11-28-2015, 09:29 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: INDIA Age: 38
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | HTC Desire 310 dual sim D310w NOT CONNECT PROPERLY TO CM2:- SEEMS THE IT HAD BOOT LOADER LOCK PHONE CAME TO ME IN SECURITY INVALID ITS MTK 6582 HOW TO UNLOCK BOOT LOADER IN MTK PHONES READ INFO LOGS Code: Chinese Miracle II [MTK module] v 1.37 Operation : Check / Read Info [ v1.37 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 12 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 Error : DA init Failed! Error code : 0x2 LErr : 2001 Error! SECURE BOOT target! Check Model Settings! Boot Error! Operation Failed Elapsed: 00:00:06 Reconnect Power/Cable! Code: Operation : Read Flash [ v1.37 ] Power Off Phone , re-connect battery , Insert USB cable! Wait for phone... Phone found! [ 12 ] Sync... 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 12 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage Will use Secure DA for boot target DA Select done , sending DA Ver : MTK_AllInOne_DA_v3.3001.00.00 NAND : DA_DRAM_NOT_SUPPORT Error : DA init Failed! Error code : 0x4 LErr : 0000 Boot Error! Operation Failed Elapsed: 00:00:22 Reconnect Power/Cable! ANY WAY IT CAN BE SOLVED MORE LOGS FROM PHONE INSIDE Code: Batt Volt : 3.803 V BB Chip : MT6582 MS Board : htc_v1_dug IMEI1 : unknown IMEI2 : unknown Modem Ver : MOLY. WR8. W1315. MD. WG. MP. V1 9.P6, 2014/08/12 16:43 Bar code : unknown Build Time : tue Aug 12 17:39:44 CST 2014 Kernel Ver. : 3.4.5 (rdasmin@vBuild1LX83) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #1 SMP PREEMPT True Aug 12 17 :36:31 CST 2014 Android Ver : 4.2.2 SW Ver. : ALPS. JB5. MP. V1. 23 Custom Build Verno. : LX84 WBR sahil2000ind |
11-23-2016, 11:01 | #7 (permalink) |
No Life Poster Join Date: Nov 2015 Age: 25
Member: 2493574 Status: Offline Thanks Meter: 605 | WORLD IN A FIRST TIME OF 2016 HTW D310W 0PA2210 SUCCESSFULLY UNBRICK AND FLASHING GOT SUCCESS HERE GO ON.... |
The Following User Says Thank You to Shikhar12 For This Useful Post: |
