11-14-2016, 15:35 | #1 (permalink) |
No Life Poster Join Date: Jun 2013 Location: PK Lahore Panjab
Member: 1965559 Status: Offline Sonork: 100.1622928 Thanks Meter: 1,834 | huawei Clone SL-4503 qualcomm hang on Logo Done . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . huawei Clone SL-4503 qualcomm hang on Logo Done Read flash fully supported Write flah fully Supported Frp Unlock fully supported With Infinity CM2 Read flash Done Code: Wait for phone... Device not found! Check cable, connection and drivers! Reconnect Power/Cable! Operation : Read Flash [ v1.02 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 210 [MSM8909] ID_BLOCK_S : 00FE8424 ID_BLOCK_I : 009600E1 ID_BLOCK_L : 49C762F6FE52E492 ID_BLOCK_L : 9B939302A85331CC Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8909 , FLASH : eMMC , VER : 1 ExtInfo : 0x0000C000/00100000/00001000/00001000 Boot Ok! Brand : LYF ProdName : LS-4503 ProdModel : LS-4503 Device : msm8909 AndroidVer: 5.1.1 Manufact. : unknown QLMxCPU : MSM8909 QLMxPRJ : LS-4503-S10A_LYF_L90EN_209_160725 DevInfo : MSM8909__unknown__LYF__ANDR_v5.1.1__LS-4503__msm8909__LS-4503__LS-4503-S10A_LYF_L90EN_209_160725 Reading Flash Content ... [Read Ok] : gpt_main0.bin [Read Ok] : NON-HLOS.bin [Read Ok] : sbl1.mbn [Read Ok] : emmc_appsboot.mbn [Read Ok] : rpm.mbn [Read Ok] : tz.mbn [Read Ok] : splash.img [Read Ok] : fs_gc.img [Read Ok] : sec.dat [Read Ok] : boot.img [Read Ok] : system.img [Read Ok] : persist.img [Read Ok] : cache.img [Read Ok] : recovery.img [Read Ok] : oem.img [Read Ok] : userdata.img [Read Ok] : gpt_backup0.bin Android Info saved! Read finished! Configuration : MSM8909 / eMMC Firmware Size : 2208 MiB Done! Elapsed: 00:03:11 Reconnect Power/Cable! Write flash Done Code: Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 210 [MSM8909] ID_BLOCK_S : 011C9504 ID_BLOCK_I : 009600E1 ID_BLOCK_L : 49C762F6FE52E492 ID_BLOCK_L : 9B939302A85331CC Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8909 , FLASH : eMMC , VER : 1 ExtInfo : 0x0000C000/00100000/00001000/00001000 Boot Ok! Files in Chain : 25 Flashing now Flashing : gpt_main0.bin Flashing : NON-HLOS.bin Flashing : sbl1.mbn Flashing : sbl1.mbn Flashing : emmc_appsboot.mbn Flashing : emmc_appsboot.mbn Flashing : rpm.mbn Flashing : rpm.mbn Flashing : tz.mbn Flashing : tz.mbn Flashing : splash.img Flashing : sec.dat Flashing : boot.img Flashing : system.img Flashing : persist.img Flashing : cache.img Flashing : recovery.img Flashing : oem.img Flashing : userdata.img Flashing : gpt_backup0.bin Flashing done! Done! Elapsed: 00:02:56 Reconnect Power/Cable! Frp Unlock Done FRP Reset Done by 1 Signal Click With Infinity CM2 Code: Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 210 [MSM8909] ID_BLOCK_S : 011C9504 ID_BLOCK_I : 009600E1 ID_BLOCK_L : 49C762F6FE52E492 ID_BLOCK_L : 9B939302A85331CC Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8909 , FLASH : eMMC , VER : 1 ExtInfo : 0x0000C000/00100000/00001000/00001000 Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP ( Google Reset Protection ) FRP removed! Done! Elapsed: 00:00:15 Reconnect Power/Cable! BR. Last edited by Mr..bhatti; 11-14-2016 at 15:45. |
The Following 7 Users Say Thank You to Mr..bhatti For This Useful Post: |
