03-01-2011, 13:51 | #1 (permalink) | ||
Freak Poster Join Date: Jun 2009
Member: 1059036 Status: Offline Thanks Meter: 57 | huawai g 7010 dead log read code PHP Code: Quote:
03-01-2011, 16:27 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @all please, use test software only according to my instruction: http://forum.gsmhosting.com/vbb/f296...0/#post7015056 Also, as I can see, in some cases software was used with other operation mode and I have to delete test software to avoid user's problems and future misunderstanding. Once again I ask everybody read instructions before use software ! We will continue with G7010 solution and I hope it will be fixed in short time. @GSM FREE charge battery and try to flash phone again |
03-01-2011, 18:18 | #5 (permalink) |
Member: 1059036 Status: Offline Thanks Meter: 57 | thanks phone power on and always locked OM4 [VCP0] selected module v3.77 Device: Huawei-G7010 Checking data, wait... Action: write flash skip: Firmware skip: Customization/Language Pack skip: Customization write: Eeprom/ffs Huawei-G7010_HUAWEI53_09B_PCB01_GPRS_MT6253_S00.ESPC113B1 46SSC.BIN_FLNTY6701111184KC__ffs_20110301-093800.B0M.bin nor area detection... interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6253:8A02:8A00 status: FF bbchip bl ver: FE NOR flash id[00C0]: 0098:009E00000000 [TOSHIBA] TC58FYM7T8C chip size: 16Mb otp status/size: S_DA_NOR_OTP_EXIST/00020000 NAND flash chip: not installed internal RAM size: 00020000 external RAM: S_DA_RAM_ERROR done Set baudrate (921600)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 00000000/00000000 detect sec ro... detect custom parameters... detect project-id... project-id: ESPC113B146SSC detect NOR info... number of areas/bytes to read: 1:00040000 reading (HW_STORAGE_NOR)... TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: HUAWEI53_09B_PCB01_GPRS_MT6253_S00.ESPC113B146SSC. BIN_FLNTY6701111184KC project-id: ESPC113B146SSC, 00000000 code offset: 00000000 ffs offset/size [02]: 00DC0000/00240000 rom info structure: [standard] type (07) TCL-ID is absent ===> done warning: firmware database can not be loaded number of cores: 1 loading files... number of areas: 1 done write... write core... Disconnect... done Finished, time used: 2 min 9 sec Remove/Install battery now ! |
03-01-2011, 19:27 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | I think that after you restore backup phone should be exactly in the same state as before. At least it should accept original sim card. We are working now to understand what is the problem with unlock, so if you can pls, keep phone with you. Also, try to make "read unlock codes" once again now. Pls, post here operation log. |
03-01-2011, 19:54 | #7 (permalink) |
Member: 1059036 Status: Offline Thanks Meter: 57 | i tested alwyas code not correct COM4 [VCP0] selected module v3.77 Action: read unlock codes unlock method: read codes Model: Huawei-G7010 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6253:8A02:8A00]... CPU: MT6253 chip: 0000:0000:000F status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6253,E02 Date: 2000.00.00 Version: 1.0 Version: ESPC113B146SSC Version: VER.B 115 byte(s) read imei: 3539150 connection Ok 216 byte(s) read 38 byte(s) read Phone lock: Off Phone code: 2580369 204 byte(s) read reading data... reading data #2... 188 byte(s) read lock[1] code: + 12345678 lock[2] code: + default lock[3] code: + 1122 lock[4] code: - default lock[5] code: - default lock[6] code: + default lock[7] code: + default if code is not accepted by phone: - make full flash backup for emergency case - flash phone with good eeprom file - Power-On phone without sim-card - Power-Off phone - read unlock codes - restore original imei Finished, time used: 13 sec Remove/Install battery now ! |
03-02-2011, 19:02 | #9 (permalink) |
Member: 1059036 Status: Offline Thanks Meter: 57 | unlock g6020 done COM4 [VCP0] selected module v3.77 Action: read unlock codes unlock method: read codes Model: Huawei-G6620 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6253:8A02:8A00]... CPU: MT6253 chip: 0000:0000:000F status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6253,E02 Date: 2000.00.00 Version: 1.0 Version: G6620SS.C210.M40.04.05 Version: CKT53_12832_09B_HW 116 byte(s) read imei: 35194804265474 connection Ok 217 byte(s) read 38 byte(s) read Phone lock: Off Phone code: 1234 205 byte(s) read reading data... 220 byte(s) read lock[1] code: + 38500546 lock[2] code: + default lock[3] code: + 1122 lock[4] code: - default lock[5] code: - default lock[6] code: + default lock[7] code: + default if code is not accepted by phone: - make full flash backup for emergency case - flash phone with good eeprom file - Power-On phone without sim-card - Power-Off phone - read unlock codes - restore original imei Finished, time used: 1 min 0 sec Remove/Install battery now ! i wait your update for tested g7010 |
The Following User Says Thank You to GSM FREE For This Useful Post: |
03-03-2011, 12:40 | #11 (permalink) |
Member: 1059036 Status: Offline Thanks Meter: 57 | unlock g6020 done new verssion COM4 [VCP0] selected module v3.77 Action: read unlock codes unlock method: read codes Model: Huawei-G6620 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6253:8A02:8A00]... CPU: MT6253 chip: 0000:0000:000F status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6253,E02 Date: 2000.00.00 Version: 1.0 Version: G6620SS.C210.M40.04.05 Version: CKT53_12832_09B_HW ==================== New firmware found (v.3.77, database date: 01.03.2011): G6620SS.C210.M40.04.05 This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== 116 byte(s) read imei: 35194804273073 connection Ok 217 byte(s) read 38 byte(s) read Phone lock: Off Phone code: 1234 205 byte(s) read reading data... 220 byte(s) read lock[1] code: + 38848954 lock[2] code: + default lock[3] code: + 1122 lock[4] code: - default lock[5] code: - default lock[6] code: + default lock[7] code: + default if code is not accepted by phone: - make full flash backup for emergency case - flash phone with good eeprom file - Power-On phone without sim-card - Power-Off phone - read unlock codes - restore original imei Finished, time used: 19 sec Remove/Install battery now ! http://www.4shared.com/file/H_hti1Ck...W_VODAFON.html for g7010 i wait your update |
03-04-2011, 22:36 | #14 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @GSM FREE we are really working hard w/o sleep now to improve g7010, hope to give results soon |
Repaired dead phone without backup | Prodigal | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-29-2011 11:26 |
HELP Dead 5130 v5.00 | N.Schmetz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 03-08-2011 04:51 |
help! Dead 5110 v5.30 | aklishin | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 04-04-2001 11:56 |
nokia 5110 dead | alpha | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 02-28-2001 11:59 |
6150 V5.20 WANTED --- DEAD OR ALIVE --- IT'S BETTER ALIVE ! ;))) | tcamilo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 12-19-1999 22:30 |
