05-16-2012, 22:34 | #1 (permalink) |
Freak Poster Join Date: Mar 2005 Location: Ports***** UK Age: 44
Member: 126675 Status: Offline Thanks Meter: 13 | Huawei G6608 startup code area #1 can't be fixed After flashing phone is dead. This is original FullFlash from working phone: http://gsmpro.com.pl/Data/Huawei-G66...155345.B4M.bin Code: COM19 [VCP0] selected module v4.13 Device: Huawei-G6608 Checking data, wait... Action: write flash NAND write: Firmware Polski_Huawei-G6608_THEMISPLUS_HW_SS_VDFC210_PCB01_GPRS_MT6235B_S01.G6608SSW_C210_M49_00_06__firmware_20120510-152852.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nfi area detection... nfi scat area detected (4 areas) nfi area detection (4 cores) finished: Ok "format ffs" active interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8C00:8A00 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0043]: 0098:00D000000015 [TOSHIBA] TC58NWM9S3B chip size: 64Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: absent done Set baudrate (921600)... done interesting cpu type found: 6235:8C00:8A00 ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/02000000 firmware size: 32Mb ffs size: 32Mb detect sec ro... detect custom parameters... detect project-id... project-id: G6608SSW.C210.M49.00.06 detect NAND info... number of areas/bytes to read: 1:001A0000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... bootloader version: THEMISPLUS_HW_SS_VDFC210_BOOTLOADER_V005_MT6235B_G6608SSW_C210_M nfi area detection (4 cores) finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... number of areas/bytes to read: 1:00020000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... number of areas/bytes to read: 1:00020000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... startup code area #1 is invalid startup code area #1 detection done rom info ver: 07 sw version: THEMISPLUS_HW_SS_VDFC210_PCB01_GPRS_MT6235B_S01.G6608SSW_C210_M49_00_06.BIN project-id: G6608SSW.C210.M49.00.06, 54DF838E code offset: 00000000 ffs offset/size [01]: 02000000/02000000 rom info structure: [protected] type (07), 1 record(s) TCL-ID is absent ===> done nfi area detection... nfi scat area detected (4 areas) nfi area detection (4 cores) finished: Ok startup code area #1 check... rpl file not found: C:\InfinityBox\MModule\id.00006235.[THEMISPLUS_HW_SS_VDFC210_PCB01_GPRS_MT6235B_S01.G6608SSW_C210_M49_00_06.BIN_8E83DF54].rpl rpl file not found: C:\InfinityBox\MModule\id.00006235._THEMISPLUS_HW_SS_VDFC210_PCB01_GPRS_MT6235B_S01.G6608SSW_C210_M49_00_06.BIN_8E83DF54_.rpl rpl file not found: C:\InfinityBox\MModule\backup_security\id.00006235.[THEMISPLUS_HW_SS_VDFC210_PCB01_GPRS_MT6235B_S01.G6608SSW_C210_M49_00_06.BIN_8E83DF54].rpl rpl file not found: C:\InfinityBox\MModule\backup_security\id.00006235._THEMISPLUS_HW_SS_VDFC210_PCB01_GPRS_MT6235B_S01.G6608SSW_C210_M49_00_06.BIN_8E83DF54_.rpl ==================== warning: unknown firmware: THEMISPLUS_HW_SS_VDFC210_PCB01_GPRS_MT6235B_S01.G6608SSW_C210_M49_00_06.BIN_8E83DF54 Unknown firmware found (v.4.13, database date: 29.01.2012), user action required: 1. download latest software from support area and try again 2. if no still luck follow the next procedure: - find good working phone with the same firmware: THEMISPLUS_HW_SS_VDFC210_PCB01_GPRS_MT6235B_S01.G6608SSW_C210_M49_00_06.BIN - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) - be little bit patient and wait update ==================== error: startup code area #1 can't be fixed You can flash phone now but can not finalize it, in most cases phone CAN NOT power-on. Do you want to continue anyway ? number of cores: 4 loading files... number of areas: 4 done write... write bootloader... . . write core... warning: can not format: HW_STORAGE_NOR is not present Format... autodetection mode... Format done Disconnect... done Finished, time used: 8 min 4 sec Remove/Install battery now ! |
Help: Forgot my 6110 user lock code!! | GByte9 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 02-26-2016 14:52 |
PIN1/PIN2 CODE | Jon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 12-26-2012 04:40 |
5110 Security Code Help! | cahrisma | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 07-05-2010 09:04 |
Orange IL, Nokia 5110 GSM codes... | rosso11 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 11-05-1999 21:38 |
