Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2008 Location: some were in my head Age: 31
Member: 922273 Status: Offline Sonork: 100.1583612 Thanks: 85
| huawei g 6150 ok huawei g 6150 unlock 100% ==== [07/04/2012 12:19:09] ==== COM3 [VCP0] selected module v4.12 Model: Huawei-G6150 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6253:8A02:8A00]... CPU: MT6253 high speed boot On chip: 0000:0000:000F status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6253,E02 Date: 2000.00.00 Version: 1.0 Version: FRAC26B181SSC Version: VER.B ==================== New firmware found (v.4.12, database date: 28.11.2011): FRAC26B181SSC This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: support@infinity-box.biz or upload files to RapidShare ? Secure Data Logistics or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== 115 byte(s) read imei: 35xxxxxxxxxxxxx Finished, time used: 26 sec Remove/Install battery now ! Now click to "OK" button and press and HOLD phone "Power" button again ! interface: META_DLL_v6.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... done Release Power button now ! Shutdown... done Finished, time used: 7 sec Remove/Install battery now ! |
| The Following User Says Thank You to GFTELECOM For This Useful Post: |
| | #2 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Mar 2011
Member: 1527470 Status: Offline Thanks: 126
| module v4.23 Model: Huawei-G6150 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6253:8A02:8A00]... CPU: MT6253 high speed boot On chip: 0000:0000:000F status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6253,E02 Date: 2000.00.00 Version: 1.0 Version: FRAC26B176SSC Version: VER.B 115 byte(s) read imei: 3557*********** Finished, time used: 6 sec Remove/Install battery now ! Now click to "OK" button and press and HOLD phone "Power" button again ! interface: META_DLL_v6.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... done Release Power button now ! error: last error: 0012:[FAT] Target FAT file not found Shutdown... done error: operation failed ! Finished, time used: 5 sec Remove/Install battery now ! what is problem with my set |
| | #3 (permalink) |
| Junior Member Join Date: Apr 2012
Member: 1744578 Status: Offline Sonork: energy_fx Thanks: 0
| Please do help me in getting the valid unlock code, i found some online calculator but dat is nt working,. Please help. |
| | #5 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2004 Age: 39
Member: 95476 Status: Offline Thanks: 129
| huawei g6150 unlocked with infinity just selecte red code COM1 [Serial0] selected module v4.13 Model: Huawei-G6150 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6253:8A02:8A00]... CPU: MT6253 high speed boot On chip: 0000:0000:000F status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6253,E02 Date: 2000.00.00 Version: 1.0 Version: FRAC26B181SSC Version: VER.B ==================== New firmware found (v.4.13, database date: 08.05.2012): FRAC26B181SSC This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: support@infinity-box.biz or upload files to RapidShare ? Secure Data Logistics or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== 115 byte(s) read imei: 35391604140654 Finished, time used: 3 min 7 sec Remove/Install battery now ! Now click to "OK" button and press and HOLD phone "Power" button again ! interface: META_DLL_v6.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... done Release Power button now ! Shutdown... done Finished, time used: 6 sec Remove/Install battery now ! |
| The Following User Says Thank You to lader For This Useful Post: |
| | #6 (permalink) |
| Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2005 Location: infinity-box
Member: 130995 Status: Offline Thanks: 9,039
| Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works, what is phone hardware configuration (f.e. flash chip type) and what is possible problems (so we will be able to fix it) and successfully done work. |
| | #7 (permalink) | |
| Insane Poster ![]() ![]() ![]() Join Date: Jan 2010 Location: GB
Member: 1216581 Status: Offline Sonork: btcoolmi Thanks: 23
| Quote:
module v4.12 Model: Huawei-G7010 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6253:8A02:8A00]... CPU: MT6253 high speed boot On chip: 0000:0000:000F status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6253,E02 Date: 2000.00.00 Version: 1.0 Version: FRAC26B176SSC Version: VER.B 115 byte(s) read imei: 35XXXXXXXXXXXXXX Finished, time used: 8 sec Remove/Install battery now ! Now click to "OK" button and press and HOLD phone "Power" button again ! interface: META_DLL_v6.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... done Release Power button now ! error: last error: 0012:[FAT] Target FAT file not found Shutdown... done error: operation failed ! Finished, time used: 9 sec WHY I CAN UNLOCk,? were is the pb? | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| IR between 6150 and IBM TP 600 | favdijck | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 3 | 11-15-2011 12:08 |
| 6150 Lock Problem | Zeljko | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 1 | 09-11-1999 17:39 |
| i can unlock all nokia 5110/6110/6150 | spterminator | Main Sales Section | 0 | 07-30-1999 03:05 |
| $50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 4 | 07-09-1999 22:08 |
