11-10-2011, 16:12 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Bulgaria/China Age: 58
Member: 391664 Status: Offline Sonork: Python Thanks Meter: 1,063 | Huawei G7010 Fast Direct Unlock is Not Working !! module v4.07 Device: _Autodetect MT6253 NOR Checking data, wait... advanced flash detection disabled Action: "sp-unlock" unlock method: standard fast Unlock procedure can be faster if you skip ffs/eeprom area backup procedure. Do you want to disable ffs/eeprom backup ? ffs/eeprom backup disabled ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6253:8A02:8A00]... CPU: MT6253 high speed boot On chip: 0000:0000:000F status: FF boot packet size: 0400 Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 7 sec Remove/Install battery now ! ==== [11/10/2011 8:03:45 PM] ==== COM91 [ProlificSerial2] selected module v4.07 Device: _Autodetect MT6253 NOR Checking data, wait... advanced flash detection disabled Action: "sp-unlock" unlock method: standard ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6253:8A02:8A00]... CPU: MT6253 high speed boot On chip: 0000:0000:000F status: FF boot packet size: 0400 Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 13 sec Remove/Install battery now ! ==== [11/10/2011 8:04:08 PM] ==== COM91 [ProlificSerial2] selected module v4.07 Action: "sp-unlock" unlock method: smart fast Model: _Autodetect MT6253 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6253:8A02:8A00]... CPU: MT6253 high speed boot On chip: 0000:0000:000F status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6253,E02 Date: 2000.00.00 Version: 1.0 Version: ESPC113B217SSC Version: VER.B detecting structure #2... 0 1 2 3 4 6 7 8 9 10 11 12 13 15 21 22 23 24 25 27 28 29 30 31 32 33 34 36error: detection failed (28 tries), read flash and send to support connection Ok detecting structure #1... 1 3 4 6 7 11 12 14warning: wrong packet cs 16 17 19 21 23 24 26 27 31 32 34warning: wrong packet cs 36 37 39error: detection failed (22 tries), read flash and send to support error: can't read required data error: operation failed ! Finished, time used: 10 sec Remove/Install battery now ! |
11-10-2011, 16:55 | #2 (permalink) |
Member: 391664 Status: Offline Sonork: Python Thanks Meter: 1,063 | error: last error: 0012:[FAT] Target FAT file not found COM91 [ProlificSerial2] selected module v4.07 Model: Huawei-G7010 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6253:8A02:8A00]... CPU: MT6253 high speed boot On chip: 0000:0000:000F status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6253,E02 Date: 2000.00.00 Version: 1.0 Version: ESPC113B217SSC Version: VER.B 115 byte(s) read imei: 35391504581115 Finished, time used: 7 sec Remove/Install battery now ! Now click to "OK" button and press and HOLD phone "Power" button again ! interface: META_DLL_v6.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... done Release Power button now ! error: last error: 0012:[FAT] Target FAT file not found Shutdown... done error: operation failed ! Finished, time used: 5 sec Remove/Install battery now ! |
11-10-2011, 20:48 | #5 (permalink) | |
No Life Poster Join Date: Mar 2011 Location: GSM World!! Age: 35
Member: 1530237 Status: Offline Sonork: 100.1614868 Thanks Meter: 5,598 | How repair & UNlock you Phone (G7010 Normal) Quote:
Thanks !!! | |
11-10-2011, 21:40 | #6 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | According to your advice it looks like you did not tried to repair any G7010 by yourself, but you kill a lot of them. Am I right ? @maplegsm I think that for now it's not possible to repair your phone. You can try to flash phone with eeprom/ffs files from Infinity-Box support area, but I think you will get "Error XX" result. |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
how the **** do i make wintesla 6.03 work | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-16-1999 08:41 |
