09-20-2015, 15:20 | #1 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Huawei G700(G700-U10) Error/unsupported :( Phone is working (But buggy ) Code: Operation : Check / Read Info [ v1.30 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6583 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6583|6589_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 Error : DA init Failed! Error code : 0x2 LErr : 2001 Error! SECURE BOOT targted! Check Model Settings! Boot Error! Operation Failed Elapsed: 00:00:06 Reconnect Power/Cable! Code: Operation : Check / Read Info [ v1.30 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6583 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6583|6589_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage Will use Secure DA for boot target DA Select done , sending DA Ver : MTK_AllInOne_DA_v3.3001.00.00 DA Stat : v3.2 on BBID : 0x86 DA Sent. Configure setting now ... DA start Failed at final stage! Check battery , cable , drivers and try try again Boot Error! Operation Failed Elapsed: 00:00:07 Reconnect Power/Cable! |
01-02-2016, 09:40 | #7 (permalink) |
Junior Member Join Date: May 2010
Member: 1297824 Status: Offline Thanks Meter: 2 | Same problem with huawei g610 u20 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 101 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6583 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6583|6589_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage Will use Secure DA for boot target DA Select done , sending DA Ver : MTK_AllInOne_DA_v3.3001.00.00 DA Stat : v3.2 on BBID : 0x86 Error : DA init Failed! Error code : 0x5 LErr : 0000 Boot Error! Operation Failed Elapsed: 00:00:22 Reconnect Power/Cable! Operation : Check / Read Info [ v1.40 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 101 ] Sync... Brom Init not done Boot Error! Operation Failed Elapsed: 00:00:13 Reconnect Power/Cable! |
01-14-2016, 11:47 | #8 (permalink) |
No Life Poster Join Date: Jul 2009 Location: CHENNAI
Member: 1079392 Status: Offline Thanks Meter: 444 | Error! SECURE BOOT target! Check Model Settings! same problem in INFOCUS M330,PHONE problem is patternlock,i cant able to read pattern lock and all. Operation : Read Pattern/DP Lock [ v1.40 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6592 BB_CPU_HW : CA00 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6592_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 Error : DA init Failed! Error code : 0x2 LErr : 2001 Error! SECURE BOOT target! Check Model Settings! Boot Error! Operation Failed Elapsed: 00:00:08 Reconnect Power/Cable! |
02-07-2016, 21:23 | #10 (permalink) |
Freak Poster Join Date: Oct 2007
Member: 617539 Status: Offline Thanks Meter: 64 | huawei y330 u05 Operation : Remove Viruses [SmartAV] [ v1.40 ] SmartAV Conf : 100/80/2000 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 Error : DA init Failed! Error code : 0x2 LErr : 2001 Error! SECURE BOOT target! Check Model Settings! Boot Error! Operation Failed Elapsed: 00:00:16 Reconnect Power/Cable! |
04-25-2016, 18:57 | #11 (permalink) | |
No Life Poster Join Date: Sep 2015 Location: Earth
Member: 2455344 Status: Offline Sonork: Ask me Thanks Meter: 420 | Quote:
