-   Infinity-Box (http://forum.gsmhosting.com/vbb/f296/)
-   -   htc 526G dead after fix unknown baseband (http://forum.gsmhosting.com/vbb/f296/htc-526g-dead-after-fix-unknown-baseband-2072392/)
Ehab_se 03-31-2016 16:33
i have same problem
original htc 526 mt6582
came to me with unknown baseband and invailed imies
first i readed backup for firmware and nvram
then i flashed it with anther tested firmware and tested nvram readed from working phone but same problem
i try ti fix unknown base-band from extra tap in infinity mtk module but after repair phone dead and only vibrate when i try to switch it on
i try to flash its backup firmware and nvram but same problem
Operation : Fix Unknown BaseBand [ v1.41 ]
User accepted FixBB operation!
Wait for phone...
Phone found! [ 3389 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BB_CPU_NME : [MediaTek] MT6582_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
BootLdrSS : NORMAL with SPRELOADER
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x87
NAND Flash : NOT INSTALLED
eMMC Flash : 150100513732534D42002D0F9BCA6251
Initialize Memory ...
DRAM configured from ScatFW!
DRAM initialize passed!
DRAM size : 0x40000000
eMMC FlashIC initialized
[eMMC] : FLASH_INF : [SAMSUNG] , BMS27
[eMMC] : FLASH_CID : 150100513732534D42002D0F9BCA6251
[eMMC] : FLASH_LEN : 0x00000001D2000000
[eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB]
DEV RID : D745A4A9692130D0C47DB1F6BCF7E787
INT RAM : 0x00020000
EXT RAM : 0x40000000
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Step #1
Step #1 ... Ok
Step #2
Step #2 ... Ok
Reset Done!
Done!
Elapsed: 00:00:18
Reconnect Power/Cable!
how i can retrieve this phone back
Ehab_se 03-31-2016 16:35
phone info
[AP] : Initial info read Ok!
Brand : htc
ProdName : v02_htc_europe
ProdModel : HTC Desire 526G dual sim
Device : htc_v02_dug
AndroidVer: 4.4.2
MTKxCPU : MT6582
MTKxPRJ : 1.02.401.8
SECURITY :
IMEI_SW [1] : 358233064930436
IMEI_SW [2] : 358233064950632
BTMAC Addr : 90E7C4B2B71C
WiFi MAC : 90E7C4A7B310
MODEM :
BaseBand : MT6582_S00_MOLY_WR8_W1315_MD_WG_MP_V62_1_wg_n
EXTRA :
LCD [0] : ili9807_qhd_dsi_vdo
LCD [1] : hx8389c_qhd_dsi_vdo_tcl
LCD [2] : hx8389b_qhd_dsi_vdo_tm
LCD [3] : ili9807_qhd_dsi_vdo_bld
LCD [4] : dummy_lcm
LCD Res : 960x540
TOUCH [0] : ft6436l
TOUCH [1] : msg2142
CAM [0] : s5k4h5yx_mipi_raw
CAM [1] : ov8858_mipi_raw
CAM [2] : gc2355_mipi_raw
CAM [3] : ov2680_mipi_raw
MODEM : mt6582kk_hspa_18_2015_7_31
LOCALE : en_US af_ZA in_ID ms_MY ca_ES cs_CZ da_DK de_DE de_AT de_CH de_LI en_GB en_AU en_CA en_IE en_IN en_NZ en_SG en_ZA es_ES es_US tl_PH fr_FR fr_BE fr_CA fr_CH hr_HR zu_ZA it_IT it_CH sw_TZ lv_LV lt_LT hu_HU nl_NL nl_BE nb_NO pl_PL pt_BR pt_PT ro_RO rm_CH sk_SK sl_SI fi_FI sv_SE vi_VN tr_TR el_GR bg_BG ru_RU sr_RS uk_UA iw_IL ar_EG ar_IL fa_IR am_ET hi_IN th_TH my_MM km_KH ko_KR zh_CN zh_TW zh_HK ja_JP ar_SA hb_IL he_IL et_EE hy_AM kk_KZ en_MY
Done!
Elapsed: 00:00:16
JayDi 03-31-2016 17:08
Why make thousand posts with same problem again and again?
http://forum.gsmhosting.com/vbb/f296...rased-2033849/
wahidulislam39 11-04-2016 10:26
Htc 526g dual sim mt6582 dead recover ok tasted by wahid
FIRST DOWNLOAD TASTED FIRMWARE HERE http://easy-firmware.com/index.php?a...tegory&id=2675DOWNLOAD CONVERT FLASHTOOL HERE http://www.mediafire.com/file/tpjg4jtdf7sj40t/SP_Flash_Tool_exe_Windows_v5.1516.00.zip STEP 1. OPEN FLASHTOOL SELECT FIRMWARE 2. SELECT FORMAT+DOWNLOAD 3. CLICK DOWNLOAD AND PHONE CONNECT 4. YOU SEE FORMAT OK BUT WHEN DOWNLOAD SHOW AN ERROR 5. DON'T WORRY NOW WORK START 6. DOWNLOAD SP_Flash_Tool_v5.1620_Win any link 7. open SP_Flash_Tool_v5.1620_Win 8. select firmware and untick preloader 9. then download 10. now your phone is alive 11. enjoy
Page generated in 0.15676 seconds with 5 queries
