Huawei G7007 Not supported COM5 [ProlificSerial0] selected module v3.99 Action: read unlock codes unlock method: read codes Model: Huawei-G7007 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8A04:8A01]... CPU: MT6235 high speed boot On chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6235,E04 Date: 2000.00.00 Version: 1.0 Version: ENGC27B162 Version: VER.B 80 byte(s) read imei: 86334900067463 connection Ok 185 byte(s) read 38 byte(s) read Phone lock: Off Phone code: 1122 173 byte(s) read reading data... 972 byte(s) read lock[1] code: - default lock[2] code: - default lock[3] code: - 1122 lock[4] code: - default lock[5] code: - default lock[6] code: - default lock[7] code: - default if code is not accepted by phone: - insert wrong sim card into phone - power-On phone - enter code: 12345678 - wait 10 seconds - power-Off phone via "Power" button (do not remove battery) - read unlock codes again Finished, time used: 12 sec Remove/Install battery now |
Did you tried to follow the instruction given by software ? |
i havesame problem pless help my unlock g 7007 COM5 [VCP0] selected module v4.04 Action: read unlock codes unlock method: read codes Model: Huawei-G7007 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8A04:8A01]... CPU: MT6235 high speed boot On chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6235,E04 Date: 2000.00.00 Version: 1.0 Version: ENGC46B182 Version: VER.B 80 byte(s) read imei: 35722103019755 connection Ok 185 byte(s) read 38 byte(s) read Phone lock: Off Phone code: 1122 173 byte(s) read reading data... 972 byte(s) read lock[1] code: + default lock[2] code: + default lock[3] code: + 1122 lock[4] code: - default lock[5] code: - default lock[6] code: + default lock[7] code: + default if code is not accepted by phone: - insert wrong sim card into phone - power-On phone - enter code: 12345678 - wait 10 seconds - power-Off phone via "Power" button (do not remove battery) - read unlock codes again Finished, time used: 25 sec Remove/Install battery now ! |
1: read backup then select unlock method: smart fast hit sp-unlock |
