Huawei G6600 pinout ????? 1 Attachment(s) Hi, I am trying to unlock a HUAWEI G6600 but I can't connect it. I had tryed using pin finder, it finds Rx Tx on pins 3 an 4 but phone doesen't boot. I want ot solder wires on pcb but the picture given is diffrent from the phones . Can someone point me on the picture attaced here where is rx and tx on board? |
alcatel s211 cable, working 100% |
Phone is new and pinfinder is workind with other phone models I want like someone to point me on pic atached Rx and TX |
three points at right side. 0 0 0 0 ________ 1 2 3 1: connect to RJ45 pin-2 2: connect to RJ45 pin-3 GND - take it from PCB (f.e. from "-" battery contact) |
Thanks I will test it tomorroy and post result |
Huawei G6600 pinout Huawei G6600 pinout +++++++++++++ |
COM4 [VCP0] selected module v3.73 Action: read unlock codes unlock method: read codes Model: Huawei-G6600 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8A04:8A01]... CPU: MT6235 chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6235,E04 Date: 2000.00.00 Version: 1.0 Version: E5.2FY01V01.09 Version: BYD35_09A_PMWY_HW 82 byte(s) read imei: 35751003698294 connection Ok 189 byte(s) read 38 byte(s) read Phone lock: Off Phone code: 1234 Finished, time used: 14 sec Remove/Install battery now ! |
pinout g6600 here |
this works thanks!!!!!!!!!! |
COM5 [VCP0] selected module v3.75 Action: read unlock codes unlock method: read codes Model: Huawei-G6600 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8A04:8A01]... CPU: MT6235 chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6235,E04 Date: 2000.00.00 Version: 1.0 Version: E5.2RT01V01.04 Version: BYD35_09A_PMWY_HW 82 byte(s) read imei: 35751003858927 connection Ok 189 byte(s) read 38 byte(s) read Phone lock: Off Phone code: 1234 177 byte(s) read reading data... 972 byte(s) read lock[1] code: + 87362826 lock[2] code: + 56781234 lock[3] code: + 1122 lock[4] code: - 3344 lock[5] code: - 5566 lock[6] code: + 7788 lock[7] code: + 9900 if code is not accepted by phone: - make full flash backup for emergency case - flash phone with good eeprom file - Power-On phone without sim-card - Power-Off phone - read unlock codes - restore original imei Finished, time used: 17 sec Remove/Install battery now ! |
Done 100% With v3.82 COM11 [VCP0] selected module v3.82 Action: read unlock codes unlock method: read codes Model: Huawei-G6600 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8A04:8A01]... CPU: MT6235 chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6235,E04 Date: 2000.00.00 Version: 1.0 Version: E5.2EM01V01.08 Version: BYD35_09A_PMWY_HW 82 byte(s) read imei: 3575XXXXXXXXX connection Ok 189 byte(s) read 38 byte(s) read Phone lock: Off Phone code: 1234 177 byte(s) read reading data... 972 byte(s) read lock[1] code: + 43487131 lock[2] code: + default lock[3] code: + 1122 lock[4] code: - default lock[5] code: - default lock[6] code: + default lock[7] code: + default if phone do not ask for a code try: *983*8284# if code is not accepted by phone: - make full flash backup for emergency case - flash phone with good eeprom file - Power-On phone without sim-card - Power-Off phone (do not remove battery) - read unlock codes - restore original imei Finished, time used: 16 sec Remove/Install battery now ! |
COM152 [VCP0] selected module v3.82 Action: "sp-unlock" méthode déverrouillage: Smart rapide Modèle: Huawei-G6600 Contrôle des données, attendre ... téléphone doit être éteint! Appuyez et restez appuiez sur le bouton "Power" dès maintenant! 19200 autodetect Initialisation [6235:8A04:8A01]... CPU: MT6235 chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... lachez bouton d'alimentation maintenant! Téléphone détecté, attendre ... Matériel: MT6235,E04 Date: 2000.00.00 Version: 1.0 Version: E5.2FY01V01.09 Version: BYD35_09A_PMWY_HW 82 byte(s) read IMEI: 35751003891387 connexion Ok 189 byte(s) read lecture des données en cours ... reading data #2... la construction de nouvelles données ... écriture de données ... 177 byte(s) read lecture des données en cours ... 972 byte(s) read la construction de nouvelles données ... écriture de données ... verifying... vérification Ok bien Terminé, temps utilisé: 25 sec Retirez / remettre la batterie maintenant! |
100000% work tnx............. |
