08-08-2013, 14:16 | #1 (permalink) |
Freak Poster Join Date: May 2007 Location: MX-KEY is the BEST NOKIA TOOL
Member: 509348 Status: Offline Thanks Meter: 116 | Huawei g6 unlock problem , now restart when i do unlock in m module 4.13 , it gives error at the end Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6253:8A02:8A00]... CPU: MT6253 high speed boot On chip: 0000:0000:000F status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6253,E02 Date: 2000.00.00 Version: 1.0 Version: PTRC77B168SSC Version: VER.B 115 byte(s) read imei: 35391604022959 Finished, time used: 16 sec Remove/Install battery now ! Now click to "OK" button and press and HOLD phone "Power" button again ! interface: META_DLL_v6.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... done Release Power button now ! error: last error: 0012:[FAT] Target FAT file not found Shutdown... done error: operation failed ! Finished, time used: 6 sec Remove/Install battery now ! after getting this error , phone restarts on T logo with sim card , but on normally without sim i also try to writethese readed files and eaprom but still same problem , help me to get the set back in same condition and unlock , thnx i m waiting |
08-08-2013, 14:20 | #2 (permalink) |
No Life Poster Join Date: Apr 2006 Location: INDIA Age: 38
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | USE LATEST INFINITY-BOX MMODULE TO UNLOCK. WBR sahil2000ind |
The Following User Says Thank You to sahil2000ind For This Useful Post: |
08-09-2013, 20:24 | #5 (permalink) | |
According to log, your phone have been already damaged before unlock process (some important data have been absent in phone memory). Currently we do not have any solution to repair such fault. You can try to restore eeprom backup file, but if phone was damaged before this can not help. | |
