03-10-2016, 19:32 | #1 (permalink) |
Insane Poster Join Date: Oct 2014
Member: 2268606 Status: Offline Thanks Meter: 5 | HTC One E9+ MT6795 flash error Code: Scatter Load Ok , BaseBand : MT6795 , Project : htc_a55ml , Storage : EMMC Files found : 17 , Set to Flash : 16 Ready to Flash! Operation : Flash [ v1.43 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital Boot Ok! BB_CPU_PID : 6795 BB_CPU_NME : [MediaTek] Helio[X10]|MT6795_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... [DA_ERROR] : SECURITY_BOOT_NOT_ACCEPTED Boot Error! Operation Failed |
03-11-2016, 12:39 | #6 (permalink) | |
No Life Poster Join Date: May 2005 Age: 40
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | Quote:
i have the same device with s-off and read backup fully.. i mean factory firmware.. if need full dump i can read it too.. maybe u can solve sth over it.. | |
03-11-2016, 17:11 | #7 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. I prefer re-check all things, before clearly say : HTC Xxx supported fully. I add only sme of new HTC's, and can't say exactly now - will it work well with latest MT6795 HTC or not. When get device - all will be clear. Dump not help me much. If CM2 read FW - it mean I already inspected such FW. |
01-18-2017, 16:28 | #9 (permalink) | |
Junior Member Join Date: Oct 2016
Member: 2638541 Status: Offline Thanks Meter: 0 | Quote:
i've a a55ml when i restore twrp backup recovery hanged up and stuck on logo just going to bootloader can you upload this file that you attach their photo and a clean dump for me? thanks | |
