06-11-2019, 09:04 | #1 (permalink) |
Freak Poster Join Date: Jan 2011 Location: india
Member: 1492933 Status: Offline Sonork: 100.1646938 Thanks Meter: 56 | howo to network unlock optus x smart please help Operation : Identify [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM218) MODE : BOOTROM PORT : 218 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+ARB BROM : BOOTROM MODE : 0_base : BASE_v1712 | Manual : Enabled BROM : ARB : ACTIVE : LOG : F0: 102B 0000 F3: 0000 0000 V0: 0000 0000 [0001] BROM : SOCID : 7C650CB6F91B46638B4E3F3F562E4FC8F8A2659DB99C4A58BD CBA726447851F4 AGENT : Look for suitable BootChain in DA ... AGENT : Alcatel-OT-4034_5010_5012_5015_5016_5022_5023_5025_5116_DA_SW SEC.bin AGENT : Selected AGENT doesn't have required configuration! Check and select CORRECT SETTINGS for your device! Reconnect Power/Cable! 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM218) MODE : BOOTROM PORT : 218 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+ARB BROM : BOOTROM MODE : 0_base : BASE_v1712 | Manual : Disabled BROM : ARB : ACTIVE : LOG : F0: 102B 0000 F3: 0000 0000 V0: 0000 0000 [0001] BROM : SOCID : 7C650CB6F91B46638B4E3F3F562E4FC8F8A2659DB99C4A58BD CBA726447851F4 AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Selected AGENT doesn't have required configuration! Check and select CORRECT SETTINGS for your device! Reconnect Power/Cable! 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : PreLoader USB VCOM Port (COM114) MODE : PRELOADER PORT PORT : 114 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000007 BROM : SecMode : SBC+SLA+SDA BROM : PRELOADER PORT MODE : 0_base : BASE_v1712 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Selected AGENT doesn't have required configuration! Check and select CORRECT SETTINGS for your device! Reconnect Power/Cable! network unlock possible ? |
06-11-2019, 09:38 | #3 (permalink) |
Member: 1492933 Status: Offline Sonork: 100.1646938 Thanks Meter: 56 | Operation : Identify [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : PreLoader USB VCOM Port (COM114) MODE : PRELOADER PORT PORT : 114 Waiting BOOT ack ... PRELOADER : ACK confirm FAIL! BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000007 BROM : SecMode : SBC+SLA+SDA BROM : PRELOADER PORT MODE : 0_base : BASE_v1912 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6739 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00007024 : DA SEND ERROR! ERROR : SECURE BOOT : SELECTED DA NOT SUPPORTED IN CURRENT DEVICE STATE! INFO : PRELOADER Level : CORRECT DA required : PL/PL_CRYPTO/SWSEC! Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM218) MODE : BOOTROM PORT : 218 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+ARB BROM : BOOTROM MODE : 0_base : BASE_v1912 | Manual : Disabled BROM : ARB : ACTIVE : LOG : F0: 102B 0000 F3: 0000 0000 V0: 0000 0000 [0001] BROM : SOCID : 7C650CB6F91B46638B4E3F3F562E4FC8F8A2659DB99C4A58BD CBA726447851F4 AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6739 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00000001 : DA SEND ERROR! ERROR : BROM : DL MODE ERROR INFO : BROM Level : SLA AUTH or AUTH required! Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! not working |
