How to write imei of lg b2060? Big problem! HOW TO WRITE IMEI OF LG B2060? I HAVE FULL FLASH THE SET. WRITE GOOD EEPROM FILE. ALSO WRITE IMEI IN SERVICE MENU BUT STILL THE IMEI IS 0000? NEED HELP FROM INFINITY TEAM. COM6 [VCP0] selected module v1.39 Device: LG-B2060 Checking data, wait... advanced flash detection enabled Action: imei repair Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 01227E22212200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud ... 115200 Set baud Done Check flash ... current eeprom imei: 3533730100***** current otp imei: 3533730100***** file saved: C:\Program Files\InfinityBox\LGA\eeprom_353373010001307_LG-B2060_20100321-102640.B1E.bin ........ version: XXX-XXV10l91B2060P40 Check flash Done Check space ... current eeprom imei: 3533730100***** Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... Write Done Finished, time used: 31 sec Remove/Install battery now ! |
why nobody helping me out in this matter? is it not possible to write imei of lg b2060 with infinity? should i need other tool (et) for this job? |
INFINITY BOX IS GREAT. SO THE EXPECTATION IS HIGH. |
Lg b2060 imei solution Bro, Flase This Attached flash file. Set will be ok. I Tested Many Handsets. "KG110P40FL-91-V10d_404-XX_OCT-16-2006_full_code_alchemy_352691010123453[1].B1M.bin" |
problem solved. |
