01-05-2016, 10:52 | #1 (permalink) | ||
No Life Poster Join Date: May 2013 Location: In Core Of eMMC
Member: 1950912 Status: Offline Sonork: 100.1654643(Offline) Thanks Meter: 403 | HTC Desire 526G+ Preloader Status : Not active (Erased) Read Info Quote:
Preloader Status : Not active (Erased) | ||
01-05-2016, 12:55 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. You should reflash phone with good FW completely. Also, there is strange secstatus. If it original one ( by preloader name seems strange - it not belongs to original HTC ) - then you need correct FW. |
01-05-2016, 14:11 | #3 (permalink) | |
Member: 1950912 Status: Offline Sonork: 100.1654643(Offline) Thanks Meter: 403 | Quote:
03-31-2016, 12:39 | #4 (permalink) |
No Life Poster Join Date: May 2005 Age: 40
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | hi guys and JayDi.. i have the same pb and different result; Code: Operation : Check / Read Info [ v1.44 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital Boot Ok! BB_CPU_PID : 6592 BB_CPU_NME : [MediaTek] MT6592_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8A NAND Flash : NOT INSTALLED eMMC Flash : 150100513758534142019DD5D47E22F9 Initialize Memory ... DRAM configured from ScatFW! DRAM initialize passed! DRAM size : 0x40000000 eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BASX7 [eMMC] : FLASH_CID : 150100513758534142019DD5D47E22F9 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : BA3528E0950D4D18A1F773A8DE9C0D42 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Info read not done :( Erased phone or unsupported FlashIc? Done! Elapsed: 00:00:10 Reconnect Power/Cable! Code: User selected Preloader file : preloader_huaqin92_cwet_b2_kk.bin Operation : Init Preloader [ v1.44 ] Supported HW by Preloader : FlashID [0] CID : 150100513758534142 , Name : Q7XSAB , Vendor : 15 , [SAMSUNG] FlashID [1] CID : 150100513858534142 , Name : Q8XSAB , Vendor : 15 , [SAMSUNG] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital Boot Ok! BB_CPU_PID : 6592 BB_CPU_NME : [MediaTek] MT6592_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8A NAND Flash : NOT INSTALLED eMMC Flash : 150100513758534142019DD5D47E22F9 Initialize Memory ... DRAM configured from ScatFW! DRAM initialize passed! DRAM size : 0x40000000 eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BASX7 [eMMC] : FLASH_CID : 150100513758534142019DD5D47E22F9 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : BA3528E0950D4D18A1F773A8DE9C0D42 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! SecCfg Passed , 179A BL : BBID supported by BootLoader! Supported HW by Preloader : FlashID [0] CID : 150100513758534142 , Name : Q7XSAB , Vendor : 15 , [SAMSUNG] FlashID [1] CID : 150100513858534142 , Name : Q8XSAB , Vendor : 15 , [SAMSUNG] BL : Storage supported by BootLoader! Sending BootLoader ... Preloader Sent , Init passed SecCfg Passed , 179A PartTable Init Failed, Reflashing required! All Done Done! Elapsed: 00:00:10 Reconnect Power/Cable! device is dead condition and only vibrate.. dead by wrong flash... |
03-31-2016, 13:21 | #6 (permalink) | |
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | Quote:
0PL4IMG_V02_DUG_K44_SENSE53_hTC_Asia_WWE_1.02.720. 1_Radio_MOLY.WR8.W1315.MD.WG.MP.V62_release 0PL4IMG_V02_DUG_K44_SENSE53_htc_europe_1.02.401.6_ Radio_MOLY.WR8.W1315.MD.WG.MP.V62_release_4 [SCATCHECK] : Missing File : E:\GsM\HTC\RUU\Desire_526g+\0PL4IMG_V02_DUG_K44_SE NSE53_hTC_Asia_WWE_1.02.720.1_Radio_MOLY.WR8.W1315 .MD.WG.MP.V62_release\1.02.720.1_DCC\MBR [SCATCHECK] : Scatter wrong or incomplete. Use Factory or CM2MTK Scatter! and sp flash tools give error 6047 (bootloader locked) | |
03-31-2016, 15:33 | #9 (permalink) |
Junior Member Join Date: Dec 2015 Location: Libya
Member: 2497070 Status: Offline Thanks Meter: 0 | i have same problem original htc 526 mt6582 came to me with unknown baseband and invailed imies first i readed backup for firmware and nvram then i flashed it with anther tested firmware and tested nvram readed from working phone but same problem i try ti fix unknown base-band from extra tap in infinity mtk module but after repair phone dead and only vibrate when i try to switch it on i try to flash its backup firmware and nvram but same problem Operation : Fix Unknown BaseBand [ v1.41 ] User accepted FixBB operation! 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3389 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 150100513732534D42002D0F9BCA6251 Initialize Memory ... DRAM configured from ScatFW! DRAM initialize passed! DRAM size : 0x40000000 eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMS27 [eMMC] : FLASH_CID : 150100513732534D42002D0F9BCA6251 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : D745A4A9692130D0C47DB1F6BCF7E787 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Step #1 Step #1 ... Ok Step #2 Step #2 ... Ok Reset Done! Done! Elapsed: 00:00:18 Reconnect Power/Cable! how i can retrieve this phone back |
