Huawei G700(G700-U10) Error/unsupported :( Hello, Phone is working (But buggy ) Code: Operation : Check / Read Info [ v1.30 ] Code: Operation : Check / Read Info [ v1.30 ] |
What do you want whit phone...?? ((flash, read code, format, read firm, etc)) |
I can't find those models at all. When find 4-6 pcs of different models - will be added. |
phone have virus(monkey test etc) i want to repair format or flash do you have tool? |
same problem in g610 u20 |
some phones have boot protected.... |
Same problem with huawei g610 u20 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 101 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6583 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6583|6589_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage Will use Secure DA for boot target DA Select done , sending DA Ver : MTK_AllInOne_DA_v3.3001.00.00 DA Stat : v3.2 on BBID : 0x86 Error : DA init Failed! Error code : 0x5 LErr : 0000 Boot Error! Operation Failed Elapsed: 00:00:22 Reconnect Power/Cable! Operation : Check / Read Info [ v1.40 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 101 ] Sync... Brom Init not done Boot Error! Operation Failed Elapsed: 00:00:13 Reconnect Power/Cable! |
Error! SECURE BOOT target! Check Model Settings! same problem in INFOCUS M330,PHONE problem is patternlock,i cant able to read pattern lock and all. Operation : Read Pattern/DP Lock [ v1.40 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6592 BB_CPU_HW : CA00 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6592_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 Error : DA init Failed! Error code : 0x2 LErr : 2001 Error! SECURE BOOT target! Check Model Settings! Boot Error! Operation Failed Elapsed: 00:00:08 Reconnect Power/Cable! |
Same problem where is supporter reply ? any way to solve this problem |
huawei y330 u05 Operation : Remove Viruses [SmartAV] [ v1.40 ] SmartAV Conf : 100/80/2000 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 Error : DA init Failed! Error code : 0x2 LErr : 2001 Error! SECURE BOOT target! Check Model Settings! Boot Error! Operation Failed Elapsed: 00:00:16 Reconnect Power/Cable! |
