06-22-2011, 18:42 | #1 (permalink) |
Freak Poster Join Date: Sep 2004 Location: BG, Sofia Age: 47
Member: 82937 Status: Offline Sonork: 100.1613800 Thanks Meter: 7 | Huawei G7007 unlock problem Flash with backup - result: software error:23 Any help ? |
06-22-2011, 19:14 | #2 (permalink) |
Member: 82937 Status: Offline Sonork: 100.1613800 Thanks Meter: 7 | COM4 [VCP0] selected module v3.95 Device: _Autodetect MT6228-6268 NAND Checking data, wait... Action: write flash NAND write: Firmware Huawei-G7007_HUAWEI35_08B_PCB01_GPRS_MT6235B_S01.ENGC46B1 82__fullflash_20110622-150851.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nfi area detection... external bootloader is not present bootloader version: HUAWEI35_08B_BOOTLOADER_V005_MT6235B_ENGC46B182.bi n nfi area detection (3 cores) finished: Ok interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0053]: 00AD:00A100000015 [HYNIX] H8BCS0PG0MBP chip size: 128Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: absent done Set baudrate (921600)... done ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/06000000 firmware size: 32Mb ffs size: 96Mb detect sec ro... detect custom parameters... detect project-id... project-id: ENGC46B182 detect NAND info... number of areas/bytes to read: 1:001A0000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... external bootloader is not present bootloader version: HUAWEI35_08B_BOOTLOADER_V005_MT6235B_ENGC46B182.bi n nfi area detection (3 cores) finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... number of areas/bytes to read: 1:00020000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... number of areas/bytes to read: 1:00020000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... startup code area #1 is valid startup code area #1 detection done rom info ver: 05 sw version: HUAWEI35_08B_PCB01_GPRS_MT6235B_S01.ENGC46B182.BIN project-id: ENGC46B182, BE898244 code offset: 00000000 ffs offset/size [01]: 02000000/06000000 rom info structure: [protected] type (05), 1 record(s) TCL-ID is absent ===> done nfi area detection... external bootloader is not present bootloader version: HUAWEI35_08B_BOOTLOADER_V005_MT6235B_ENGC46B182.bi n nfi area detection (3 cores) finished: Ok startup code area #1 check... startup code area #1 calculation... startup code area #1 fixed number of cores: 3 loading files... number of areas: 3 done write... write bootloader... . . write core... |
06-23-2011, 15:52 | #4 (permalink) |
Freak Poster Join Date: Nov 2005 Location: Sliven, Bulgaria
Member: 198847 Status: Online Thanks Meter: 109 | Flash phone with firmware from support and repair IMEI: write: Firmware Huawei-G7007_HUAWEI35_08B_PCB01_GPRS_MT6235B_S01.ENGC46B1 82_MTel_En_Bg.B4M.bin |
The Following User Says Thank You to Petyo For This Useful Post: |
06-25-2011, 00:25 | #7 (permalink) |
No Life Poster Join Date: Sep 2010 Location: Cali-Colombia Age: 46
Member: 1389840 Status: Offline Sonork: 100.1627479 Thanks Meter: 114 | friend, what happens is that "INFINITY TEAM" has problems with these models, makes error 23 andthe problem is that error out of these models "G" |
06-25-2011, 08:56 | #8 (permalink) |
Member: 198847 Status: Online Thanks Meter: 109 | I had the same problem, but after several attempts, managed to recover the phone. Code: ==== [11.12.2010 г. 13:39:37] ==== COM239 [VCP0] selected module v3.70 Action: read unlock codes unlock method: read codes Model: Huawei-G7007 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8A04:8A01]... CPU: MT6235 chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6235,E04 Date: 2000.00.00 Version: 1.0 Version: ENGC46B182 Version: VER.B 80 byte(s) read imei: 35722103022254 connection Ok 185 byte(s) read 38 byte(s) read Phone lock: Off Phone code: 1234 Finished, time used: 17 sec Remove/Install battery now ! ==== [11.12.2010 г. 13:40:27] ==== COM239 [VCP0] selected module v3.70 Action: "sp-unlock" unlock method: smart fast Model: Huawei-G7007 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8A04:8A01]... CPU: MT6235 chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6235,E04 Date: 2000.00.00 Version: 1.0 Version: ENGC46B182 Version: VER.B 80 byte(s) read imei: 35722103022254 connection Ok 185 byte(s) read reading