09-25-2012, 13:30 | #1 (permalink) |
No Life Poster Join Date: Feb 2003 Location: TelServisHalo,Loznica, Serbia Age: 53
Member: 21365 Status: Offline Thanks Meter: 92 | Huawei G6608 COM4 [VCP2] selected module v4.39 Device: Huawei-G6608 Checking data, wait... Action: write flash NAND write: Firmware Huawei-G6608_THEMISPLUS_HW_SS_VDFC210_PCB01_GPRS_MT6235B_ S01.G6608SSW_C210_M49_00_06_2011-10-17_En_Es.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nfi area detection... bootloader version: THEMISPLUS_HW_SS_VDFC210_BOOTLOADER_V005_MT6235B_G 6608SSW_C210_M nfi area detection (4 cores) finished: Ok interface: BROM_DLL_v3.1108.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8C00:8A00 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0044]: 0098:00D000000015 [TOSHIBA] TC58NWM9S3B chip size: 64Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: absent done Set baudrate (115200)... done interesting cpu type found: 6235:8C00:8A00 ram test (40000000)... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/02000000 firmware size: 32Mb ffs size: 32Mb detect sec ro... error:0BF9:S_DA_HANDSET_SEC_INFO_NOT_FOUND detect custom parameters... error:0401:S_CUST_PARA_NOT_SUPPORTED detect project-id... project-id: G6608SSW.C210.M49.00.06 detect NAND info... number of areas/bytes to read: 1:001A0000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... bootloader version: THEMISPLUS_HW_SS_VDFC210_BOOTLOADER_V005_MT6235B_G 6608SSW_C210_M warning: id-page1 area is invalid nfi area detection (0 cores) finished: failed TCL-ID detection... TCL-ID detection done startup code area #1 detection... number of areas/bytes to read: 1:00020000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... number of areas/bytes to read: 1:00020000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... startup code area #1 is invalid startup code area #1 detection done rom info ver: 07 sw version: THEMISPLUS_HW_SS_VDFC210_PCB01_GPRS_MT6235B_S01.G6 608SSW_C210_M49_00_06.BIN project-id: G6608SSW.C210.M49.00.06, 54DF838E code offset: 00000000 ffs offset/size [01]: 02000000/02000000 rom info structure: [protected] type (07), 1 record(s) TCL-ID is absent ===> done nfi area detection... bootloader version: THEMISPLUS_HW_SS_VDFC210_BOOTLOADER_V005_MT6235B_G 6608SSW_C210_M nfi area detection (4 cores) finished: Ok startup code area #1 check... factory firmware detected: THEMISPLUS_HW_SS_VDFC210_PCB01_GPRS_MT6235B_S01.G6 608SSW_C210_M49_00_06.BIN ==================== New firmware found (v.4.39, database date: 18.09.2012): THEMISPLUS_HW_SS_VDFC210_PCB01_GPRS_MT6235B_S01.G6 608SSW_C210_M49_00_06.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare ? Secure Data Logistics or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== startup code area #1 calculation... startup code area #1 fixed number of cores: 4 loading files... number of areas: 4 done write... write bootloader... . . . . . . . . . . . write core... error: can not write flash (0): 0FAF:S_FT_NFB_DOWNLOAD_CODE_FAIL error: last error: 0FAF:S_FT_NFB_DOWNLOAD_CODE_FAIL Disconnect... done Finished, time used: 5 min 5 sec Remove/Install battery now ! So, what now? |
