Old 08-21-2017, 15:43   #1 (permalink)
Member: 2298369
Thanks Meter: 440
Htc 516 dead handset alive some tips
I READ FIRMWARE HTC 516 WITH CM2 QUALCOMM, YESTERDAY I GOT 3 HTC 516 ONE DEAD AND TWO HANG ON LOGO, I TRY WITH MEMORY CARD BUT BOTH HANG ON LOGO HANDSET NOT BOOT WITH MEMORY CARD SO SOFTWARE DID NOT COMPLETE , THEN I TRY TO WRITE FIRMWARE(WHICH I READED WITH CM2) ONE HANG ON LOGO, AND ONE DEAD SET BOTH NOT DONE AND FIRMWARE STOP ON 37 PERCENT. ONE STRANGE THING I NOTED WHEN I FORMAT WITH CM2 QUALCOMM MODULE, IT SHOW FORMAT FAIL. LASTLY WHEN LAST ONE I TRY FORMAT FIRST BEFORE FLASH , IT SHOW FORMAT OK, THEN I FLASH WITH CM2 THAT READED FIRMWARE HANDSET IS OK, LOG IS HERE-
Card found : 94FBD840 , v0136
Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.15
Loading firmware ...
Created by Infinity-Box (c) Chinese Miracle II (c) 2017
Device Brand : htc
Device Manufact.: HTC
Device CPU : MSM8610
Device IntName : HTC_Europe
Device Version : 4.3
CU_SWVer : HTC
Device Compile : 11/28/2014 9:02:47 AM
Device ExtInfo : HTC Desire 516 dual sim
Load Ok!
Operation : Reset Settings [ v1.15 ]
2. PRESS and HOLD BOTH VOLUME KEYS!
3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
BB_IDC_CPU : SnapDragon 2x/4x|00 [MSM8x12]
ID_BLOCK_S : 04CE72BF
ID_BLOCK_I : 008140E1
ID_BLOCK_L : C43C56A00F9B80837CD1232CEBB63E0E
ID_BLOCK_L : 85F846E9EA75E56E635207FCF6393714
Pickup loader from firmware package
Loader Sent! Initializing ...
Running FireHose on BBID : MSM8x10 , FLASH : eMMC , mVER : 1
ExtInfo : 0x0000C000/0000C000/00001000/00001000/00000000
Boot Ok!
Format USER ...
Format CACHE ...
Format Ok!
Done!
Elapsed: 00:00:33
Reconnect Power/Cable!
Operation : Flash [ v1.15 ]
ForceFlashing : Disabled
Verify FW package ...
Verification passed!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
Boot Ok!
Flash Chain : 24
Flashing now
Flashing : gpt_main0.bin
Flashing : sbl1.mbn
Flashing : deploy.mbn
Flashing : rpm.mbn
Flashing : tz.mbn
Flashing : emmc_appsboot.mbn
Flashing : NON-HLOS.bin
Flashing : boot.img
Flashing : system.img
Flashing : persist.img
Flashing : cache.img
Flashing : recovery.img
Flashing : misc.img
Flashing : splash.img
Flashing : usbdisk.img
Flashing : userdata.img
Flashing : gpt_backup0.bin
Wipe data ...
BootConfig set to 0x00
Flashing done!
Done!
Elapsed: 00:04:54
SO FIRST DO FORMAT WITH INFINITY CM2 MODULE, IF FORMAT OK THEN U CAN WRITE FIRMWARE AND HOPE SET WILL BE OK EITHER DEAD OR HANG ON LOGO BUT IF FORMAT FAILED MEANS EMCC GONE NO WAY.
The Following 2 Users Say Thank You to galaxycompue For This Useful Post:
Old 08-21-2017, 15:44   #2 (permalink)
Member: 2298369
Thanks Meter: 440
This works perfectly on that handsets which not boot with memory card.
The Following User Says Thank You to galaxycompue For This Useful Post:
Old 11-08-2017, 13:24   #3 (permalink)
Member: 277018
Hi,
Can you share firmware??
Old 11-08-2017, 15:40   #4 (permalink)
Member: 2298369
Thanks Meter: 440
HERE IS YOUR TESTED FIRMWARE LINK-
https://www.4shared.com/archive/CaTk...DR_v43__H.html
Page generated in 0.16474 seconds with 8 queries