data... reading data #2... building new data... writing data... 173 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 36 sec Remove/Install battery now ! Flash phone with firmware from support area ! method is not supported yet method is not supported yet ==== [11.12.2010 г. 13:54:35] ==== COM239 [VCP0] selected module v3.70 Action: read unlock codes unlock method: read codes Model: Huawei-G7007 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8A04:8A01]... CPU: MT6235 chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6235,E04 Date: 2000.00.00 Version: 1.0 Version: ENGC46B182 Version: VER.B 80 byte(s) read imei: 35722103022254 connection Ok 185 byte(s) read 38 byte(s) read Phone lock: Off Phone code: 1122 Finished, time used: 13 sec Remove/Install battery now ! ==== D:\Program Files\InfinityBox\MModule\MModule.exe [11.12.2010 г. 14:01:06] ==== Wait... Device: Huawei-G7007 Done Flash phone with firmware from support area ! Loading file v.05... Huawei-G7007_HUAWEI35_08B_PCB01_GPRS_MT6235B_S01.ENGC46B182_MTel_En_Bg.B4M.bin loaded usb bootloader (file) is absent rom info ver: 05 sw version: HUAWEI35_08B_PCB01_GPRS_MT6235B_S01.ENGC46B182.BIN project-id: ENGC46B182, BE898244 code offset: 00000000 ffs offset/size [01]: 02000000/06000000 rom info structure: [protected] type (05), 1 record(s) TCL-ID is absent file w/protection: startup code area #1 ==== [11.12.2010 г. 14:02:36] ==== COM239 [VCP0] selected module v3.70 Device: Huawei-G7007 Checking data, wait... Action: write flash NAND write: Firmware Huawei-G7007_HUAWEI35_08B_PCB01_GPRS_MT6235B_S01.ENGC46B182_MTel_En_Bg.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs firmware patch (general #0)... done firmware patch (sp-lock #1)... not required firmware patch (sp-lock #2)... not required nfi area detection... external bootloader is not present bootloader version: HUAWEI35_08B_BOOTLOADER_V005_MT6235B_ENGC46B182.bin nfi area detection (3 cores) finished: Ok interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0053]: 00AD:00A100000015 [HYNIX] H8BCS0PG0MBP chip size: 128Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: S_DA_RAM_ERROR done Set baudrate (921600)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/06000000 firmware size: 32Mb ffs size: 96Mb detect sec ro... detect custom parameters... detect project-id... project-id: ENGC46B182 detect NAND info... number of areas/bytes to read: 1:001A0000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... external bootloader is not present bootloader version: HUAWEI35_08B_BOOTLOADER_V005_MT6235B_ENGC46B182.bin nfi area detection (3 cores) finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... number of areas/bytes to read: 1:00020000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... number of areas/bytes to read: 1:00020000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... error: unexpected answer: startup code area #1 is valid startup code area #1 detection done rom info ver: 05 sw version: HUAWEI35_08B_PCB01_GPRS_MT6235B_S01.ENGC46B182.BIN project-id: ENGC46B182, BE898244 code offset: 00000000 ffs offset/size [01]: 02000000/06000000 rom info structure: [protected] type (05), 1 record(s) TCL-ID is absent ===> done nfi area detection... external bootloader is not present bootloader version: HUAWEI35_08B_BOOTLOADER_V005_MT6235B_ENGC46B182.bin nfi area detection (3 cores) finished: Ok startup code area #1 check... startup code area #1 calculation... startup code area #1 fixed number of cores: 3 loading files... number of areas: 3 done write... write bootloader... . . write core... Disconnect... done file saved: D:\Program Files\InfinityBox\MModule\backup_security\Huawei-G7007_HUAWEI35_08B_PCB01_GPRS_MT6235B_S01.ENGC46B182__system_log_20101211-141019.B4X.bin Finished, time used: 7 min 43 sec Remove/Install battery now ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? aborted by user Loading file v.05... Huawei-G7007_HUAWEI35_08B_PCB01_GPRS_MT6235B_S01.ENGC46B182_MTel_En_Bg.B4M.bin loaded usb bootloader (file) is absent rom info ver: 05 sw version: HUAWEI35_08B_PCB01_GPRS_MT6235B_S01.ENGC46B182.BIN project-id: ENGC46B182, BE898244 code offset: 00000000 ffs offset/size [01]: 02000000/06000000 rom info structure: [protected] type (05), 1 record(s) TCL-ID is absent file w/protection: startup code area #1 ==== [11.12.2010 г. 14:12:46] ==== COM239 [VCP0] selected module v3.70 Device: Huawei-G7007 Checking data, wait... Action: write flash NAND write: Firmware Huawei-G7007_HUAWEI35_08B_PCB01_GPRS_MT6235B_S01.ENGC46B182_MTel_En_Bg.