Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Mar 2005 Location: Poland - lubuskie Age: 33
Member: 126675 Status: Offline Thanks: 76
| Huawei G6608 startup code area #1 can't be fixed Hello. After flashing phone is dead. This is original FullFlash from working phone: http://gsmpro.com.pl/Data/Huawei-G66...155345.B4M.bin Code: COM19 [VCP0] selected module v4.13 Device: Huawei-G6608 Checking data, wait... Action: write flash NAND write: Firmware Polski_Huawei-G6608_THEMISPLUS_HW_SS_VDFC210_PCB01_GPRS_MT6235B_S01.G6608SSW_C210_M49_00_06__firmware_20120510-152852.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nfi area detection... nfi scat area detected (4 areas) nfi area detection (4 cores) finished: Ok "format ffs" active interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8C00:8A00 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0043]: 0098:00D000000015 [TOSHIBA] TC58NWM9S3B chip size: 64Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: absent done Set baudrate (921600)... done interesting cpu type found: 6235:8C00:8A00 ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/02000000 firmware size: 32Mb ffs size: 32Mb detect sec ro... detect custom parameters... detect project-id... project-id: G6608SSW.C210.M49.00.06 detect NAND info... number of areas/bytes to read: 1:001A0000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... bootloader version: THEMISPLUS_HW_SS_VDFC210_BOOTLOADER_V005_MT6235B_G6608SSW_C210_M nfi area detection (4 cores) finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... number of areas/bytes to read: 1:00020000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... number of areas/bytes to read: 1:00020000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... startup code area #1 is invalid startup code area #1 detection done rom info ver: 07 sw version: THEMISPLUS_HW_SS_VDFC210_PCB01_GPRS_MT6235B_S01.G6608SSW_C210_M49_00_06.BIN project-id: G6608SSW.C210.M49.00.06, 54DF838E code offset: 00000000 ffs offset/size [01]: 02000000/02000000 rom info structure: [protected] type (07), 1 record(s) TCL-ID is absent ===> done nfi area detection... nfi scat area detected (4 areas) nfi area detection (4 cores) finished: Ok startup code area #1 check... rpl file not found: C:\InfinityBox\MModule\id.00006235.[THEMISPLUS_HW_SS_VDFC210_PCB01_GPRS_MT6235B_S01.G6608SSW_C210_M49_00_06.BIN_8E83DF54].rpl rpl file not found: C:\InfinityBox\MModule\id.00006235._THEMISPLUS_HW_SS_VDFC210_PCB01_GPRS_MT6235B_S01.G6608SSW_C210_M49_00_06.BIN_8E83DF54_.rpl rpl file not found: C:\InfinityBox\MModule\backup_security\id.00006235.[THEMISPLUS_HW_SS_VDFC210_PCB01_GPRS_MT6235B_S01.G6608SSW_C210_M49_00_06.BIN_8E83DF54].rpl rpl file not found: C:\InfinityBox\MModule\backup_security\id.00006235._THEMISPLUS_HW_SS_VDFC210_PCB01_GPRS_MT6235B_S01.G6608SSW_C210_M49_00_06.BIN_8E83DF54_.rpl ==================== warning: unknown firmware: THEMISPLUS_HW_SS_VDFC210_PCB01_GPRS_MT6235B_S01.G6608SSW_C210_M49_00_06.BIN_8E83DF54 Unknown firmware found (v.4.13, database date: 29.01.2012), user action required: 1. download latest software from support area and try again 2. if no still luck follow the next procedure: - find good working phone with the same firmware: THEMISPLUS_HW_SS_VDFC210_PCB01_GPRS_MT6235B_S01.G6608SSW_C210_M49_00_06.BIN - make "Read full flash" operation - send flash backup files to support: support@infinity-box.biz or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) - be little bit patient and wait update ==================== error: startup code area #1 can't be fixed You can flash phone now but can not finalize it, in most cases phone CAN NOT power-on. Do you want to continue anyway ? number of cores: 4 loading files... number of areas: 4 done write... write bootloader... . . write core... warning: can not format: HW_STORAGE_NOR is not present Format... autodetection mode... Format done Disconnect... done Finished, time used: 8 min 4 sec Remove/Install battery now ! |
| | #2 (permalink) |
| Product Supporter ![]() ![]() ![]() Join Date: May 2005 Age: 36
Member: 148515 Status: Offline Thanks: 2,319
| hello! this file can be written without this error Huawei-G6608_THEMISPLUS_HW_SS_VDFC210_PCB01_GPRS_MT6235B_ S01.G6608SSW_C210_M49_00_06_2011-10-17_64m_En_Es.B4M.bin - 4shared.com - online file sharing and storage - download - Abc olk |
| | #3 (permalink) |
| Not work. I can not even load the file: Code: Wait... trying to select model: /G6608 model selected via command line: Huawei-G6608 Device: Huawei-G6608 Initialization done Loading file v.01... Loading failed, probably damaged data file |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| PIN1/PIN2 CODE | Jon | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 1 | 12-26-2012 03:40 |
| Help: Forgot my 6110 user lock code!! | GByte9 | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 5 | 05-10-2012 14:14 |
| 5110 Security Code Help! | cahrisma | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 6 | 07-05-2010 09:04 |
| Orange IL, Nokia 5110 GSM codes... | rosso11 | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 0 | 11-05-1999 20:38 |
| Pin Code | Verdonn | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 0 | 10-23-1999 15:35 |
