Old 12-09-2014, 11:05   #1 (permalink)
VIJAY2U2's Avatar
Member: 1039903
Thanks Meter: 2,025
Talking HTC Desire 616 [Test Report]
HTC DESIRE 616
Check / Read Info
Operation : Check / Read Info [ v1.07 ]
Wait for phone...
Phone found! [ 28 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6592
BB_CPU_HW : CA00
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BB_CPU_NM : [MediaTek] MT6592_S00
Processing BROM stage
BLVersion : 0x01
SecCfgVal : 0x00000000
BromVersion : 0xFF
BLVersion : 0x01
Preloader Status : Alive
Processing DA stage
DA Select done , sending
NAND_ID : 00000000000000000000000000000000
eMMC_ID : 90014A4834473164048601A39C6D51E3
DA Stat : v4.2 on BBID : 0x8A
DA Sent. Configure setting now ...
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0090 , OEM : 014A
[eMMC] : FLASH_INF : d1G4
[eMMC] : FLASH_CID : 90014A4834473164048601A39C6D51E3
[eMMC] : FLASH_LEN : 0x00000000E7000000
INT RAM    : 0x00020000
EXT RAM    : 0x40000000
BOOT TYPE  : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Initial info read Ok!
Done!
Elapsed: 00:00:08
Reconnect Power/Cable!
Old 12-09-2014, 11:35   #2 (permalink)
VIJAY2U2's Avatar
Member: 1039903
Thanks Meter: 2,025
Read PatternLock
Operation : Read PatternLock [ v1.07 ]
Wait for phone...
Phone found! [ 28 ]
Sync...
Boot Info :
BB_CPU_ID : 6592
BB_CPU_HW : CA00
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Reading data ...
FS Size : 2106 MiB
Magic Ok
Mount point  : /data
Get PatternLock ...
PatternLock Sequnce : 125874
Done!
Elapsed: 00:00:14
Old 12-09-2014, 11:37   #3 (permalink)
VIJAY2U2's Avatar
Member: 1039903
Thanks Meter: 2,025
Format FileSystem
Operation : Format FileSystem [ v1.07 ]
Wait for phone...
Phone found! [ 28 ]
Sync...
Boot Info :
BB_CPU_ID : 6592
BB_CPU_HW : CA00
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Backup : Already exist
FMT Mode set to : 10
Format : Cache and UserData (Full Factory Reset)
Format CACHE block
Set STORAGE_ERASE_ADDR failed! Something wrong with HW or FW?
Operation Failed
Elapsed: 00:00:45
Old 12-09-2014, 11:42   #4 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,181
For now 6592 and HTC exactly Format support disabled. When come second sample with 6592 - will be activated
Also HTC phones come to DL FAIL mode after format FS. At now help only Factory FW.
Will find way for this case also.
Old 12-09-2014, 11:47   #5 (permalink)
VIJAY2U2's Avatar
Member: 1039903
Thanks Meter: 2,025
hi
my set is ok after format fail
set have no problem just i m testing it
reading flash logs on the way
br
vijay2u2
Old 12-09-2014, 11:59   #6 (permalink)
VIJAY2U2's Avatar
Member: 1039903
Thanks Meter: 2,025
Read Flash
SIZE-3.60GB
Operation : Read Flash [ v1.07 ]
Wait for phone...
Phone found! [ 28 ]
Sync...
Boot Info :
BB_CPU_ID : 6592
BB_CPU_HW : CA00
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Reading Flash Conent now ...
Read Ok , collect info
Saved to : F:\InfinityBox\CM2MTK\Flash\6592_Temp_dump.ispff
Done!
Elapsed: 00:15:04
Old 12-09-2014, 12:48   #7 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,181
Originally Posted by VIJAY2U2 View Post
hi
br
vijay2u2
Sure it will not. I try make all safer, as possible, if something going wrong.
Read Flash
SIZE-3.60GB
Wait for phone...
Phone found! [ 28 ]
Sync...
Boot Info :
BB_CPU_ID : 6592
BB_CPU_HW : CA00
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Done!
Elapsed: 00:15:04
Thanks for the log, will improve compile info reading also.
Page generated in 0.27393 seconds with 7 queries
