![]() | #1 (permalink) |
Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2007 Location: Sri Lanka-Beruwala
Member: 617198 Status: Offline Sonork: 100.1606436 Thanks Meter: 214 | Huawei g6620 unlock done Used gs101 cable COM14 [VCP0] selected module v3.77 Action: read unlock codes unlock method: read codes Model: Huawei-G6620 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6253:8A02:8A00]... CPU: MT6253 chip: 0000:0000:000F status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6253,E02 Date: 2000.00.00 Version: 1.0 Version: G6620SS.C200.M40.04.10 Version: CKT53_12832_09B_HW 116 byte(s) read imei: 351XXXXXXXXXX connection Ok 217 byte(s) read 38 byte(s) read Phone lock: Off Phone code: 1234 205 byte(s) read reading data... 220 byte(s) read lock[1] code: + 36498824 lock[2] code: + default lock[3] code: + 1122 lock[4] code: - default lock[5] code: - default lock[6] code: + default lock[7] code: + default if code is not accepted by phone: - make full flash backup for emergency case - flash phone with good eeprom file - Power-On phone without sim-card - Power-Off phone - read unlock codes - restore original imei Finished, time used: 22 sec Remove/Install battery now ! |
The Following 41 Users Say Thank You to Risan Fassy For This Useful Post: |
![]() | #2 (permalink) |
Product Supporter ![]() ![]() ![]() Join Date: Jun 2009 Location: private
Member: 1043909 Status: Offline Thanks Meter: 61,453 | Thanks a lot for good test reports ! We will be waiting for more test reports from other users. @all Also, we still need to buy G6620 sample phone to finalize all required tests regarding flashing. If somebody can sell to us good working phone, please, contact to [email protected] @all again Please, try to use this new software for Huawei-G6620 unlock: http://www.infinity-box.com/download...dule_v3.77.rar 1. make full flash backup for emergency case ! 2. try to unlock phone with "read unlock codes" method only, DO not try other unlock methods ! Please, post here operation log. Waiting for your results. Last edited by YellowBoss; 02-27-2011 at 08:44. |
The Following 17 Users Say Thank You to YellowBoss For This Useful Post: |
![]() | #3 (permalink) |
Member: 617198 Status: Offline Sonork: 100.1606436 Thanks Meter: 214 | I am sorry i forget to thanks for your software, that really the phone is not mine, i can ask any reasonable prize not a demand,when she agree i can send it to you, if you don't mind could you send me the prize detail to my email or as a private massage? thanks, best wishes for the team. |
![]() | #4 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Aug 2006 Location: pakistan
Member: 334999 Status: Offline Thanks Meter: 225 | G7010 not unloc done with 3.77 version COM18 [VCP1] selected module v3.77 Action: read unlock codes unlock method: read codes Model: Huawei-G6620 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6253:8A02:8A00]... CPU: MT6253 chip: 0000:0000:000F status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6253,E02 Date: 2000.00.00 Version: 1.0 Version: ESPC113B146SSC Version: VER.B 116 byte(s) read imei: 1400E600370016 connection Ok 217 byte(s) read reading data #2... reading data #3... reading data #4... reading data #5... 8 byte(s) read error: source data size is less than expected 205 byte(s) read reading data... reading data #2... reading data #3... 0 byte(s) read warning: communication fault error: operation failed ! Finished, time used: 9 sec Remove/Install battery now ! |
![]() | #5 (permalink) | |
Member: 1043909 Status: Offline Thanks Meter: 61,453 | Quote:
G7010 can not be unlocked yet, because we have made software for G6620 only. If you want to get software for G7010, make this: Read full flash from G7010 (select G6620 model) and send full flash backup file (or link) to [email protected] We will check your file and try to make update. | |
The Following 3 Users Say Thank You to YellowBoss For This Useful Post: |
![]() | #6 (permalink) | |
Super Moderator ![]() Join Date: Jul 2009 Location: .:India:.
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,830 ![]() | Quote:
Thanks A Lot For Good This Test Reports ! Special Thanks For Infinity All Tools | |
The Following User Says Thank You to MyGSM World For This Useful Post: |
![]() | #7 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2004 Location: ORAN-ALGERIE Age: 50
Member: 64213 Status: Offline Thanks Meter: 493 | G6620 enjoy unlocked COM15 [VCP0] selected module v3.77 Action: read unlock codes unlock method: read codes Model: Huawei-G6620 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6253:8A02:8A00]... CPU: MT6253 chip: 0000:0000:000F status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6253,E02 Date: 2000.00.00 Version: 1.0 Version: G6620SS.C210.M40.04.05 Version: CKT53_12832_09B_HW 116 byte(s) read imei: 35194804282362 connection Ok 217 byte(s) read 38 byte(s) read Phone lock: Off Phone code: 1234 205 byte(s) read reading data... 220 byte(s) read lock[1] code: + 57516523 lock[2] code: + default lock[3] code: + 1122 lock[4] code: - default lock[5] code: - default lock[6] code: + default lock[7] code: + default if code is not accepted by phone: - make full flash backup for emergency case - flash phone with good eeprom file - Power-On phone without sim-card - Power-Off phone - read unlock codes - restore original imei Finished, time used: 11 sec Remove/Install battery now ! BIG TXS INFINITY TEAM FOR THIS HARD WORK AND DONE ZINEGSM@ |
The Following 4 Users Say Thank You to zine For This Useful Post: |
![]() | #8 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: May 2007 Location: zaragoza spain
Member: 505498 Status: Offline Thanks Meter: 46 | COM4 [VCP2] selected module v3.77 Action: read unlock codes unlock method: read codes Model: Huawei-G6620 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6253:8A02:8A00]... CPU: MT6253 chip: 0000:0000:000F status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6253,E02 Date: 2000.00.00 Version: 1.0 Version: G6620SS.C210.M40.04.05 Version: CKT53_12832_09B_HW 116 byte(s) read imei: 35194804278313 connection Ok 217 byte(s) read 38 byte(s) read Phone lock: Off Phone code: 1234 205 byte(s) read reading data... 220 byte(s) read lock[1] code: + 43617530 lock[2] code: + default lock[3] code: + 1122 lock[4] code: - default lock[5] code: - default lock[6] code: + default lock[7] code: + default if code is not accepted by phone: - make full flash backup for emergency case - flash phone with good eeprom file - Power-On phone without sim-card - Power-Off phone - read unlock codes - restore original imei Finished, time used: 12 sec Remove/Install battery now ! |
The Following 4 Users Say Thank You to samirho For This Useful Post: |
![]() | #10 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: May 2005 Location: New Area
Member: 148814 Status: Offline Sonork: 100.1576882 Thanks Meter: 5,013 ![]() | can send mobile if interested...PM me from Vodafone Spain..barnd new WBR |
The Following User Says Thank You to boucettay For This Useful Post: |
![]() | #13 (permalink) | |
Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2005 Location: infinity-box
Member: 130995 Status: Offline Thanks Meter: 35,230 | Quote:
btw, here is a thread about G6620. I think it will be better do not ask all possible questions about all phones in one thread but create new thread with separate questions. | |
![]() | #14 (permalink) | |
Member: 334999 Status: Offline Thanks Meter: 225 | here is the link of full flash backup Quote:
The Following 2 Users Say Thank You to asif_ae For This Useful Post: |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
FAQ about unlock n0kia | man0n | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 11-29-2010 19:06 |
