06-29-2017, 08:55 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: pakistan
Member: 270869 Status: Offline Sonork: 100.1600061 Thanks Meter: 429 | Htc 310 dual sim Card found : S/N : , v0136 Chinese Miracle II [MTK module] v 1.58 Scatter Load Ok , BaseBand : MT6582 , Project : lx84 , Storage : EMMC Files found : 14 , Set to Flash : 13 Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 55 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473164040503A2756EA1CF Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164040503A2756EA1CF [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0x4D0D1D92F7B150FD780BD38FE34F26EB INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6582 , Project : lx84 , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : Unknown (not supported or without battery) BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000C00000-0x0000000000100000 Erase : 0x0000000002900000-0x00000000E3D00000 Flash Pre-Erase Done, time used : 00:00:01 SecCfg Passed , 179A BMT remark passed Sending Preloader ... Use : preloader_lx84.bin Preloader Sent , Init passed SecCfg Passed , 179A PartCount : FFFFFFFF PartErr : Not initialized , will update PMT now ... Repartition Done! Use FLS Mode Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : EBR2 Image Flash Ok Flash now : BLINKFEED Image Flash Ok Flash now : FLEX Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:06:36 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : EBR2 Verify Passed : BLINKFEED Verify Passed : FLEX Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Data Verify Done, time used : 00:00:05 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:07:11 Reconnect Power/Cable! |
06-29-2017, 10:18 | #3 (permalink) |
Member: 270869 Status: Offline Sonork: 100.1600061 Thanks Meter: 429 | ============ Memory Detection Report =========== Internal RAM: Size = 0x00020000 (128KB) External RAM: Type = DRAM Size = 0x40000000 (1024MB/8192Mb) NAND Flash: ERROR: NAND Flash was not detected! EMMC: EMMC_PART_BOOT1 Size = 0x0000000000400000(4MB) EMMC_PART_BOOT2 Size = 0x0000000000400000(4MB) EMMC_PART_RPMB Size = 0x0000000000400000(4MB) EMMC_PART_GP1 Size = 0x0000000000000000(0MB) EMMC_PART_GP2 Size = 0x0000000000000000(0MB) EMMC_PART_GP3 Size = 0x0000000000000000(0MB) EMMC_PART_GP4 Size = 0x0000000000000000(0MB) EMMC_PART_USER Size = 0x00000000e9000000(3728MB) ============ EMMC Test ============ |
06-29-2017, 17:24 | #5 (permalink) |
Member: 270869 Status: Offline Sonork: 100.1600061 Thanks Meter: 429 | Operation : HW Test [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 55 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473164040503A2756EA1CF Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164040503A2756EA1CF [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0x4D0D1D92F7B150FD780BD38FE34F26EB INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Initial info read error! Erased or damaged FlashIC?! Force eMMC test by user request [Processing] FlashMemory Read-Write test [eMMC] : [HYNIX] , d1G4 , 0xE9000000 , 3728 MiB [eMMC] : CID : 90014A4834473164040503A2756EA1CF [eMMC] : MODE : SQ-WR [FAILED : READONLY] : eMMC state seems as READ-ONLY !!!! Operation Failed Elapsed: 00:01:19 Reconnect Power/Cable! |
