06-25-2015, 16:38 | #1 (permalink) |
No Life Poster Join Date: Sep 2008 Location: India
Member: 851193 Status: Offline Sonork: 100.1615313 Thanks Meter: 348 | HTC Desire 616 HTC D616h flash file needed Code: ========================================================= Chinese Miracle II [MTK module] v 1.21 Start at : [6/25/2015 / 7:24:16 PM] Operation : Check / Read Info [ v1.21 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 22 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6592 BB_CPU_HW : CA00 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6592_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473164048601A3F6535173 DA Stat : v4.2 on BBID : 0x8A DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : d1G4 [eMMC] : FLASH_CID : 90014A4834473164048601A3F6535173 [eMMC] : FLASH_LEN : 0x00000000E7000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Done! Elapsed: 00:00:19 Reconnect Power/Cable! Finish at : [6/25/2015 / 7:24:36 PM] Start at : [6/25/2015 / 7:24:42 PM] Operation : Format FileSystem [ v1.21 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 22 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6592 BB_CPU_HW : CA00 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6592_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473164048601A3F6535173 DA Stat : v4.2 on BBID : 0x8A DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : d1G4 [eMMC] : FLASH_CID : 90014A4834473164048601A3F6535173 [eMMC] : FLASH_LEN : 0x00000000E7000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Backup : not found, will read now ... FMT Mode set to : 0 Format : Cache and UserData (Full Factory Reset) Format CACHE block Format block Ok! Format UDA block Format block Ok! Done! Elapsed: 00:00:42 Reconnect Power/Cable! Finish at : [6/25/2015 / 7:25:25 PM] Start at : [6/25/2015 / 7:26:19 PM] Operation : Fix DL Errors [ v1.21 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 22 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6592 BB_CPU_HW : CA00 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6592_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473164048601A3F6535173 DA Stat : v4.2 on BBID : 0x8A DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : d1G4 [eMMC] : FLASH_CID : 90014A4834473164048601A3F6535173 [eMMC] : FLASH_LEN : 0x00000000E7000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Phone not require that operation!!! Done! Elapsed: 00:00:08 Reconnect Power/Cable! Finish at : [6/25/2015 / 7:26:28 PM] Start at : [6/25/2015 / 7:37:06 PM] Operation : Fix DL Errors [ v1.21 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 22 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6592 BB_CPU_HW : CA00 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6592_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473164048601A3F6535173 DA Stat : v4.2 on BBID : 0x8A DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : d1G4 [eMMC] : FLASH_CID : 90014A4834473164048601A3F6535173 [eMMC] : FLASH_LEN : 0x00000000E7000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Phone not require that operation!!! Done! Elapsed: 00:00:08 Reconnect Power/Cable! Finish at : [6/25/2015 / 7:37:15 PM] I did format now Iamge Download tool Error which is not solved by software . shows not needed for this cpu kindlyhelp me to alive the phone |
06-25-2015, 17:03 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. Yes, was missed MT6592. Leave phone for 2-3 days, if not find FW. After SPD release will make some fast MTK update. |
The Following 2 Users Say Thank You to JayDi For This Useful Post: |
06-25-2015, 19:27 | #3 (permalink) |
Member: 851193 Status: Offline Sonork: 100.1615313 Thanks Meter: 348 | is there any way I can write the user data back up got by cm2mtk software? which is I think in unique format and around 100 to xxx MB data and it should goes alive? also can you confirm this firmware should works? HTC Desire 616 Stock by jamesjerss |
06-25-2015, 19:44 | #5 (permalink) | |
Member: 851193 Status: Offline Sonork: 100.1615313 Thanks Meter: 348 | Quote:
I did not read NVRAM... how to write that backup written back to phone? | |
06-26-2015, 08:41 | #10 (permalink) |
Member: 851193 Status: Offline Sonork: 100.1615313 Thanks Meter: 348 | @ read nvram and write NvRam fixed error but set stuck at HTC logo will ask client to wait for 2-3 days .if get file will try to flash thank you for your kind help. |
06-26-2015, 08:48 | #11 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Yes, this trick will fix DL. Make sure you used "0" if FMT settings and format UDA+CACHE. ( as see in log - you already do that ) If set stuck - mostly that mean some system part damage. By "read FW" , not dump - you can make sure about system integrity. If some error will come - that mostly mean problem with flashparts or eMMC itself. Need good FW in that case. |
06-26-2015, 08:55 | #12 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | @kariakala I have dump for this model- http://forum.gsmhosting.com/vbb/f296...l#post10916139 And here is some info about dump- Brand : htc ProdName : htc_asia_sea_wwe ProdModel : HTC Desire 616 dual sim Device : htc_v3_dug AndroidVer: 4.2.2 MTKxCPU : MT6592 MTKxPRJ : SW_G98518A2_V008_M10_HTC_V3DUG_ASIA_MP So, if you need I can post dump link. But first do as JayDi said- "read FW" to check system integrity Br. |
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
06-26-2015, 09:02 | #13 (permalink) |
Member: 851193 Status: Offline Sonork: 100.1615313 Thanks Meter: 348 | its same model I have reading in progress .if successfully read done or error I am going to message here thanks. I am able to read it successfully [ScatCFG] : MT6592 / V1.1.2 / wt98518 / EMMC FW Size : 1278 MiB Scatter saved to : C:\InfinityBox\CM2MTK\Flash\MT6592__htc__HTC Desire 616 dual sim__htc_v3_dug__4.2.2__SW_G98518A2_V019_M10_HTC_V 3DUG_ASIA_MP\ kindly help now by give dump / firmware link for same Last edited by kariakala; 06-26-2015 at 09:11. |
06-26-2015, 09:22 | #14 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Quote:
There is version difference in both firmwares- V008 vs V019. Anyway you can try, here is link for dump (not factory firmware)- 6592_Temp_dump Make sure you have complete backup of original firmware which is already in phone. Br. | |
The Following 3 Users Say Thank You to PASSIONATE_BOYS For This Useful Post: |
06-26-2015, 10:20 | #15 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Yes, this FW (dump) can work, if there was not any big difference between HW revisions ( not remeber about that in HTC MTK ) After write - restore your original NVRAM. |
