02-18-2016, 14:31 | #1 (permalink) |
Junior Member Join Date: Dec 2009
Member: 1177304 Status: Offline Thanks Meter: 0 | htc desire 310 not connecting Code: Operation : Check / Read Info [ v1.40 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 28 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 Error : DA init Failed! Error code : 0x2 LErr : 2001 Error! SECURE BOOT target! Check Model Settings! Boot Error! Operation Failed Elapsed: 00:00:04 Reconnect Power/Cable! |
02-18-2016, 15:05 | #3 (permalink) |
Member: 1177304 Status: Offline Thanks Meter: 0 | same in new also Code: Operation : Check / Read Info [ v1.41 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 28 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... [DA_ERROR] : SECURITY_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00:04 Reconnect Power/Cable! |
02-18-2016, 15:23 | #7 (permalink) | |
No Life Poster Join Date: Jul 2005 Location: philippine
Member: 159757 Status: Offline Thanks Meter: 461 | Quote:
The Following User Says Thank You to rico_deep For This Useful Post: |
02-18-2016, 15:36 | #10 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | It secured phone. De their concept - you can flash in them right now ONLY dump ( whole image ) or Factory FW only ( it can be found over forum as well ) , but take a note - you can't flash Factory FW in secured phones yet with CM2. That feature will come soon, as well as FW reading for them. Right now you can do all operations, mentioned in update log, except FW read and FW write. |
