01-19-2017, 19:29 | #1 (permalink) |
Freak Poster Join Date: Aug 2014 Location: algeria
Member: 2232889 Status: Offline Thanks Meter: 91 | open discussion for oppo f1s dead after flashing and finding solution and firmware so what i want from everyone to try posting all firmwares for the phone and the logs her and thnx for everybody how helps |
The Following User Says Thank You to AnonDz For This Useful Post: |
01-20-2017, 10:12 | #3 (permalink) |
Member: 2232889 Status: Offline Thanks Meter: 91 | hi guys i did make a folder with all the firmwares i have on this phone on mega.co and here it is the link https://mega.nz/#F!DsMGhY4A!TDJ3nCo79HKqQv19LamNog |
01-20-2017, 14:30 | #4 (permalink) |
Member: 2232889 Status: Offline Thanks Meter: 91 | hi guys for i did get something new on my mt6750 i did the with only this files and the now s but no boot logo no recovery but when i enter manually the recovery the gives me the recovery at the bottom but can't enter recovery because there is no recovery so it restarts after a while any new ideas to restor the missing files Last edited by AnonDz; 01-20-2017 at 14:37. |
01-21-2017, 07:50 | #9 (permalink) | |
No Life Poster Join Date: Apr 2016 Location: B A N G L A D E S H
Member: 2556542 Status: Offline Thanks Meter: 1,790 | Quote:
there is no solution yet very hard and no box support for flashing oppo f1s | |
01-21-2017, 08:53 | #10 (permalink) |
Member: 2232889 Status: Offline Thanks Meter: 91 | hi thnx guys for the help you can say i tried every firmware you now it on the net exept the [firmware27]OPPO F1s Live Mode.7z and everyone of them fail il get back at you after trying it thnx |
01-21-2017, 15:18 | #13 (permalink) | |
everbody listen to me carefully oppo f1s firmware is signed and much more security so not possible at this moment wait release cm2 mt 2.00 version problem will be solved pls dont waste your time untill jaydis knock | |
01-21-2017, 15:49 | #14 (permalink) |
Member: 2232889 Status: Offline Thanks Meter: 91 | my friend i unlocked flashed f1plus read pattern with cmtk 1.58 and flashed and read mt6755 oppo f1s but this one i cant nor read nor flash only this one and this is the latest one log Chinese Miracle II [MTK module] v 1.58 Operation : Read Pattern/DP Lock [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 13 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : BROM DRAM configured from IDB! Link with DAgent established eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM41C [eMMC] : FLASH_CID : 150100524331344D4201CCEBD90033EF [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000E8F800000 [eMMC] : FLASH_UCP : 59640 MiB [eMMC 128 GiB] DEV RID : 0x76A84994FE1E33BEEF6AF37BD39C36D7 INT RAM : 0x00000000 EXT RAM : 0x80000000 [2 GiB] [NAND] : FLASH : NOT INSTALLED [UFSM] : FLASH : NOT INSTALLED [HSUSB] : MODE : FULL-SPEED Boot Ok! USBDL : Init HSUSB Ok Reading data ... Get Locks ... PatternLock Sequnce : 74123598 Done! Elapsed: 00:00:32 Reconnect Power/Cable! Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 13 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : BROM DRAM configured from IDB! Link with DAgent established eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM41C [eMMC] : FLASH_CID : 150100524331344D4201CCEBD90033EF [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000E8F800000 [eMMC] : FLASH_UCP : 59640 MiB [eMMC 128 GiB] DEV RID : 0x76A84994FE1E33BEEF6AF37BD39C36D7 INT RAM : 0x00000000 EXT RAM : 0x80000000 [2 GiB] [NAND] : FLASH : NOT INSTALLED [UFSM] : FLASH : NOT INSTALLED [HSUSB] : MODE : FULL-SPEED Boot Ok! Reading Flash Content now ... USBDL : Init HSUSB Ok! xGPT : Normalize settings Ok! Brand : OPPO ProdName : X9009 ProdModel : X9009 Device : X9009 AndroidVer: 5.1 MTKxCPU : MT6755 MTKxPRJ : X9009EX_11_A.24_161205 [Read Ok] : preloader_oppo6755_15111.bin [Read Ok] : recovery.img [Read Ok] : md1img.img [Read Ok] : md1dsp.img [Read Ok] : md1arm7.img [Read Ok] : lk.bin [Read Ok] : lk2.bin [Read Ok] : boot.img [Read Ok] : logo.bin [Read Ok] : tz1.img [Read Ok] : tz2.img [Read Ok] : secro.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6755 / V1.1.2 / oppo6755_15111 / EMMC Android Info saved HWConfig Info saved FW Size : 3258 MiB Scatter saved to : C:\Users\AnonDz\Desktop\oppo\MT6755__OPPO__X9009__ X9009__5.1__X9009EX_11_A.24_161205\ All done! Done! Elapsed: 00:02:51 Reconnect Power/Cable! and this is the read of the firmware |
