03-10-2011, 05:59 | #1 (permalink) |
Freak Poster Join Date: Jan 2010 Location: Cambodia
Member: 1218675 Status: Offline Thanks Meter: 24 | Huawei G6620 unlock success See more detail log: COM3 [VCP0] selected module v3.79 Action: read unlock codes unlock method: read codes Model: Huawei-G6620 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6253:8A02:8A00]... CPU: MT6253 chip: 0000:0000:000F status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6253,E02 Date: 2000.00.00 Version: 1.0 Version: G6620SD.C206.M40.08.02 Version: CKT53_12832_09B_HW ==================== New firmware found (v.3.79, database date: 07.03.2011): G6620SD.C206.M40.08.02 This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== 116 byte(s) read imei: 35194804254583 connection Ok 217 byte(s) read 38 byte(s) read Phone lock: Off Phone code: 1234 205 byte(s) read reading data... 220 byte(s) read lock[1] code: + 39507030 lock[2] code: + default lock[3] code: + 1122 lock[4] code: - default lock[5] code: - default lock[6] code: + default lock[7] code: + default if code is not accepted by phone: - make full flash backup for emergency case - flash phone with good eeprom file - Power-On phone without sim-card - Power-Off phone - read unlock codes - restore original imei Finished, time used: 1 min 44 sec Remove/Install battery now ! Here is it full flash that i read and more detail about phone: Huawei-G6620_SJ_S0A_HW_BEELINE_PCB01_GPRS_MT6253_S00.G662 0SD_C206_M40_08_02.BIN_FLNTY6801111190KC__fullflas h_20110310-105643.B0M.zip - 4shared.com - online file sharing and storage - download |
03-10-2011, 06:24 | #2 (permalink) | |
No Life Poster Join Date: Nov 2008 Location: gsm hosting
Member: 907098 Status: Offline Sonork: 100.1601140 Thanks Meter: 705 | Quote:
03-10-2011, 08:19 | #6 (permalink) | |
Freak Poster Join Date: Aug 2007
Member: 568259 Status: Offline Thanks Meter: 52 | Quote:
in this case try this: 1. insert any sim card into phone 2. power-on phone with sim card (enter pin-code if need) 3. power-off phone by "Power" button (do not remove battery) 4. try to read unlock codes and post results here if codes still can not be read well make the same, but enter one wrong unlock code after step 2. Try to read codes again. Let's see results. | |
03-11-2011, 05:12 | #9 (permalink) | |
Member: 1218675 Status: Offline Thanks Meter: 24 | Quote:
i confuse that just read code the software will unlock directly, that's my fault. and i'm so sorry cuz the owner take it back. | |
03-26-2011, 08:22 | #10 (permalink) |
Freak Poster Join Date: Jul 2005 Location: .........
Member: 165303 Status: Offline Sonork: 100.1580123 Thanks Meter: 57 | unlock don COM18 [VCP0] selected module v3.80 Action: read unlock codes unlock method: read codes Model: Huawei-G6620 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6253:8A02:8A00]... CPU: MT6253 chip: 0000:0000:000F status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6253,E02 Date: 2000.00.00 Version: 1.0 Version: G6620SS.C200.M40.04.10 Version: CKT53_12832_09B_HW ==================== New firmware found (v.3.80, database date: 20.03.2011): G6620SS.C200.M40.04.10 This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== 116 byte(s) read imei: 35194804291280 connection Ok 217 byte(s) read 38 byte(s) read Phone lock: Off Phone code: 1234 205 byte(s) read reading data... 220 byte(s) read lock[1] code: + 37732842 lock[2] code: + default lock[3] code: + 1122 lock[4] code: - default lock[5] code: - default lock[6] code: + default lock[7] code: + default if phone do not ask for a code try: *983*8284# if code is not accepted by phone: - make full flash backup for emergency case - flash phone with good eeprom file - Power-On phone without sim-card - Power-Off phone (do not remove battery) - read unlock codes - restore original imei Finished, time used: 18 sec Remove/Install battery now ! |
The Following User Says Thank You to nvad For This Useful Post: |
08-21-2011, 17:33 | #11 (permalink) |
No Life Poster Join Date: Apr 2002 Location: The Green Mile
Member: 11325 Status: Offline Thanks Meter: 266 | Mine unlocked after following the procedure of entering 12345678, powering it off and then retry to read the codes again. Worked 100% OK Phone is from T-Mobile UK. Sent flash to support. Thanks Infinity team for your great tools and support! Here is log 1st log :- COM15 [VCP0] selected module v4.01 Action: read unlock codes unlock method: read codes Model: Huawei-G6620 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6253:8A02:8A00]... CPU: MT6253 high speed boot On chip: 0000:0000:000F status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6253,E02 Date: 2000.00.00 Version: 1.0 Version: G6620SS.C200.M40.04.13N Version: CKT53_12832_09B_HW ==================== New firmware found (v.4.01, database date: 19.08.2011): G6620SS.C200.M40.04.13N This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare – Secure Data Logistics or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== 116 byte(s) read imei: 35194804958101 connection Ok 217 byte(s) read 38 byte(s) read Phone lock: Off Phone code: 1234 205 byte(s) read reading data... 220 byte(s) read lock[1] code: + default lock[2] code: + default lock[3] code: + 1122 lock[4] code: - default lock[5] code: - default lock[6] code: + default lock[7] code: + default if code is not accepted by phone: - insert wrong sim card into phone - power-On phone - enter code: 12345678 - wait 10 seconds - power-Off phone via "Power" button (do not remove battery) - read unlock codes again Finished, time used: 14 sec Remove/Install battery now ! Here is 2nd log:- COM15 [VCP0] selected module v4.01 Action: read unlock codes unlock method: read codes Model: Huawei-G6620 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6253:8A02:8A00]... CPU: MT6253 high speed boot On chip: 0000:0000:000F status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6253,E02 Date: 2000.00.00 Version: 1.0 Version: G6620SS.C200.M40.04.13N Version: CKT53_12832_09B_HW ==================== New firmware found (v.4.01, database date: 19.08.2011): G6620SS.C200.M40.04.13N This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare – Secure Data Logistics or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== 116 byte(s) read imei: 35194804958101 connection Ok 217 byte(s) read 38 byte(s) read Phone lock: Off Phone code: 1234 205 byte(s) read reading data... 220 byte(s) read lock[1] code: + 39279755 lock[2] code: + default lock[3] code: + 1122 lock[4] code: - default lock[5] code: - default lock[6] code: + default lock[7] code: + default if phone do not ask for a code try: *983*8284# if code is not accepted by phone: - make full flash backup for emergency case - flash phone with good eeprom file - Power-On phone without sim-card - Power-Off phone (do not remove battery) - read unlock codes - restore original imei Finished, time used: 15 sec Remove/Install battery now ! |
The Following User Says Thank You to Burnt Cobba For This Useful Post: |
08-23-2011, 18:00 | #12 (permalink) |
No Life Poster Join Date: Apr 2004 Location: MOON
Member: 60899 Status: Offline Thanks Meter: 792 | unlocked ok thank you. COM7 [VCP0] selected module v4.01 Action: read unlock codes unlock method: read codes Model: Huawei-G6620 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6253:8A02:8A00]... CPU: MT6253 high speed boot On chip: 0000:0000:000F status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6253,E02 Date: 2000.00.00 Version: 1.0 Version: G6620SS.C200.M40.04.10 Version: CKT53_12832_09B_HW ==================== New firmware found (v.4.01, database date: 19.08.2011): G6620SS.C200.M40.04.10 This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare – Secure Data Logistics or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== 116 byte(s) read imei: 35194804987181 connection Ok 217 byte(s) read 38 byte(s) read Phone lock: Off Phone code: 1234 205 byte(s) read reading data... 220 byte(s) read lock[1] code: + 36047716 lock[2] code: + default lock[3] code: + 1122 lock[4] code: - default lock[5] code: - default lock[6] code: + default lock[7] code: + default if phone do not ask for a code try: *983*8284# if code is not accepted by phone: - make full flash backup for emergency case - flash phone with good eeprom file - Power-On phone without sim-card - Power-Off phone (do not remove battery) - read unlock codes - restore original imei Finished, time used: 16 sec Remove/Install battery now ! |
09-13-2011, 21:27 | #13 (permalink) |
Insane Poster Join Date: Feb 2009 Location: spain
Member: 975300 Status: Offline Sonork: 100.1593908 Thanks Meter: 21 | COM393 [VCP0] selected module v4.01 Action: read unlock codes unlock method: read codes Model: Huawei-G6620 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6253:8A02:8A00]... CPU: MT6253 high speed boot On chip: 0000:0000:000F status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6253,E02 Date: 2000.00.00 Version: 1.0 Version: G6620SS.C210.M40.04.05 Version: CKT53_12832_09B_HW ==================== New firmware found (v.4.01, database date: 19.08.2011): G6620SS.C210.M40.04.05 This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare – Secure Data Logistics or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== 116 byte(s) read imei: 3519xxxxxxxxxx connection Ok 217 byte(s) read 38 byte(s) read Phone lock: Off Phone code: 1234 205 byte(s) read reading data... 220 byte(s) read lock[1] code: + 35833516 lock[2] code: + default lock[3] code: + 1122 lock[4] code: - default lock[5] code: - default lock[6] code: + default lock[7] code: + default if phone do not ask for a code try: *983*8284# if code is not accepted by phone: - make full flash backup for emergency case - flash phone with good eeprom file - Power-On phone without sim-card - Power-Off phone (do not remove battery) - read unlock codes - restore original imei Finished, time used: 20 sec Remove/Install battery now ! my huawei g6620 unlocked successefully |
09-14-2011, 21:08 | #14 (permalink) | |
Each test report with attached logs is very important for us so we can see how is Infinity-Box software works, what is phone hardware configuration (f.e. flash chip type) and what is possible problems (so we will be able to fix it) and successfully done work. | |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
FAQ about unlock n0kia | man0n | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 11-29-2010 19:06 |
