Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| Crazy Poster ![]() ![]() ![]() Join Date: Aug 2008
Member: 836938 Status: Offline Thanks: 35
| Huawei G7007 After Unlock DEAD. Help I try unlock a Huawei G7007 Movistar. The Shell select automatic Action: read unlock codes unlock method: read codes But the code NP not good, after enter code phone locked. Before: 1. I make FULL BACKUP 2. Unlock by Action: "sp-unlock" unlock method: smart fast and phone DEAD, LCD in white color and blinking. 3. I try to restore the previus backup dead. Now, when try power on de phone, this show the Logo of Company Movistart and before LCD in white color and blinking. Help Thanks ************************************* Here LOG HISTORY OPERATION ************************************* Unlock method: read codes COM5 [VCP0] selected module v3.75 Action: read unlock codes unlock method: read codes Model: Huawei-G7007 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8A04:8A01]... CPU: MT6235 chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6235,E04 Date: 2000.00.00 Version: 1.0 Version: ENGC13B139 Version: VER.A 80 byte(s) read imei: 86334900000436 connection Ok 185 byte(s) read 38 byte(s) read Phone lock: Off Phone code: 1234 173 byte(s) read reading data... 972 byte(s) read lock[1] code: + 12345678 lock[2] code: + 56781234 lock[3] code: + 1122 lock[4] code: - 3344 lock[5] code: - 5566 lock[6] code: + 7788 lock[7] code: + 9900 if code is not accepted by phone: - make full flash backup for emergency case - flash phone with good eeprom file - Power-On phone without sim-card - Power-Off phone - read unlock codes - restore original imei Finished, time used: 15 sec Remove/Install battery now ! READ INFORMATION Action: read/check information Model: Huawei-G7007 Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6235, E04 Hardware version: VER.A Software version: ENGC13B139" Software date: 2000.00.00 Barcode: 020RGK4C02000747 imei-1: 863349000004363 Finished, time used: 12 sec Remove/Install battery now ! READ DETAILED INFORMATION COM5 [VCP0] selected module v3.75 Device: Huawei-G7007 Checking data, wait... Action: read/check information interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0053]: 00AD:00A100000015 [HYNIX] H8BCS0PG0MBP chip size: 128Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: S_DA_RAM_ERROR done Set baudrate (460800)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/06000000 firmware size: 32Mb ffs size: 96Mb detect sec ro... detect custom parameters... detect project-id... project-id: ENGC13B139 detect NAND info... number of areas/bytes to read: 1:001A0000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... external bootloader is not present bootloader version: HUAWEI35_08B_BOOTLOADER_V005_MT6235B_ENGC13B139.bi n nfi area detection (3 cores) finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... number of areas/bytes to read: 1:00020000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... number of areas/bytes to read: 1:00020000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... error: unexpected answer: startup code area #1 is valid startup code area #1 detection done rom info ver: 05 sw version: HUAWEI35_08B_PCB01_GPRS_MT6235B_S01.ENGC13B139.BIN project-id: ENGC13B139, 9876D74C code offset: 00000000 ffs offset/size [01]: 02000000/06000000 rom info structure: [protected] type (05), 1 record(s) TCL-ID is absent ===> done Disconnect... done file saved: c:\InfinityBox\MModule\backup_security\Huawei-G7007_HUAWEI35_08B_PCB01_GPRS_MT6235B_S01.ENGC13B1 39__system_log_20110623-153023.B4X.bin Finished, time used: 1 min 47 sec Remove/Install battery now ! READ FULL FLASH COM5 [VCP0] selected module v3.75 Device: Huawei-G7007 Checking data, wait... Action: read firmware NAND interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0053]: 00AD:00A100000015 [HYNIX] H8BCS0PG0MBP chip size: 128Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: S_DA_RAM_ERROR done Set baudrate (460800)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/06000000 firmware size: 32Mb ffs size: 96Mb detect sec ro... detect custom parameters... detect project-id... project-id: ENGC13B139 detect NAND info... number of areas/bytes to read: 1:001A0000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... external bootloader is not present bootloader version: HUAWEI35_08B_BOOTLOADER_V005_MT6235B_ENGC13B139.bi n nfi area detection (3 cores) finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... number of areas/bytes to read: 1:00020000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... number of areas/bytes to read: 1:00020000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... error: unexpected answer: startup code area #1 is valid startup code area #1 detection done rom info ver: 05 sw version: HUAWEI35_08B_PCB01_GPRS_MT6235B_S01.ENGC13B139.BIN project-id: ENGC13B139, 9876D74C code offset: 00000000 ffs offset/size [01]: 02000000/06000000 rom info structure: [protected] type (05), 1 record(s) TCL-ID is absent ===> done area size: 32Mb number of areas/bytes to read: 