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nfi area detection... external bootloader is not present bootloader version: HUAWEI35_08B_BOOTLOADER_V005_MT6235B_ENGC46B182.bin nfi area detection (3 cores) finished: Ok interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! bootcode current/expected: 0.0/3.2 CPU: 6235:8A04:8A01 status: 00 bbchip bl ver: 00 NOR flash id[0000]: 0000:000000000000 [AMD] AM29DL323D chip size: 0Mb otp status/size: S_DONE/00000000 NAND flash id[0000]: 0000:000000000000 [SAMSUNG] K9F5608Q0C chip size: 0Mb page/spare size: 0000/0000 pages per block: 0000 bits i/o: 00 address cycles: 00 internal RAM size: 00000000 external RAM [HW_RAM_UNKNOWN, CS0] size: 00000000 sec error code: 00 error: can not boot device: 07E9:S_BROM_LOCK_POWERKEY_FAIL error: last error: 07E9:S_BROM_LOCK_POWERKEY_FAIL Disconnect... done Finished, time used: 12 sec Remove/Install battery now ! ==== [11.12.2010 г. 14:13:13] ==== COM239 [VCP0] selected module v3.70 Device: Huawei-G7007 Checking data, wait... Action: write flash NAND write: Firmware Huawei-G7007_HUAWEI35_08B_PCB01_GPRS_MT6235B_S01.ENGC46B182_MTel_En_Bg.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nfi area detection... external bootloader is not present bootloader version: HUAWEI35_08B_BOOTLOADER_V005_MT6235B_ENGC46B182.bin nfi area detection (3 cores) finished: Ok interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0053]: 00AD:00A100000015 [HYNIX] H8BCS0PG0MBP chip size: 128Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: S_DA_RAM_ERROR done Set baudrate (921600)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/06000000 firmware size: 32Mb ffs size: 96Mb detect sec ro... detect custom parameters... detect project-id... project-id: ENGC46B182 detect NAND info... number of areas/bytes to read: 1:001A0000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... external bootloader is not present bootloader version: HUAWEI35_08B_BOOTLOADER_V005_MT6235B_ENGC46B182.bin nfi area detection (3 cores) finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... number of areas/bytes to read: 1:00020000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... number of areas/bytes to read: 1:00020000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... error: unexpected answer: startup code area #1 is valid startup code area #1 detection done rom info ver: 05 sw version: HUAWEI35_08B_PCB01_GPRS_MT6235B_S01.ENGC46B182.BIN project-id: ENGC46B182, BE898244 code offset: 00000000 ffs offset/size [01]: 02000000/06000000 rom info structure: [protected] type (05), 1 record(s) TCL-ID is absent ===> done nfi area detection... external bootloader is not present bootloader version: HUAWEI35_08B_BOOTLOADER_V005_MT6235B_ENGC46B182.bin nfi area detection (3 cores) finished: Ok startup code area #1 check... startup code area #1 calculation... startup code area #1 fixed number of cores: 3 loading files... number of areas: 3 done write... write bootloader... . . write core... Disconnect... done file saved: D:\Program Files\InfinityBox\MModule\backup_security\Huawei-G7007_HUAWEI35_08B_PCB01_GPRS_MT6235B_S01.ENGC46B182__system_log_20101211-142140.B4X.bin Finished, time used: 8 min 26 sec Remove/Install battery now ! Action: "repair imei" Model: Huawei-G7007 Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... imei-1: " imei write method: mode-1 new imei-1: 357221030222542 verification Ok Finished, time used: 13 sec Remove/Install battery now ! |
06-25-2011, 13:01 | #11 (permalink) |
Member: 82937 Status: Offline Sonork: 100.1613800 Thanks Meter: 7 | Flash this sh*t 10 or 20 times. With Pinfinder, direct cable, on COM1, All options on soft, new and old version ..... but result is error 23. My opinion is that infinity can't read (and save) correct backup. This f...... phone is not supported by infinity till now. Anyway thanks for help. |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
