Old 03-05-2012, 12:05   #1 (permalink)
Member: 112185
huawei G6150 unlocked ok!
just by read code :
Version: FRAC26B181SSC
Version: VER.B
New firmware found (v.4.13, database date: 29.01.2012):
FRAC26B181SSC
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: support@infinity-box.biz or upload files to http://rapidshare.com or http://4shared.com
- include in your e-mail full text from phone back label (phone name etc.)
115 byte(s) read
imei: xxxxxxxxxxxxxxxxx
Finished, time used: 1 min 44 sec
Remove/Install battery now !
Now click to "OK" button and press and HOLD phone "Power" button again !
interface: META_DLL_v6.1016.00
Connect...
Connecting...
done
Release Power button now !
Shutdown...
done
Finished, time used: 7 sec
The Following User Says Thank You to recan21 For This Useful Post:
Old 04-09-2012, 11:27   #2 (permalink)
TUR@N ALAM's Avatar
Member: 705213
Sonork: 100:1601195
COM3 [Serial2] selected
module v4.13
Model: Huawei-G6150
Checking data, wait...
19200 autodetect
Initializing [6253:8A02:8A00]...
CPU: MT6253
high speed boot On
chip: 0000:0000:000F
status: FF
Connecting at 19200, wait...
Phone detected, wait...
Hardware: MT6253,E02
Date: 2000.00.00
Version: 1.0
Version: FRAC26B176SSC
Version: VER.B
115 byte(s) read
imei: 353916040
Finished, time used: 24 sec
Connect...
Connecting...
done
Shutdown...
done
Finished, time used: 5 sec
The Following 2 Users Say Thank You to TUR@N ALAM For This Useful Post:
Old 04-15-2012, 13:09   #3 (permalink)
YellowBoss's Avatar
Member: 1043909
Thank you very much for test report !
Each test report with attached logs is very important for us
so we can see how is Infinity-Box software works, what is phone hardware configuration (f.e. flash chip type)
and what is possible problems (so we will be able to fix it) and successfully done work.
Old 05-08-2012, 16:55   #4 (permalink)
Member: 196085
thanksssssssssssssssssssssssssssssssss
Old 05-21-2012, 20:05   #5 (permalink)
Member: 127053
Thanxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Old 05-26-2012, 13:17   #6 (permalink)
fypoi's Avatar
Member: 712832
no doubts in infinity soft
model listed = model supported
thanks team
br
The Following User Says Thank You to fypoi For This Useful Post:
Old 06-16-2012, 08:38   #7 (permalink)
darmobiles's Avatar
Member: 1675429
Sonork: 1609235
after this process phone still locked.
what is this
COM7 [VCP0] selected
module v4.32
Model: Huawei-G6150
19200 autodetect
CPU: MT6253
high speed boot On
status: FF
Date: 2000.00.00
Version: 1.0
Version: VER.B
115 byte(s) read
imei: 35391604071218
interface: META_DLL_v6.1108.00
Connect...
Connecting...
done
Shutdown...
done
Finished, time used: 10 sec
Old 06-16-2012, 08:45   #8 (permalink)
darmobiles's Avatar
Member: 1675429
Sonork: 1609235
i chose standard method and phone unlocked successfully.
The Following User Says Thank You to darmobiles For This Useful Post:
Old 07-01-2012, 22:02   #9 (permalink)
Member: 13751
With which cable??
Thank you for the answer
Old 07-05-2012, 20:15   #10 (permalink)
darmobiles's Avatar
Member: 1675429
Sonork: 1609235
for this Use z3x uart cable.
Old 07-31-2012, 09:16   #11 (permalink)
InfinitySupport's Avatar
Member: 130995
Originally Posted by petit1959 View Post
With which cable??
Hello,
Here is an instruction how to get cable/pinout information:
1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update: Infinity-Box - News
2. run Infinity-Box Shell
3. select required model
4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information)
Here is an example of information given by Infinity-Box Shell.
It's just an example for Alcatel, if you have another model you must select your model !
RJ45 connector pinout:
Here is an information how to build your own cable: FAQ: Frequently Asked Questions, cables/pinouts
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 08-01-2012, 00:30   #12 (permalink)
Member: 95476
huawei g6150 unlocked with infinity
just selecte red code
COM1 [Serial0] selected
module v4.13
Model: Huawei-G6150
19200 autodetect
CPU: MT6253
high speed boot On
status: FF
Date: 2000.00.00
Version: 1.0
Version: VER.B
New firmware found (v.4.13, database date: 08.05.2012):
FRAC26B181SSC
- send flash backup files to support: support@infinity-box.biz or upload files to RapidShare ? Secure Data Logistics or 4shared.com - free file sharing and storage
115 byte(s) read
imei: 35391604140654
Finished, time used: 3 min 7 sec
Connect...
Connecting...
done
Shutdown...
done
Finished, time used: 6 sec
The Following User Says Thank You to lader For This Useful Post:
Old 08-01-2012, 10:00   #13 (permalink)
Member: 130995
FAQ about unlock n0kia man0n Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 11-29-2010 18:06
$50 Reward for unlocking my 6150!!! TheDon Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 4 07-09-1999 22:08
Page generated in 0.49091 seconds with 11 queries
