12-26-2011, 17:36 | #1 (permalink) |
No Life Poster Join Date: Jun 2006 Location: Alger Age: 57
Member: 295459 Status: Offline Thanks Meter: 68 | Huawei G6150 Unlock error COM4 [VCP8] selected module v4.12 Model: Huawei-G6150 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6253:8A02:8A00]... CPU: MT6253 high speed boot On chip: 0000:0000:000F status: FF Connecting at 19200, wait... warning: wrong packet cs Release Power button now ! Phone detected, wait... warning: can't read software version, probably unknown firmware 115 byte(s) read Finished, time used: 4 min 6 sec Remove/Install battery now ! error: invalid data size Shutdown... done Finished, time used: 4 min 6 sec Remove/Install battery now ! |
12-29-2011, 09:45 | #3 (permalink) |
Member: 295459 Status: Offline Thanks Meter: 68 | I can't read "read detailed information" but I read eeprom : COM4 selected module v4.12 Device: Huawei-G6150 Checking data, wait... Action: read ffs/eeprom NAND interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6253:8A02:8A00 status: FF bbchip bl ver: FE NOR flash id[00C1]: 00EC:240400000000 [SAMSUNG] K5N2833ATB chip size: 16Mb otp status/size: S_DA_NOR_OTP_NOT_SUPPORT/00000000 NAND flash chip: not installed internal RAM size: 00020000 external RAM: absent done Set baudrate (115200)... done ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 00000000/00000000 detect sec ro... detect custom parameters... detect project-id... project-id: FRAC26B176SSC detect NOR info... number of areas/bytes to read: 1:00050000 reading (HW_STORAGE_NOR)... TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: HUAWEI53_09B_PCB01_GPRS_MT6253_S00.FRAC26B176SSC.B IN_FLNTY6701111184KC project-id: FRAC26B176SSC, 00000000 code offset: 00000000 ffs offset/size [02]: 00D40000/002C0000 rom info structure: [standard] type (07) TCL-ID is absent ===> done area size: 2Mb number of areas/bytes to read: 1:002C0000 reading (HW_STORAGE_NOR)... file saved: C:\Program Files\InfinityBox\MModule\Huawei-G6150_HUAWEI53_09B_PCB01_GPRS_MT6253_S00.FRAC26B17 6SSC.BIN_FLNTY6701111184KC__ffs_20111229-094334.B0M.bin Disconnect... done Finished, time used: 6 min 27 sec Remove/Install battery now ! |
12-29-2011, 09:50 | #4 (permalink) | |
Member: 295459 Status: Offline Thanks Meter: 68 | Quote:
I can't read "read detailed information" but I read eeprom : COM4 selected module v4.12 Device: Huawei-G6150 Checking data, wait... Action: read ffs/eeprom NAND interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6253:8A02:8A00 status: FF bbchip bl ver: FE NOR flash id[00C1]: 00EC:240400000000 [SAMSUNG] K5N2833ATB chip size: 16Mb otp status/size: S_DA_NOR_OTP_NOT_SUPPORT/00000000 NAND flash chip: not installed internal RAM size: 00020000 external RAM: absent done Set baudrate (115200)... done ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 00000000/00000000 detect sec ro... detect custom parameters... detect project-id... project-id: FRAC26B176SSC detect NOR info... number of areas/bytes to read: 1:00050000 reading (HW_STORAGE_NOR)... TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: HUAWEI53_09B_PCB01_GPRS_MT6253_S00.FRAC26B176SSC.B IN_FLNTY6701111184KC project-id: FRAC26B176SSC, 00000000 code offset: 00000000 ffs offset/size [02]: 00D40000/002C0000 rom info structure: [standard] type (07) TCL-ID is absent ===> done area size: 2Mb number of areas/bytes to read: 1:002C0000 reading (HW_STORAGE_NOR)... file saved: C:\Program Files\InfinityBox\MModule\Huawei-G6150_HUAWEI53_09B_PCB01_GPRS_MT6253_S00.FRAC26B17 6SSC.BIN_FLNTY6701111184KC__ffs_20111229-094334.B0M.bin Disconnect... done Finished, time used: 6 min 27 sec Remove/Install battery now ! thanks | |
12-31-2011, 10:30 | #5 (permalink) | |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
