Old 03-10-2016, 09:56   #1 (permalink)
Member: 2195211
Thanks Meter: 4,294,967,295
how to write phone contact that read with cm2
Chinese Miracle II [MTK module] v 1.42
Operation : Read UserData [ v1.42 ]
PhoneBook : Enabled
Wait for phone...
Phone found! [ 5 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BB_CPU_NME : [MediaTek] MT6582_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
BootLdrSS : NORMAL with SPRELOADER
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x87
NAND Flash : NOT INSTALLED
eMMC Flash : 90014A4834473164048603A21DD431D3
Initialize Memory ...
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , d1G4
[eMMC] : FLASH_CID : 90014A4834473164048603A21DD431D3
[eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000
[eMMC] : FLASH_LEN : 0x00000000E7000000
[eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB]
DEV RID : AB92A7BBE47D0666F2AAD2F6751A04C7
INT RAM : 0x00020000
EXT RAM : 0x40000000
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Processiung : PhoneBook extraction
Step #1
Step #2
Read Ok, PhoneBook records extracted : 1699
TXT Saved to : F:\MT6582_PhoneBook.txt
Write : 1699
CSV Saved to : F:\MT6582_PhoneBook.csv
VCF Saved to : F:\MT6582_PhoneBook.vcf
Done!
Elapsed: 00:00:20
Reconnect Power/Cable!
Old 03-10-2016, 10:34   #2 (permalink)
syed tuqeer's Avatar
Member: 654997
Sonork: 1613804(Don't Spam Plz)
Thanks Meter: 3,924
put saved file in Memory Card
and import contact via MMC
Old 03-10-2016, 10:54   #3 (permalink)
Member: 2195211
in whcih format? file saved in 3 format
Old 03-10-2016, 15:34   #4 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 14,688
Why not google about it?
CM2 made STANDARD files, which can be uses whatewer you want. Just google. All explained even with pictures how move hand by X and Y axis to choose/press need button.
Old 03-10-2016, 16:57   #5 (permalink)
Member: 2195211
sir if u simply answer the problem may be it will be more easy to do..
Old 03-10-2016, 18:38   #6 (permalink)
masterRt1994's Avatar
Member: 2105681
Sonork: Stoped Using...
Thanks Meter: 899
Copy .vcf to phone storage and import contacts from phone storage....
br
masterRt1994
Old 03-11-2016, 05:52   #7 (permalink)
Member: 2195211
thank u master g and Mr.Jaydi
Page generated in 0.25705 seconds with 7 queries
