Unlock Server
Old 03-14-2011, 15:09   #1 (permalink)
Qaisar Mahmood's Avatar
Member: 226457
Sonork: 100.1604561
Huawei-G3610 Ufone Successfully Unlocked
COM4 [VCP11] selected
module v3.78
Action: read unlock codes
unlock method: read codes
Model: Huawei-G3610
Checking data, wait...
19200 autodetect
Initializing [6223:8A05:8A00]...
CPU: MT6223
chip: 0011:7A64:000C
status: FF
Connecting at 19200, wait...
Release Power button now !
Phone detected, wait...
Hardware: MT6223,E05
Date: 2000.00.00
Version: 1.0
Version: G3610_V100R001B001C19SP03S
Version: L75_HW
80 byte(s) read
imei: 35------------
connection Ok
185 byte(s) read
38 byte(s) read
Phone lock: Off
Phone code: 1122
173 byte(s) read
reading data...
972 byte(s) read
lock[1] code: + 47723911
lock[2] code: + default
lock[3] code: + 1122
lock[4] code: - default
lock[5] code: - default
lock[6] code: + default
lock[7] code: + default
if code is not accepted by phone:
- make full flash backup for emergency case
- flash phone with good eeprom file
- Power-On phone without sim-card
- Power-Off phone
- read unlock codes
- restore original imei
Finished, time used: 11 sec
Remove/Install battery now !
Old 03-15-2011, 11:18   #2 (permalink)
Member: 1255084
COM6 [VCP0] selected
module v3.75
Model: Huawei-G3610
19200 autodetect
CPU: MT6223
chip: 0011:4655:000C
status: FF
Date: 2000.00.00
Version: 1.0
Version: L75_HW
80 byte(s) read
imei: 35398504430088
connection Ok
185 byte(s) read
38 byte(s) read
Phone lock: Off
Phone code: 1234
173 byte(s) read
reading data...
972 byte(s) read
lock[1] code: + 07882419
lock[2] code: + 56781234
lock[4] code: - 3344
lock[5] code: - 5566
lock[6] code: + 7788
lock[7] code: + 9900
- Power-Off phone
- read unlock codes
Finished, time used: 2 min 15 sec
The Following User Says Thank You to khalid mobile For This Useful Post:
Old 03-15-2011, 11:41   #3 (permalink)
shamshad quresh's Avatar
Member: 898041
Sonork: 5346
which code use for unlocking? plaaaaaase tell us proceedure for entring unlock code. bro
Old 03-16-2011, 04:51   #4 (permalink)
Latifkhan75's Avatar
Member: 1352180
Sonork: 100.1605782
when insert block sim it show code on screne them put code 1 show in logs ur set will unlock
first connect set with spiderman then run latest mm module select port same to spider man and select model then click read code not sp lock u can read code by this method
Old 03-16-2011, 08:27   #5 (permalink)
Member: 1255084
infinty is very very best
Old 03-17-2011, 22:00   #6 (permalink)
InfinitySupport's Avatar
Member: 130995
module v3.75
Model: Huawei-G3610
19200 autodetect
CPU: MT6223
status: FF
Date: 2000.00.00
Version: 1.0
Version: L75_HW
80 byte(s) read
connection Ok
185 byte(s) read
38 byte(s) read
Phone lock: Off
Phone code: 1234
173 byte(s) read
reading data...
972 byte(s) read
- Power-Off phone
- read unlock codes
Thank you very much for test report !
Each test report with attached logs is very important for us
so we can see how is Infinity-Box software works, what is phone hardware configuration (f.e. flash chip type)
and what is possible problems (so we will be able to fix it) and successfully done work.
FAQ about unlock n0kia man0n Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 11-29-2010 18:06
$50 Reward for unlocking my 6150!!! TheDon Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 4 07-09-1999 22:08
Page generated in 1.52128 seconds with 11 queries
