Old 09-19-2010, 19:21   #1 (permalink)
dragosgsm's Avatar
Member: 148032
Thanks Meter: 387
Huawei G6600 pinout ?????
Hi, I am trying to unlock a HUAWEI G6600 but I can't connect it.
I had tryed using pin finder, it finds Rx Tx on pins 3 an 4 but phone doesen't boot. I want ot solder wires on pcb but the picture given is diffrent from the phones .
Can someone point me on the picture attaced here where is rx and tx on board?
The Following User Says Thank You to dragosgsm For This Useful Post:
Old 09-19-2010, 19:43   #2 (permalink)
Crazy Poster
Member: 123904
Thanks Meter: 8
alcatel s211 cable, working 100%
The Following User Says Thank You to teddeca For This Useful Post:
Old 09-19-2010, 20:53   #3 (permalink)
dragosgsm's Avatar
Member: 148032
Thanks Meter: 387
I know that because I had used search before posting, but I don't have s211 cable so I tryed with pinfider but,as I said,phone dosen't boot(pinfinder findes pins but doesen't boot)
Phone is new and pinfinder is workind with other phone models
I want like someone to point me on pic atached Rx and TX
Old 09-19-2010, 21:11   #4 (permalink)
Member: 1043909
Thanks Meter: 52,433
three points at right side.
0 0 0 0 ________ 1 2 3
1: connect to RJ45 pin-2
2: connect to RJ45 pin-3
GND - take it from PCB (f.e. from "-" battery contact)
The Following 10 Users Say Thank You to YellowBoss For This Useful Post:
Old 09-20-2010, 20:22   #5 (permalink)
dragosgsm's Avatar
Member: 148032
Thanks Meter: 387
Thanks I will test it tomorroy and post result
Old 01-21-2011, 17:05   #6 (permalink)
MMDEBILI's Avatar
Member: 360073
Thanks Meter: 2,180
Huawei G6600 pinout
Huawei G6600 pinout +++++++++++++
Old 01-21-2011, 17:26   #7 (permalink)
MMDEBILI's Avatar
Member: 360073
Thanks Meter: 2,180
COM4 [VCP0] selected
module v3.73
Action: read unlock codes
unlock method: read codes
Model: Huawei-G6600
Checking data, wait...
19200 autodetect
Initializing [6235:8A04:8A01]...
CPU: MT6235
chip: 0000:0000:0003
status: FF
rom: 4D573031
Connecting at 19200, wait...
Release Power button now !
Phone detected, wait...
Hardware: MT6235,E04
Date: 2000.00.00
Version: 1.0
Version: E5.2FY01V01.09
Version: BYD35_09A_PMWY_HW
82 byte(s) read
imei: 35751003698294
connection Ok
189 byte(s) read
38 byte(s) read
Phone lock: Off
Phone code: 1234
Finished, time used: 14 sec
Remove/Install battery now !
The Following User Says Thank You to MMDEBILI For This Useful Post:
Old 01-21-2011, 17:50   #8 (permalink)
MMDEBILI's Avatar
Member: 360073
Thanks Meter: 2,180
module v3.73
Action: "sp-unlock"
unlock method: smart fast
Model: Huawei-G6600
19200 autodetect
CPU: MT6235
status: FF
rom: 4D573031
Date: 2000.00.00
Version: 1.0
82 byte(s) read
connection Ok
189 byte(s) read
reading data...
reading data #4...
building new data...
writing data...
177 byte(s) read
reading data...
972 byte(s) read
writing data...
verifying...
verification Ok
done
Finished, time used: 15 sec
working 100%.........
Old 01-22-2011, 13:11   #9 (permalink)
Member: 1434518
Thanks Meter: 7
its wrong on that model just use alcatel cable S120 100%
Old 01-29-2011, 21:34   #10 (permalink)
Member: 106488
Thanks Meter: 23
pinout g6600 here
The Following 11 Users Say Thank You to fantomasv For This Useful Post:
Old 03-10-2011, 10:06   #11 (permalink)
dragosgsm's Avatar
Member: 148032
Thanks Meter: 387
this works thanks!!!!!!!!!!
