Originally Posted by Ehab_se today i get new htc 526G
i read full flash from it and flashed it to my dead phone
this is phone log for flash process and for phone info after flash and for format phone
but still only vibrate when i try to switch it on and not pwered up
Scatter Load Ok , BaseBand : MT6582 , Project : huaqin82_cwet_b2_kk , Storage : EMMC
Files found : 13 , Set to Flash : 12
Created by Infinity-Box (c) Chinese Miracle II (c) 2016
Device Brand : htc
Device Model : htc_v02_dug
Device CPU : MT6582
Device IntName : v02_htc_europe
Device Version : 4.4.2
Device Compile : 8/7/2015 03:42:08 ã
Device Project : 1.02.401.6
Device ExtInfo : HTC Desire 526G dual sim
Ready to Flash! Operation : Flash [ v1.41 ]
======= Flash
Wait for phone...
Phone found! [ 3389 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BB_CPU_NME : [MediaTek] MT6582_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
BootLdrSS : NORMAL with SPRELOADER
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x87
NAND Flash : NOT INSTALLED
eMMC Flash : 150100513732534D42002D0F9BCA6251
Initialize Memory ...
DRAM configured from ScatFW!
DRAM initialize passed!
DRAM size : 0x40000000
eMMC FlashIC initialized
[eMMC] : FLASH_INF : [SAMSUNG] , BMS27
[eMMC] : FLASH_CID : 150100513732534D42002D0F9BCA6251
[eMMC] : FLASH_LEN : 0x00000001D2000000
[eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB]
DEV RID : D745A4A9692130D0C47DB1F6BCF7E787
INT RAM : 0x00020000
EXT RAM : 0x40000000
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6582 , Project : huaqin82_cwet_b2_kk , Storage : EMMC
Setting : AFF verify : Enabled
Setting : HW verify : Enabled
Switching to HSUSB
HSUSB Init Ok
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : BatteryLevel : 3710 mV
BL : BatteryLevel Ok
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000001400000-0x0000000000100000
Erase : 0x0000000003100000-0x00000001CE280000
Flash Pre-Erase Done, time used : 00:00:09
SecCfg Passed , 179A
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader_huaqin82_cwet_b2_kk.bin
Preloader Sent , Init passed
PartCount : FFFFFFFF
PartErr : Not initialized , will update PMT now ...
Repartition Done!
Processing : Flash Write
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Flash now : RECOVERY
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : EBR2
Image Flash Ok
Flash now : COTA
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Image Flash Ok
Flash Write Done, time used : 00:04:12
Processing : Verify
Verify Passed : MBR
Verify Passed : EBR1
Verify Passed : UBOOT
Verify Passed : BOOTIMG
Verify Passed : RECOVERY
Verify Passed : SEC_RO
Verify Passed : LOGO
Verify Passed : EBR2
Verify Passed : COTA
Verify Passed : ANDROID
Verify Passed : CACHE
Verify Passed : USRDATA
Data Verify Done, time used : 00:00:48
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:05:27
Reconnect Power/Cable! Operation : Check / Read Info [ v1.41 ]
Wait for phone...
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Brand : htc
ProdName : v02_htc_europe
ProdModel : HTC Desire 526G dual sim
Device : htc_v02_dug
AndroidVer: 4.4.2
MTKxCPU : MT6582
MTKxPRJ : 1.02.401.6
MODEM :
BaseBand : MT6582_S00_MOLY_WR8_W1315_MD_WG_MP_V62_1_wg_n
EXTRA :
LCD [0] : ili9807_qhd_dsi_vdo
LCD [1] : hx8389c_qhd_dsi_vdo_tcl
LCD [2] : hx8389b_qhd_dsi_vdo_tm
LCD [3] : ili9807_qhd_dsi_vdo_bld
LCD [4] : dummy_lcm
LCD Res : 960x540
TOUCH [0] : ft6436l
TOUCH [1] : msg2142
CAM [0] : s5k4h5yx_mipi_raw
CAM [1] : ov8858_mipi_raw
CAM [2] : gc2355_mipi_raw
CAM [3] : ov2680_mipi_raw
MODEM : mt6582kk_hspa_18_2015_7_31
LOCALE : en_US af_ZA in_ID ms_MY ca_ES cs_CZ da_DK de_DE de_AT de_CH de_LI en_GB en_AU en_CA en_IE en_IN en_NZ en_SG en_ZA es_ES es_US tl_PH fr_FR fr_BE fr_CA fr_CH hr_HR zu_ZA it_IT it_CH sw_TZ lv_LV lt_LT hu_HU nl_NL nl_BE nb_NO pl_PL pt_BR pt_PT ro_RO rm_CH sk_SK sl_SI fi_FI sv_SE vi_VN tr_TR el_GR bg_BG ru_RU sr_RS uk_UA iw_IL ar_EG ar_IL fa_IR am_ET hi_IN th_TH my_MM km_KH ko_KR zh_CN zh_TW zh_HK ja_JP ar_SA hb_IL he_IL et_EE hy_AM kk_KZ en_MY
Done!
Elapsed: 00:00:09
Reconnect Power/Cable! Operation : Format FileSystem [ v1.41 ]
Wait for phone...
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:02:27
Reconnect Power/Cable! |
