08-04-2015, 11:28 | #1 (permalink) |
Freak Poster Join Date: Apr 2008 Location: World of technology
Member: 749754 Status: Offline Sonork: partycrasher131 Thanks Meter: 134 | huawei g610-00 format error Operation : Format FileSystem [ v1.24 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 16 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6583 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6583|6589_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 484A019064314734A3018604874139D8 DA Stat : v3.2 on BBID : 0x86 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : d1G4 [eMMC] : FLASH_CID : 90014A4834473164048601A3D8394187 [eMMC] : FLASH_LEN : 0x00000000E7000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Backup : Already exist FMT Mode set to : 0 Fatal error, buffer empty! Phone connection lost??? Format prepare error : PMT info is wrong!!! Require special settings for format that phone , contact with support! Done! Elapsed: 00:00:24 Reconnect Power/Cable! |
08-04-2015, 11:37 | #2 (permalink) |
Member: 749754 Status: Offline Sonork: partycrasher131 Thanks Meter: 134 | when i selected huawei g610 from the dropdown menu i get this log Start at : [8/4/2015 / 4:18:00 PM] Operation : Format FileSystem [ v1.24 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 16 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6583 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6583|6589_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage Will use Secure DA for boot target DA Select done , sending DA Stat : v3.2 on BBID : 0x86 DA Sent. Configure setting now ... DA start Failed! Check battery , cable , drivers and try try again Boot Error! Elapsed: 00:00:06 Reconnect Power/Cable! Finish at : [8/4/2015 / 4:18:07 PM] |
