Huawei c2906 does not recognize... please Infinity team first tell me that cdma tool 1.44 version support Huawei c2906 for unlock. second when i connect c2906 with v3i cable then show computer usb does not recognize, i have already check connector of mobile and changed cable too but problem still. please solve this. |
You Are Using Wrong Cable U Must Use RJ45 Cable C2601 Or Zte 7610 Connect Phone With Battery Open Module Select Port Select Model And Press Spunlock Wbr <<<Megatron>>> |
i was uesd rj45 cable with DirectCom but there was also show check cable. |
As I Told You Earlier Direct Com Is Not Enough For You You Must Have A UNI Box Any WayTry To Check Pinouts Of Cable UniBox Pinouts keyboard top /12345\ 1: Gnd (RJ45 pin-8) 3: box Tx/phone Rx/PinFinder Tx (RJ45 pin-2) 4: box Rx/phone Tx/PinFinder Rx (RJ45 pin-3) UFSPinouts keyboard top /12345\ 1: Gnd (RJ45 pin-8) 3: box Tx/phone Rx/PinFinder Tx (RJ45 pin-4) 4: box Rx/phone Tx/PinFinder Rx (RJ45 pin-5) Wbr <<<Megatron>>> |
How can a phone respond if wrong cable used . Quote:
Just a small answer for you "Cable is Bad or not connected " pls Recheck cable and try again.Do you have cable RJ-45 Blue 145x,Zte 7310/7610 cable? if not check pin-out and build one cable for your self bcz this cable is mostly used in huawei cdma phones . wbr |
same for /12345\ please sir make this for me. please i request u. |
http://i56.tinypic.com/122d8g9.jpg WBR <<<Megatron>>> |
Thanks <<<Megatron>>> sir u r rock. |
