07-21-2015, 07:50 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: In My Limit
Member: 610502 Status: Offline Sonork: 100.1618428 Thanks Meter: 161 | HTC DESIRE 310 Dual Sim 6582 Not Supported.... I am Posting the Logs: LOGS: hinese Miracle II [MTK module] v 1.24 Start at : [7/21/2015 / 10:30:45 AM] Operation : Check / Read Info [ v1.24 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 27 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending Error : DA init Failed! Error code : 0x2 Boot Error! Operation Failed Elapsed: 00:00:07 Reconnect Power/Cable! Finish at : [7/21/2015 / 10:30:53 AM] Start at : [7/21/2015 / 10:31:05 AM] Operation : Check / Read Info [ v1.24 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 27 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending Error : DA init Failed! Error code : 0x2 Boot Error! Operation Failed Elapsed: 00:00:07 Reconnect Power/Cable! Finish at : [7/21/2015 / 10:31:12 AM] Start at : [7/21/2015 / 10:31:22 AM] Operation : Read Flash [ v1.24 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 27 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending Error : DA init Failed! Error code : 0x2 Boot Error! Operation Failed Elapsed: 00:00:08 Reconnect Power/Cable! Finish at : [7/21/2015 / 10:31:30 AM] |
07-21-2015, 12:13 | #3 (permalink) | |
Member: 610502 Status: Offline Sonork: 100.1618428 Thanks Meter: 161 | Thanks jayDI Quote:
Now this time i do not have unit in hands otherwise i would do as you have instructed. B/R Sheraz.... | |
07-23-2015, 04:51 | #4 (permalink) |
Registered User Join Date: Feb 2012 Location: swimming
Member: 1725884 Status: Offline Sonork: swimming Thanks Meter: 293 | htc mtk supported in cm2 from a while ,just use CM2 have "SP : Model Select" option in settings ( first tab ) and you will find htc models, i test it and i read before factory files like htc 816g,htc 616.... MT6592__htc__HTC Desire 616 dual sim__htc_v3_dug__4.2.2__SW_G98518A3_V019_M10_HTC_V 3DUG_EURO_MP.7z MT6592__htc__HTC Desire 816G dual sim__htc_a5mgp_dug__4.4.2__ALPS.KK1.MP1.V2.10.7z |
