Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Feb 2009 Location: INDIA
Member: 973227 Status: Online Thanks: 231
| Huawei g7010 software error 23 hi sir i have huawei g7010 phone without sim its works as normal , we can see menu and all but if i insert simcard then shows "software error 23" for this i have flashed many files from support with eprom file imei is also original but i could not solve this error so i need your guidance to solve this error Code: COM16 [ProlificSerial2] selected module v4.27 Device: Huawei-G7010 Checking data, wait... Action: write flash write: Firmware Huawei-G7010_HUAWEI53_09B_PCB01_GPRS_MT6253_S00.MEXC13B232SSC.BIN_FLNTY6701111184KC_En_Es_Movistar-Mexico.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nor area detection... "format ffs" active interface: BROM_DLL_v3.1108.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6253:8A02:8A00 status: FF bbchip bl ver: FE NOR flash id[00C0]: 0098:009E00000000 [TOSHIBA] TC58FYM7T8C chip size: 16Mb otp status/size: S_DA_NOR_OTP_EXIST/00020000 NAND flash chip: not installed internal RAM size: 00020000 external RAM: absent done Set baudrate (921600)... done ram test (40000000)... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 00000000/00000000 detect sec ro... error:0BF9:S_DA_HANDSET_SEC_INFO_NOT_FOUND detect custom parameters... error:0401:S_CUST_PARA_NOT_SUPPORTED detect project-id... project-id: CHLC83B126 detect NOR info... number of areas/bytes to read: 1:00050000 reading (HW_STORAGE_NOR)... TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: HUAWEI53_09B_PCB01_GPRS_MT6253_S00.CHLC83B126.BIN_FLNTY6701111184KC project-id: CHLC83B126, 00000000 code offset: 00000000 ffs offset/size [02]: 00DC0000/00240000 rom info structure: [standard] type (07) TCL-ID is absent ===> done startup code area #1 check... done number of cores: 1 loading files... number of areas: 1 done write... write core... write core... Format... autodetection mode... Format don Code: COM16 [ProlificSerial2] selected module v4.27 Device: Huawei-G7010 Checking data, wait... Action: write flash write: Firmware Huawei-G7010_HUAWEI53_09B_PCB01_GPRS_MT6253_S00.SRBC21B278SSCPAB.BIN_FLNTY6701111184KC_En_Srpski.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nor area detection... "format ffs" active interface: BROM_DLL_v3.1108.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6253:8A02:8A00 status: FF bbchip bl ver: FE NOR flash id[00C0]: 0098:009E00000000 [TOSHIBA] TC58FYM7T8C chip size: 16Mb otp status/size: S_DA_NOR_OTP_EXIST/00020000 NAND flash chip: not installed internal RAM size: 00020000 external RAM: absent done Set baudrate (921600)... done ram test (40000000)... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 00000000/00000000 detect sec ro... error:0BF9:S_DA_HANDSET_SEC_INFO_NOT_FOUND detect custom parameters... error:0401:S_CUST_PARA_NOT_SUPPORTED detect project-id... project-id: MEXC13B232SSC detect NOR info... number of areas/bytes to read: 1:00050000 reading (HW_STORAGE_NOR)... TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: HUAWEI53_09B_PCB01_GPRS_MT6253_S00.MEXC13B232SSC.BIN_FLNTY6701111184KC project-id: MEXC13B232SSC, 00000000 code offset: 00000000 ffs offset/size [02]: 00DC0000/00240000 rom info structure: [standard] type (07) TCL-ID is absent ===> done startup code area #1 check... done number of cores: 1 loading files... number of areas: 1 done write... write core... write core... Format... autodetection mode... Format done Disconnect... done Finished, time used: 5 min 35 sec Remove/Install battery now ! Disconnect... done Finished, time used: 6 min 2 sec Remove/Install battery now ! |
| | #3 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Jun 2006 Location: india > gujarat
Member: 296999 Status: Offline Sonork: not avaible Thanks: 150
| now infinity takes money for one year update . please do that . i only update for this model but no supported software error 23 |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| New Nokia Software!!!!!!! | Jefferson | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 73 | 05-15-2013 13:07 |
| where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 2 | 12-12-2012 12:26 |
| Need software upgrade for Nokia 5110 | ptkrf | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 26 | 09-25-2012 02:41 |
| need software for 5161 by cable | mln2000 | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 6 | 08-29-2010 20:17 |
| 5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 2 | 07-07-1999 12:27 |
