07-06-2017, 23:15 | #1 (permalink) |
Freak Poster Join Date: Jul 2008 Location: Belize
Member: 809261 Status: Offline Sonork: 100.61830 Thanks Meter: 100 | how to write back nvm? 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 9 ] Sync... Inital Boot Ok! BB_CPU_PID : 6575 BB_CPU_NME : [MediaTek] MT6575|MT6577_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0xE201 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.3.2 on BBID : 0x84 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0088 , [TOSHIBA] TYBC0A111236KC10 [NAND] : FLASH_DIE : 00AD 00BC 0090 0055 0056 0000 0000 [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 0800/0040/01 DEV RID : 0x6C2613C27DD3C4B35FA62EDAB5EEE2FC INT RAM : 0x00020000 EXT RAM : 0x10000000 [256 MiB] BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Not supported FlashType yet for this operation !!! Done! Elapsed: 00:00:13 Reconnect Power/Cable! |
