GSM-Forum (https://forum.gsmhosting.com/vbb/)
-   Infinity-Box (https://forum.gsmhosting.com/vbb/f296/)
-   -   Huawei-G3610 Ufone Successfully Unlocked (https://forum.gsmhosting.com/vbb/f296/huawei-g3610-ufone-successfully-unlocked-1226756/)
Qaisar Mahmood 03-14-2011 15:09
COM4 [VCP11] selected
module v3.78
Action: read unlock codes
unlock method: read codes
Model: Huawei-G3610
Checking data, wait...
19200 autodetect
Initializing [6223:8A05:8A00]...
CPU: MT6223
chip: 0011:7A64:000C
status: FF
Connecting at 19200, wait...
Release Power button now !
Phone detected, wait...
Hardware: MT6223,E05
Date: 2000.00.00
Version: 1.0
Version: G3610_V100R001B001C19SP03S
Version: L75_HW
80 byte(s) read
imei: 35------------
connection Ok
185 byte(s) read
38 byte(s) read
Phone lock: Off
Phone code: 1122
173 byte(s) read
reading data...
972 byte(s) read
lock[1] code: + 47723911
lock[2] code: + default
lock[3] code: + 1122
lock[4] code: - default
lock[5] code: - default
lock[6] code: + default
lock[7] code: + default
if code is not accepted by phone:
- make full flash backup for emergency case
- flash phone with good eeprom file
- Power-On phone without sim-card
- Power-Off phone
- read unlock codes
- restore original imei
Finished, time used: 11 sec
Remove/Install battery now !
khalid mobile 03-15-2011 11:18
COM6 [VCP0] selected
module v3.75
Model: Huawei-G3610
19200 autodetect
CPU: MT6223
chip: 0011:4655:000C
status: FF
Date: 2000.00.00
Version: 1.0
Version: L75_HW
80 byte(s) read
imei: 35398504430088
connection Ok
185 byte(s) read
38 byte(s) read
Phone lock: Off
Phone code: 1234
173 byte(s) read
reading data...
972 byte(s) read
lock[1] code: + 07882419
lock[2] code: + 56781234
lock[4] code: - 3344
lock[5] code: - 5566
lock[6] code: + 7788
lock[7] code: + 9900
- Power-Off phone
- read unlock codes
Finished, time used: 2 min 15 sec
shamshad quresh 03-15-2011 11:41
which code use for unlocking? plaaaaaase tell us proceedure for entring unlock code. bro
Latifkhan75 03-16-2011 04:51
when insert block sim it show code on screne them put code 1 show in logs ur set will unlock
first connect set with spiderman then run latest mm module select port same to spider man and select model then click read code not sp lock u can read code by this method
khalid mobile 03-16-2011 08:27
infinty is very very best
InfinitySupport 03-17-2011 22:00
module v3.75
Model: Huawei-G3610
19200 autodetect
CPU: MT6223
status: FF
Date: 2000.00.00
Version: 1.0
Version: L75_HW
80 byte(s) read
connection Ok
185 byte(s) read
38 byte(s) read
Phone lock: Off
Phone code: 1234
173 byte(s) read
reading data...
972 byte(s) read
- Power-Off phone
- read unlock codes
Thank you very much for test report !
Each test report with attached logs is very important for us
so we can see how is Infinity-Box software works, what is phone hardware configuration (f.e. flash chip type)
and what is possible problems (so we will be able to fix it) and successfully done work.
abid jan 12-30-2013 06:43
HUAWEI G3610(ufone) 10 seUnlock done
Format and Enter 12345678 NP code
MUSLIMBEK 02-09-2014 14:44
please unlock full flash volcano
InfinitySupport 02-11-2014 02:22
Hello,
Do not use full flash for unlock, you must use Infinity-Box and unlock this phone in 5 seconds.
ihsan.khan.gsm 02-20-2014 17:36
wich cable use for this model we have 3 pc of the cable 7610,c2500.a39 ,no one working
YellowBoss 02-20-2014 17:59
Hello,
What is the problem exactly ?
Post here operation log text
ihsan.khan.gsm 02-21-2014 05:01
bro me want unlock huawie g3610 sellphene. we did treid to alot of by that cables but could,t connected yet therefore asked about the cable
YellowBoss 02-26-2014 12:01
Hello,
Here is an instruction how to get cable/pinout information:
1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update: Infinity-Box - News - 24-02-2014 - Infinity-Box Nokia [BEST] v1.83 released
2. run Infinity-Box Shell
3. select required model
4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information)
Here is an example of information given by Infinity-Box Shell.
It's just an example for Alcatel, if you have another model you must select your model !
http://www.infinity-box.com/download...shell_v126.jpg
RJ45 connector pinout:
http://www.infinity-box.com/download...pins_small.jpg
Here is an information how to build your own cable: FAQ: Frequently Asked Questions, cables/pinouts
AonMobilles 12-14-2015 12:14
HUAWEI G3610 ufone unlock done with volcano
http://www.4shared.com/download/cQeI...f95d&lgfp=3000
Format and Enter 12345678 NP code :D:D:D
AON MOBILES
Page generated in 0.14573 seconds with 6 queries
