07-22-2009, 16:42 | #1 (permalink) |
No Life Poster Join Date: Jul 2006 Location: INDIA,TAMILNADU,PATTUKKOTTAI
Member: 304090 Status: Offline Thanks Meter: 210 | how to write imei #2 in double sim mono cpu phone? i tried all method to write second imei ...but software only changes the first imei......second imei is always 0000000000000.... what to do? |
07-22-2009, 16:58 | #2 (permalink) |
No Life Poster Join Date: Oct 2005 Location: P A K I S T A N Age: 16
Member: 190344 Status: Offline Thanks Meter: 280 | Infinity-Box "Chinese Miracle": How to repair Imei There are several Imei repair methods, if one method failed you need to use other method: === Method-1: use it as a first step to repair Imei cable: use Rx/Tx/Gnd cable or original USB cable from phone package 1. set Imei method to "mode-1" 2. press "Write" button 3. in case of connection problems try to enter in phone service menu and enable COM port according to the next instruction: How to enable COM port for Imei repair procedure: 1. Power-On phone 2. Enter one of the next codes (try one by one): *#110*01# *#3646633# *#3338913# *#42253646633# *#0966# 3. enable COM port: -> Device -> Set UART -> PS -> UART1/115200 4. be sure that phone not in "sleep" mode, LCD light must be On. If LCD is black, shortly press phone "Power" button 5. write Imei === Method-2: use it as a second step to repair Imei cable: use Rx/Tx/Gnd cable 1. set Imei method to "mode-2" 2. press "Write" button === Method-3: use it as last step, also good method for 2nd CPU Imei for Dual-SIM phones cable: use Rx/Tx/Gnd cable 1. set Imei method to "mode-3" 2. press "Write" button for master imei: -select mode-1 -imei#1 for dual sim/mono-cpu -write new imei for slave imei: -select mode-3 -imei#2 for dual sim/mono-cpu -write new imei |
how to write imei in spread cpu | rohit50 | SpiderMan | 3 | 06-08-2010 14:25 |
how to write imei in spred cpu with infinity | rohit50 | Infinity-Box | 1 | 12-02-2009 15:35 |
double sim mono cpu phone help | Tajammul | CPF-BOX Ⅱ | 3 | 11-15-2009 16:40 |
How to write IMEI-0000000000 in lg-kp105 | kabiyal | VygisToolbox | 0 | 10-25-2009 07:34 |
