150x: How to use PinFinder with Sagem and other models | alamgarh | Infinity-Box | 22 | 07-13-2008 13:57 |
How to use pinfinder with Pantech PG-C3B | -luigi- | Infinity-Box | 5 | 05-23-2008 02:49 |
How to use patch for DB2020 SE phones? | vetas | Universalbox | 6 | 03-25-2008 14:28 |