03-31-2016, 18:14 | #11 (permalink) | |
No Life Poster Join Date: Jan 2006 Age: 40
Member: 224075 Status: Offline Thanks Meter: 69 | Quote:
thank u for trying help me but i do full reset and plug phone to charger for 1 hour and try with new battry but nothing happen phone still dead when i connect phone to computer its detected and disconcted as mtk divice | |
04-02-2016, 18:21 | #13 (permalink) |
Member: 224075 Status: Offline Thanks Meter: 69 | today i get new htc 526G i read full flash from it and flashed it to my dead phone this is phone log for flash process and for phone info after flash and for format phone but still only vibrate when i try to switch it on and not pwered up Scatter Load Ok , BaseBand : MT6582 , Project : huaqin82_cwet_b2_kk , Storage : EMMC Files found : 13 , Set to Flash : 12 Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Device Brand : htc Device Model : htc_v02_dug Device CPU : MT6582 Device IntName : v02_htc_europe Device Version : 4.4.2 Device Compile : 8/7/2015 03:42:08 ã Device Project : 1.02.401.6 Device ExtInfo : HTC Desire 526G dual sim Ready to Flash! Operation : Flash [ v1.41 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3389 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 150100513732534D42002D0F9BCA6251 Initialize Memory ... DRAM configured from ScatFW! DRAM initialize passed! DRAM size : 0x40000000 eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMS27 [eMMC] : FLASH_CID : 150100513732534D42002D0F9BCA6251 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : D745A4A9692130D0C47DB1F6BCF7E787 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6582 , Project : huaqin82_cwet_b2_kk , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled Switching to HSUSB HSUSB Init Ok BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 3710 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000001400000-0x0000000000100000 Erase : 0x0000000003100000-0x00000001CE280000 Flash Pre-Erase Done, time used : 00:00:09 SecCfg Passed , 179A BMT remark not need. Will skip Sending Preloader ... Use : preloader_huaqin82_cwet_b2_kk.bin Preloader Sent , Init passed SecCfg Passed , 179A PartCount : FFFFFFFF PartErr : Not initialized , will update PMT now ... Repartition Done! Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : EBR2 Image Flash Ok Flash now : COTA Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:04:12 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : EBR2 Verify Passed : COTA Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Data Verify Done, time used : 00:00:48 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:05:27 Reconnect Power/Cable! Operation : Check / Read Info [ v1.41 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3389 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 150100513732534D42002D0F9BCA6251 Initialize Memory ... DRAM configured from ScatFW! DRAM initialize passed! DRAM size : 0x40000000 eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMS27 [eMMC] : FLASH_CID : 150100513732534D42002D0F9BCA6251 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : D745A4A9692130D0C47DB1F6BCF7E787 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : htc ProdName : v02_htc_europe ProdModel : HTC Desire 526G dual sim Device : htc_v02_dug AndroidVer: 4.4.2 MTKxCPU : MT6582 MTKxPRJ : 1.02.401.6 MODEM : BaseBand : MT6582_S00_MOLY_WR8_W1315_MD_WG_MP_V62_1_wg_n EXTRA : LCD [0] : ili9807_qhd_dsi_vdo LCD [1] : hx8389c_qhd_dsi_vdo_tcl LCD [2] : hx8389b_qhd_dsi_vdo_tm LCD [3] : ili9807_qhd_dsi_vdo_bld LCD [4] : dummy_lcm LCD Res : 960x540 TOUCH [0] : ft6436l TOUCH [1] : msg2142 CAM [0] : s5k4h5yx_mipi_raw CAM [1] : ov8858_mipi_raw CAM [2] : gc2355_mipi_raw CAM [3] : ov2680_mipi_raw MODEM : mt6582kk_hspa_18_2015_7_31 LOCALE : en_US af_ZA in_ID ms_MY ca_ES cs_CZ da_DK de_DE de_AT de_CH de_LI en_GB en_AU en_CA en_IE en_IN en_NZ en_SG en_ZA es_ES es_US tl_PH fr_FR fr_BE fr_CA fr_CH hr_HR zu_ZA it_IT it_CH sw_TZ lv_LV lt_LT hu_HU nl_NL nl_BE nb_NO pl_PL pt_BR pt_PT ro_RO rm_CH sk_SK sl_SI fi_FI sv_SE vi_VN tr_TR el_GR bg_BG ru_RU sr_RS uk_UA iw_IL ar_EG ar_IL fa_IR am_ET hi_IN th_TH my_MM km_KH ko_KR zh_CN zh_TW zh_HK ja_JP ar_SA hb_IL he_IL et_EE hy_AM kk_KZ en_MY Done! Elapsed: 00:00:09 Reconnect Power/Cable! Operation : Format FileSystem [ v1.41 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3389 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 150100513732534D42002D0F9BCA6251 Initialize Memory ... DRAM configured from ScatFW! DRAM initialize passed! DRAM size : 0x40000000 eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMS27 [eMMC] : FLASH_CID : 150100513732534D42002D0F9BCA6251 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : D745A4A9692130D0C47DB1F6BCF7E787 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:02:27 Reconnect Power/Cable! |
