01-28-2008, 08:37 | #1 (permalink) |
No Life Poster Join Date: Nov 2005 Location: TIRUPUR
Member: 202500 Status: Offline Thanks Meter: 234 | China Phones Restart/ Dead/insert Sim/bluetooth/ Keypad/white Screen Solutions R Here SUPPORTING BOX INFINTIY CABLE COMPORT MOTOROLA 191 CUT THE CABLE WHITE IS TX BLUE IS RX BLACK IS RX FOR FLASHING AND FORMATE....... NOW A DAYS MANY PHONES AFTER FULL FORMATE PHONE BECAME DEAD. BETTER FFS WITH SAFEMODE AND CHECK THE RESULT IF WORKS FINE THEN LEAVE IT IF NOT SOLVING PROBLE FORMATTE WITH FULL - MAXIMUM SOVLE THE PROBLEM IN CASE DEAD DONT WORRY U HAVE BACKUP OF THIS FLASH WILL WHICH IS STORED WITH PROGRAME/INFINITY/CHINA MIRACLE FOLDER ACCORDING YOUR TIME OF SAVED ERROM FILE NOTE AND LOAD AGAIN IN FLASH UNMARK FIRMWARE TICK EPROM AND SELCET BACKUP FILE AND FLASH NOW WILL SAME CONDITION WORKING WHICH IT WAS EARLIER CONDITION. I FOUND MANY FILES FROM AITHER FLASH OR EROM NOT MATCHING WITH HANDSET. SO BETTER GET SAME WORKING MODELS BACKUP FULL FLASH FILE AND EROM FILE STORE IT IN NEW FOLDER . KEEP IT FOR FLASHING AND FORMATION TO SAME MODELS PHONE. FOR EXAMPLE A5 CHINA PHONE : THERE R TWO TYPE OF FLASH FILE I FOUND IN THE HANDSET. WE MUST CAREFUL TO CHECK WHICH IS SUITABLE FOR THIS MODEL ONE IS backup_eeprom CKT26 05C[CKT26_05C_PCB01_GPRS_MT6226_S01.DINOSAUR_26B_HL_L8 SM_RCH_302_070822_LD_TR0_OV0_SS75_CTF_BT_A5.BIN]_20080126-231550.B0E OTHER ONE IS KT26 06B backup_eeprom[CKT26_06B_PCB01_GPRS_MT6226_S01.DINOSAUR6_26B_HL_L 9EN_200_071127_LD_OV0_SS75_CTF_BT_06B.BIN]_20080125-154121.B0E CHECK CARE FULL LOADED SAME FILE ONLY TO MATCH THEN ONLY PHONE WORKS FINE. THIS IS THE METHOD OF ALL MODELS THIS FIRST FLASH COULD NOT FIND IN THE SITE. SO BETTER TRY TO MAKE WORKING BACK FULL FLASH AND EROM BACKUP KEEP STORED WITH OTHER LOCATION. WHEN EVER NEED FILE U CAN EASILY TAKE AND FLASH. THUIS IS THE AI AM DOING AND ENJOYING AND MAKING MONEY............................. |
The Following User Says Thank You to ashok_kumar459 For This Useful Post: |
01-28-2008, 08:43 | #2 (permalink) |
No Life Poster Join Date: Apr 2001 Location: Sun Age: 44
Member: 4021 Status: Offline Thanks Meter: 782 | first of all thanks for your post.. second.... please next time dont use all capital letters... 3rd... is flashing the phone will fix INSERT SIM problems?? coz i have tried for some units and it did not solve the problem.. br |
01-28-2008, 08:47 | #3 (permalink) |
Member: 202500 Status: Offline Thanks Meter: 234 | thanks for ur reply there is two type of problem hard/software if software not working automatically we must looking in to hardware. that is all ... some case may not work i agree. first attempt always software. this was i posted. |
04-23-2008, 07:55 | #6 (permalink) | |
No Life Poster Join Date: Mar 2006 Location: tamilnadu, india.
Member: 243961 Status: Offline Sonork: 100.1591654 Thanks Meter: 104 | Quote:
05-28-2008, 17:22 | #8 (permalink) |
Freak Poster Join Date: Apr 2008
Member: 744651 Status: Offline Thanks Meter: 20 | Jailong 269 "Insert Sim" Problem Hi Ashok, Thanks for your post, I have a number of Chinese Dual Sim Phones, Jailong 269 that has "Insert Sim" problem. This happens only in SIMB, after a few minutes in a call, the call is dropped with the SIM B showing "Insert Sim", phone must be switched off and restarted then SIMB comes back only. What is your diagnosis of this problem?....Also, how can I use my Infinity Box to fix this...please note, I am a novice to the use of this Infinity Box. |
06-09-2008, 09:06 | #10 (permalink) | |
No Life Poster Join Date: Jun 2006 Location: ..::SL3 Unlock Source::.. Age: 38
Member: 293662 Status: Offline Sonork: 100.1622609 Thanks Meter: 317 | Quote:
Md kushol BD | |
12-26-2008, 09:05 | #15 (permalink) |
No Life Poster Join Date: May 2008 Location: PAKISTAN Age: 34
Member: 772820 Status: Offline Sonork: BE MASTERMIND Thanks Meter: 124 | That all greatest info but i want some info about china who white screen after flash or format what is it solution and if have no backup only readed firmware |
6600 White Screen Solution Is Here | Javajohn | Nokia Hardware & Hardware Repair | 36 | 05-27-2010 03:18 |
6300 China White Screen solution.. | Rizwan ch08 | Chinese Models & Cloned Phones | 4 | 08-02-2009 08:45 |
n73(rm170) china white screen solution needed | shani72 | Nokia Hardware & Hardware Repair | 0 | 12-06-2008 13:15 |
Ke500 White Screen Solution *here* | .:hack3r2k:. | FuriousGold | 23 | 03-19-2008 10:49 |
