12-25-2015, 05:04 | #1 (permalink) |
Freak Poster Join Date: Dec 2005 Location: KOLKATA INDIA
Member: 207734 Status: Offline Sonork: 100.1612198 Thanks Meter: 141 | HTC 816G smart av crc error 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 45 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6592 BB_CPU_HW : CA00 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6592_S00 Processing BROM stage BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 15010051385853414206DF36F268C1D3 DA Stat : v4.2 on BBID : 0x8A DRAM not initialized , configure DRAM Settings DRAM EmiReq Ok , 0x00BC DRAM Init Ok , 0x08000000 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BASX8 [eMMC] : FLASH_CID : 15010051385853414206DF36F268C1D3 [eMMC] : FLASH_EXT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB INT RAM : 0x00020000 EXT RAM : 0x08000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Info read not done Erased phone or unsupported FlashIc? Done! Elapsed: 00:00:11 Reconnect Power/Cable! Operation : Check / Read Info [ v1.40 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 10 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6592 BB_CPU_HW : CA00 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6592_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 15010051385853414206DF36F268C1D3 DA Stat : v4.2 on BBID : 0x8A DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BASX8 [eMMC] : FLASH_CID : 15010051385853414206DF36F268C1D3 [eMMC] : FLASH_EXT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : htc ProdName : a5mgp_dug_htc_asia_wwe ProdModel : HTC Desire 816G dual sim Device : htc_a5mgp_dug AndroidVer: 4.4.2 MTKxCPU : MT6592 MTKxPRJ : ALPS.KK1.MP1.V2.10 MODEM : BaseBand : MT6592_S00_MOLY_WR8_W1315_MD_WG_MP_V34_P21_1_wg_n EXTRA : LCD [0] : hx8394d_hd720_dsi_vdo_truly LCD [1] : hx8394d_hd720_dsi_vdo_yushun LCD Res : 1280x720 TOUCH [0] : hx8526_w5800 CAM [0] : ov13850_mipi_raw CAM [1] : s5k3l2xx_mipi_raw CAM [2] : s5k5e2ya_mipi_raw CAM [3] : hi551_mipi_raw MODEM : lcsh92_cwet_kk_hspa_gps_coclk LOCALE : en_IN en_US en_GB zh_TW zh_CN zh_HK in_ID th_TH vi_VN de_DE es_ES fr_FR it_IT nl_NL pt_PT sv_SE tr_TR ru_RU hi_IN ms_MY Done! Elapsed: 00:00:13 Reconnect Power/Cable! Operation : Scan APPs [DDirect] [ v1.40 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 10 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6592 BB_CPU_HW : CA00 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6592_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 15010051385853414206DF36F268C1D3 DA Stat : v4.2 on BBID : 0x8A DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BASX8 [eMMC] : FLASH_CID : 15010051385853414206DF36F268C1D3 [eMMC] : FLASH_EXT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! DDirect : Init Ok! Scanning FileSystem now , please wait #115 : Data CRC Error : BFF4 , BFEC #0 : Data CRC Error : B381 , 0000 #0 : Data CRC Error : B381 , 0000 #0 : Data CRC Error : B381 , 0000 #0 : Data CRC Error : B381 , 0000 #0 : Data CRC Error : B381 , 0000 Collect and verify data according Dictionary Collect done : 0x000B [DDCleaner Info] : Files to remove : 11 [DDCleaner Info] : Additional garbage detected : 0 Removing files ... #128 : Data CRC Error : AC5E , ACBF [DDCleaner] : Error clear item #16 [DDCleaner] : Error clear item #18 [DDCleaner] : Error clear item #20 [DDCleaner] : Error clear item #23 [DDCleaner] : Error clear item #26 [DDCleaner] : Error clear item #30 [DDCleaner] : Error clear item #31 [DDCleaner] : Error clear item #32 [DDCleaner] : Removed 3 Finished with errors! Check connection and battery charge! Done! Elapsed: 00:00:28 Reconnect Power/Cable! |