1:02000000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... file saved: C:\InfinityBox\MModule\Read Full Flash\Huawei-G7007_HUAWEI35_08B_PCB01_GPRS_MT6235B_S01.ENGC13B1 39__firmware_20110623-155007.B4M.bin Disconnect... done file saved: c:\InfinityBox\MModule\backup_security\Huawei-G7007_HUAWEI35_08B_PCB01_GPRS_MT6235B_S01.ENGC13B1 39__system_log_20110623-155119.B4X.bin Finished, time used: 20 min 3 sec Remove/Install battery now ! Unlock method: smart fast COM5 [VCP0] selected module v3.75 Action: "sp-unlock" unlock method: smart fast Model: Huawei-G7007 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8A04:8A01]... CPU: MT6235 chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6235,E04 Date: 2000.00.00 Version: 1.0 Version: ENGC13B139 Version: VER.A 80 byte(s) read imei: 86334900000436 connection Ok 185 byte(s) read reading data... reading data #2... building new data... writing data... 173 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 29 sec Remove/Install battery now ! RESTORE ORIGINAL PHONE FLASH THE PREVIUS BACKUP Loading file v.02... Huawei-G7007_HUAWEI35_08B_PCB01_GPRS_MT6235B_S01.ENGC13B1 39__firmware_20110623-155007.B4M.bin loaded usb bootloader (file) is absent rom info ver: 05 sw version: HUAWEI35_08B_PCB01_GPRS_MT6235B_S01.ENGC13B139.BIN project-id: ENGC13B139, 9876D74C code offset: 00000000 ffs offset/size [01]: 02000000/06000000 rom info structure: [protected] type (05), 1 record(s) TCL-ID is absent file w/protection: startup code area #1 ==== [23/06/2011 16:39:04] ==== COM5 [VCP0] selected module v3.75 Device: Huawei-G7007 Checking data, wait... Action: write flash NAND write: Firmware Huawei-G7007_HUAWEI35_08B_PCB01_GPRS_MT6235B_S01.ENGC13B1 39__firmware_20110623-155007.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs firmware patch (general #0)... done firmware patch (sp-lock #1)... not required firmware patch (sp-lock #2)... not required nfi area detection... external bootloader is not present bootloader version: HUAWEI35_08B_BOOTLOADER_V005_MT6235B_ENGC13B139.bi n nfi area detection (3 cores) finished: Ok interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0053]: 00AD:00A100000015 [HYNIX] H8BCS0PG0MBP chip size: 128Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: S_DA_RAM_ERROR done Set baudrate (460800)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/06000000 firmware size: 32Mb ffs size: 96Mb detect sec ro... detect custom parameters... detect project-id... project-id: ENGC13B139 detect NAND info... number of areas/bytes to read: 1:001A0000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... external bootloader is not present bootloader version: HUAWEI35_08B_BOOTLOADER_V005_MT6235B_ENGC13B139.bi n nfi area detection (3 cores) finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... number of areas/bytes to read: 1:00020000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... number of areas/bytes to read: 1:00020000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... error: unexpected answer: startup code area #1 is valid startup code area #1 detection done rom info ver: 05 sw version: HUAWEI35_08B_PCB01_GPRS_MT6235B_S01.ENGC13B139.BIN project-id: ENGC13B139, 9876D74C code offset: 00000000 ffs offset/size [01]: 02000000/06000000 rom info structure: [protected] type (05), 1 record(s) TCL-ID is absent ===> done nfi area detection... external bootloader is not present bootloader version: HUAWEI35_08B_BOOTLOADER_V005_MT6235B_ENGC13B139.bi n nfi area detection (3 cores) finished: Ok startup code area #1 check... startup code area #1 calculation... startup code area #1 fixed number of cores: 3 loading files... number of areas: 3 done write... write bootloader... . . . . . write core... Disconnect... done file saved: c:\InfinityBox\MModule\backup_security\Huawei-G7007_HUAWEI35_08B_PCB01_GPRS_MT6235B_S01.ENGC13B1 39__system_log_20110623-165204.B4X.bin Finished, time used: 13 min 0 sec Remove/Install battery now ! |
| | #2 (permalink) |
| Product Supporter ![]() ![]() ![]() Join Date: Nov 2010 Location: inside the earth Age: 5
Member: 1549240 Status: Offline Sonork: 100.1593677 Thanks: 480
| bro try download new file from support area must be same as readed backup and flash phone and post result |
| The Following User Says Thank You to ORANGE MOB For This Useful Post: |
| | #4 (permalink) |
| Junior Member Join Date: Jul 2011
Member: 1610356 Status: Offline Thanks: 0
| please unlock my g7007 imei : 357221030240684 and send me code xxx92@abv.bg .Thansk |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Unlocking 5190 | Ryu | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 23 | 09-16-2012 23:57 |
| my 8810 is phone locked ,can somebody please help | duyphuc | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 16 | 02-01-2012 05:18 |
| HELP!!! BACKGROUND SCREEN LOGO | Michael Go | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 6 | 12-25-2011 23:56 |
| Eeprom dump lost, help needed. | CAMILO | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 6 | 11-29-2010 18:04 |
| Help with 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 3 | 05-25-2009 16:29 |
