07-15-2010, 21:19 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Colombia
Member: 614683 Status: Offline Sonork: 100.1605379 Thanks Meter: 370 | Huawei G3501 Not working unlock module v3.49 Action: "sp-unlock" unlock method: smart fast Model: Huawei-G3501 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:A57F:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: G3501CA.P63.M21.00.06 Version: CKT23C_08B_HW 80 byte(s) read imei: 35892703031232 connection Ok 185 byte(s) read reading data... building new data... writing data... 173 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 13 sec Remove/Install battery now ! still locked metodo 1 COM8 [VCP3] selected module v3.49 Action: read unlock codes unlock method: read codes Model: Huawei-G3501 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:A57F:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: G3501CA.P63.M21.00.06 Version: CKT23C_08B_HW 80 byte(s) read imei: 35892703031232 connection Ok 185 byte(s) read 38 byte(s) read Phone lock: Off Phone code: 1234 Finished, time used: 10 sec Remove/Install battery now ! not working COM8 [VCP3] selected module v3.49 Device: Huawei-G3501 Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard fast ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:A57F:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC240200000000:2AEA0000000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished ==================== New firmware detected (v.3.49, database date: 06.06.2010): GOLD_S06_PCB01_GPRS_MT6223P_S00.G3501CA_P63_M21_00 _06.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare: 1-CLICK Web hosting - Easy Filehosting or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info ver: 05 sw version: GOLD_S06_PCB01_GPRS_MT6223P_S00.G3501CA_P63_M21_00 _06.BIN project-id: G3501CA_P63_M21_00_06, 00000000 code offset: 00000000 ffs offset/size [01]: 00A50000/00550000 rom info structure: 2nd [standard] generation TCL-ID is absent ffs/eeprom address assigned: 00A50000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: EC240200000000:2AEA0000000000 Backup required data Done ====> Patch required data ... .................................. lock area found .................................. lock area found Patch required data Done ====> Special operation ... detecting parameters to apply patch area 1... ....................... required data found flash: EC240200000000:2AEA0000000000 flash: EC240200000000:2AEA0000000000 Write: area 1 (pass 1) ......................................... area 1 patch applied Ok Special operation Done ====> Write ... flash: EC240200000000:2AEA0000000000 flash: EC240200000000:2AEA0000000000 Write: lock-area-1 flash: EC240200000000:2AEA0000000000 flash: EC240200000000:2AEA0000000000 Write: lock-area-4 Write Done ====> Finalization ... Finalization Done Finished, time used: 1 min 11 sec Remove/Install battery now ! another COM8 [VCP3] selected module v3.49 Device: Huawei-G3501 Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:A57F:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC240200000000:2AEA0000000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished ==================== New firmware detected (v.3.49, database date: 06.06.2010): GOLD_S06_PCB01_GPRS_MT6223P_S00.G3501CA_P63_M21_00 _06.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare: 1-CLICK Web hosting - Easy Filehosting or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info ver: 05 sw version: GOLD_S06_PCB01_GPRS_MT6223P_S00.G3501CA_P63_M21_00 _06.BIN project-id: G3501CA_P63_M21_00_06, 00000000 code offset: 00000000 ffs offset/size [01]: 00A50000/00550000 rom info structure: 2nd [standard] generation TCL-ID is absent ffs/eeprom address assigned: 00A50000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: Huawei-G3501_GOLD_S06_PCB01_GPRS_MT6223P_S00.G3501CA_P63_ M21_00_06__ffs... file saved: C:\Archivos de programa\InfinityBox\MModule\Huawei-G3501_GOLD_S06_PCB01_GPRS_MT6223P_S00.G3501CA_P63_ M21_00_06__ffs_20100714-032954.B0E.bin flash: EC240200000000:2AEA0000000000 Backup required data Done ====> Patch required data ... detection procedure, wait... detection procedure completed detection procedure, wait... error: phone is not locked or unknown eeprom Patch required data Done ====> Special operation ... detecting parameters to apply patch area 1... .................................................. .............. error: area 1 can not apply patch Special operation Done ====> Write ... flash: EC240200000000:2AEA0000000000 Write: ffs Write Done ====> Finalization ... Finalization Done Finished, time used: 4 min 50 sec Remove/Install battery now ! all method input code np mr yellowboss hepl |
The Following User Says Thank You to jmr For This Useful Post: |
07-15-2010, 22:16 | #2 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,853 | Hello, Code: ==================== New firmware detected (v.3.49, database date: 06.06.2010): GOLD_S06_PCB01_GPRS_MT6223P_S00.G3501CA_P63_M21_00 _06.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare: 1-CLICK Web hosting - Easy Filehosting or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== |
08-26-2010, 21:35 | #8 (permalink) |
No Life Poster Join Date: Sep 2005 Location: ๑۩۞۩&&
Member: 178790 Status: Offline Sonork: 100.1593063 Thanks Meter: 1,234 | Yellow ! check.. after unlock the phone show. Enter Code NP ( Still Locked ) COM73 [VCP0] selected module v3.55 Action: "sp-unlock" unlock method: smart fast Model: Huawei-G3501 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:85D4:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: G3501CA.P63.M21.00.06 Version: CKT23C_08B_HW 80 byte(s) read imei: 35892703018847 connection Ok 185 byte(s) read reading data... reading data #2... building new data... writing data... 173 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 13 sec Remove/Install battery now ! Last edited by The_Dj; 08-26-2010 at 21:43. |
The Following User Says Thank You to The_Dj For This Useful Post: |
08-27-2010, 00:27 | #11 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,853 | Hello, We want to buy this phone for detailed research, we will pay for phone and delivery. If you can sell this phone to us, please, contact to [email protected] or ICQ 561878718 and talk about delivery. Thank you ! |
"Deskey Device driver not found" ?? Please help | DivAdonis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-08-2017 13:21 |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
how the **** do i make wintesla 6.03 work | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-16-1999 08:41 |