Old 03-31-2011, 13:16   #12 (permalink)
Member: 365289
Thanks Meter: 9
COM5 [VCP0] selected
module v3.75
Model: Huawei-G6600
19200 autodetect
CPU: MT6235
status: FF
rom: 4D573031
Date: 2000.00.00
Version: 1.0
Version: E5.2RT01V01.04
82 byte(s) read
imei: 35751003858927
connection Ok
189 byte(s) read
38 byte(s) read
Phone lock: Off
Phone code: 1234
177 byte(s) read
reading data...
972 byte(s) read
lock[1] code: + 87362826
lock[2] code: + 56781234
lock[3] code: + 1122
lock[4] code: - 3344
lock[5] code: - 5566
lock[6] code: + 7788
lock[7] code: + 9900
if code is not accepted by phone:
- make full flash backup for emergency case
- flash phone with good eeprom file
- Power-On phone without sim-card
- Power-Off phone
- read unlock codes
- restore original imei
Finished, time used: 17 sec
The Following User Says Thank You to abidjon For This Useful Post:
Old 04-04-2011, 14:34   #13 (permalink)
SiLver GSM's Avatar
Member: 210304
Sonork: 100.1573283
Thanks Meter: 1,455
Done 100% With v3.82
COM11 [VCP0] selected
module v3.82
Model: Huawei-G6600
19200 autodetect
CPU: MT6235
status: FF
rom: 4D573031
Date: 2000.00.00
Version: 1.0
Version: E5.2EM01V01.08
82 byte(s) read
imei: 3575XXXXXXXXX
connection Ok
189 byte(s) read
38 byte(s) read
Phone lock: Off
Phone code: 1234
177 byte(s) read
reading data...
972 byte(s) read
lock[1] code: + 43487131
lock[2] code: + default
lock[4] code: - default
lock[5] code: - default
lock[6] code: + default
lock[7] code: + default
if phone do not ask for a code try: *983*8284#
- Power-Off phone (do not remove battery)
- read unlock codes
Finished, time used: 16 sec
The Following User Says Thank You to SiLver GSM For This Useful Post:
Old 04-11-2011, 19:22   #14 (permalink)
pikiche's Avatar
Member: 248858
Sonork: 100.1608346
Thanks Meter: 215
COM152 [VCP0] selected
module v3.82
Action: "sp-unlock"
méthode déverrouillage: Smart rapide
Modèle: Huawei-G6600
Contrôle des données, attendre ...
téléphone doit être éteint!
Appuyez et restez appuiez sur le bouton "Power" dès maintenant!
19200 autodetect
Initialisation [6235:8A04:8A01]...
CPU: MT6235
status: FF
rom: 4D573031
lachez bouton d'alimentation maintenant!
Téléphone détecté, attendre ...
Matériel: MT6235,E04
Date: 2000.00.00
Version: 1.0
82 byte(s) read
IMEI: 35751003891387
connexion Ok
189 byte(s) read
lecture des données en cours ...
reading data #2...
la construction de nouvelles données ...
écriture de données ...
177 byte(s) read
972 byte(s) read
verifying...
vérification Ok
bien
Terminé, temps utilisé: 25 sec
Retirez / remettre la batterie maintenant!
The Following User Says Thank You to pikiche For This Useful Post:
Old 08-01-2011, 14:37   #15 (permalink)
Registered User
Member: 1546367
Sonork: best*
Thanks Meter: 23
100000% work tnx.............
8810 pinout?? timitiz Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 06-11-2012 11:10
Please Help, Pinout of N8810 mobileinfo Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 06-30-2010 15:53
8810 pinouts for dejan flasher !?!?!? makona Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 08-03-2001 04:39
8850 pinouts MDR Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 12-30-2000 00:23
Page generated in 0.44579 seconds with 9 queries
